查看: 2820|回復: 4
請大神幫忙分析一下程序就是一個簡單的時鐘,一切都可以就是按鍵部分不起作用
回帖獎勵 5 黑幣 回復本帖可獲得 5 黑幣獎勵! 每人限 1 次(中獎概率 50%)
本帖最后由 july0 于 2018-3-3 21:41 編輯
#include<reg52.h>
#include"24c02.h"
sbit rs=P2^6;
sbit wr=P2^5;
sbit lcden=P2^7;
sbit s1=P1^0;
sbit s2=P1^1;
sbit s3=P1^2;
sbit rd=P1^3;
sbit beep=P1^4;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]="2008-9-30 MON";
void delay(uint z)
        uint x,y;
        for(x=z;x--;x>0)
                for(y=110;y--;y>0);
void di()
        beep=0;
        delay(100);
        beep=1;
void write_com(uchar com)//命令送給液晶
  rs=0;
  lcden=0;
  P0=com;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_date(uchar date)
  rs=1;
  lcden=0;
  P0=date;
  delay(5);
  lcden=1;
  delay(5);
  lcden=0;
void write_sfm(uchar add,uchar date)
  uchar shi,ge;
  shi=date/10;
  ge=date%10;
  write_com(0x80+0x40+add);
  write_date(0x30+shi);
  write_date(0x30+ge);
void init()
  void init_24c02();
  uchar num;
  wr=0;
  rd=0;
  lcden=0;
  fen=0;
  shi=0;
  miao=0;
  count=0;
  s1num=0;
  write_com(0x38);
  write_com(0x0c);
  write_com(0x06);
  write_com(0x01);
  write_com(0x80);
  for(num=0;num<15;num++)
        write_date(table[num]);
        delay(5);
  write_com(0x80+0x40+6);
  write_date(':');
  delay(5);
  write_com(0x80+0x40+9);
  write_date(':');
  delay(5);
  miao=read_add(1);
  fen=read_add(2);
  shi=read_add(3);
  write_sfm(10,miao);
  write_sfm(4,shi);
  write_sfm(7,fen);
  TMOD=0x01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
void keyscan()
  if(s1==0)
          delay(5);
        if(s1==0)
          s1num++;
          while(!s1);
          di();
          if(s1num==1)
            TR0=0;
                write_com(0x80+0x40+10);
                write_com(0x0f);
          if(s1num==2)
            write_com(0x80+0x40+7);
          if(s1num==3);
            write_com(0x80+0x40+4);
          if(s1num==4);
            s1num=0;
                write_com(0x0c);
                TR0=1;
  if(s1num!=0);
    if(s2==0);
        delay(5);
        if(s2==0);
                while(!s2);
                di();
                if(s1num==1)
                        miao++;
                        if(miao==60)
                        miao=0;
                        write_sfm(10,miao);
                        write_add(1,miao);
                if(s1num==2)
                     fen++;
                        if(fen==60)
                        fen=0;
                        write_sfm(7,fen);
                        write_add(2,fen);
                if(s1num==3)
                        shi++;
                        if(shi==24)
                        shi=0;
                        write_sfm(4,shi);
                        write_add(3,shi);
        if(s3==0)
                delay(5);
                if(s3==0)
                while(!s3);
                di();
                if(s1num==1)
                         miao--;
                        if(miao==-1)
                        miao=59;
                        write_sfm(10,miao);
                        write_add(1,miao);
                if(s1num==2)
                        fen--;
                        if(fen==-1)
                        fen=59;
                        write_sfm(7,fen);
                        write_add(2,fen);
                if(s1num==3)
                        shi--;
                        if(shi==-1)
                        shi=23;
                        write_sfm(4,shi);
                        write_add(3,shi);
        init();
                keyscan();
void timer0() interrupt 1
        count++;
        if(count==20)
        miao++;
        count=0;
        if(miao==60)
                miao=0;
                fen++;
                if(fen==60)
                        fen=0;
                        shi++;
                        if(shi==24)
                                shi=0;
                        write_sfm(4,shi);
                        write_add(3,shi);
                write_sfm(7,fen);
                write_add(2,fen);
        write_sfm(10,miao);
        write_add(1,miao);
其中24c02.h的內容是
bit write=0;
sbit sda=P2^0;
sbit scl=P2^1;
void delay0()
void start()
        sda=1;
        delay0();
        scl=1;
        delay0();
        sda=0;
        delay0();
void stop()
  sda=0;
  delay0();
  scl=1;
  delay0();
  sda=1;
  delay0();
void respon()
        uchar i;
        scl=1;
        delay0();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay0();
void init_24c02()
        sda=1;
        delay0();
        scl=1;
        delay0();
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay0();
                sda=CY;
                delay0();
                scl=1;
                delay0();
        scl=0;
        delay0();
        sda=1;
        delay0();
uchar read_byte()
        uchar i,k;
        scl=0;
        delay0();
        sda=1;
        delay0();
        for(i=0;i<8;i++)
                scl=1;
                delay0();
                k=(k<<1)|sda;
                scl=0;
                delay0();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respon();
        write_byte(address);
        respon();
        write_byte(date);
        respon();
        stop();
char read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respon();
        respon();
        start();
        write_byte(0xa1);
        respon();
        date=read_byte();
        stop();
        return date;
求解為什么連接上按鍵后按鍵部分卻不起作用(按鍵沒有問題)
ID:222948 發表于 2018-3-4 10:34 | 只看該作者
在程序中找到if(s1num!=0);這一行把后面的分號去掉試一下,應該可以了,(另外就是不用的函數可以屏蔽了,還有在中斷和主函數不要同時調用同一個函數)這是建議
ID:284007 發表于 2018-3-4 12:28 | 只看該作者
999333 發表于 2018-3-4 10:34
在程序中找到if(s1num!=0);這一行把后面的分號去掉試一下,應該可以了,(另外就是不用的函數可以屏蔽了, ...
謝謝終于調試成功了,我還有一個問題希望前輩解答一下,那就是是不是中斷和主函數同時調用一個函數有時候會出現錯誤才不能同時調用
ID:284007 發表于 2018-3-4 12:33 | 只看該作者
還有就是液晶.有一部分我沒有設置卻會出現字符是為什么,我試了很多遍也不能去除掉
ID:222948 發表于 2018-3-4 19:23 | 只看該作者
july0 發表于 2018-3-4 12:33
亂碼是肯定的,你只負責初始地址而且沒有限制最后的末地址,最簡單就是在uchar code table[]="2008-9-30 MON";中mon的后面加兩個空格就行;比如uchar code table[]="2008-9-30 MON  ";這樣就行了
