查看: 11349|回復: 5
正點原子STM32的ESP8266程序
ID:287002 發表于 2018-3-2 17:28 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
讓大家參考參考
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "led.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "usmart.h"
  8. #include "malloc.h"
  9. #include "mmc_sd.h"
  10. #include "flash.h"
  11. #include "ff.h"
  12. #include "exfuns.h"
  13. #include "text.h"
  14. #include "usart2.h"
  15. #include "touch.h"
  16. #include "common.h"
  17. //ALIENTEK戰艦STM32開發板擴展實驗6
  18. //ATK-ESP8266 WIFI模塊測試實驗
  19. int main(void)
  20. {
  21.         u8 key,fontok=0;
  22.            Stm32_Clock_Init(9);        //系統時鐘設置
  23.         delay_init(72);                        //延時初始化
  24.         uart_init(72,115200);         //串口1初始化
  25.         usart2_init(36,115200);  //串口2初始化
  26.         u2_printf("nihao/r/n");
  27.         LCD_Init();                                //初始化液晶
  28.         LED_Init();                 //LED初始化
  29.         KEY_Init();                                //按鍵初始化
  30.         usmart_dev.init(72);        //usmart初始化
  31.         TP_Init();                                //初始化觸摸屏
  32.         mem_init(SRAMIN);                //初始化內部內存池
  33.         exfuns_init();                        //為fatfs相關變量申請內存
  34.   f_mount(0,fs[0]);                 //掛載SD卡
  35.         f_mount(1,fs[1]);                                             //掛載FLASH.
  36.         key=KEY_Scan(0);
  37.         if(key==KEY_RIGHT)                //強制校準
  38.         {
  39.                 LCD_Clear(WHITE);        //清屏
  40.                 TP_Adjust();                  //屏幕校準
  41.                 TP_Save_Adjdata();
  42.                 LCD_Clear(WHITE);        //清屏
  43.         }
  44.         fontok=font_init();                //檢查字庫是否OK
  45.         if(fontok||key==KEY_DOWN)//需要更新字庫
  46.         {
  47.                 LCD_Clear(WHITE);                           //清屏
  48.                 POINT_COLOR=RED;                        //設置字體為紅色
  49.                 LCD_ShowString(60,50,200,16,16,"ALIENTEK STM32");
  50.                 while(SD_Initialize())                //檢測SD卡
  51.                 {
  52.                         LCD_ShowString(60,70,200,16,16,"SD Card Failed!");
  53.                         delay_ms(200);
  54.                         LCD_Fill(60,70,200+60,70+16,WHITE);
  55.                         delay_ms(200);
  56.                 }
  57.                 LCD_ShowString(60,70,200,16,16,"SD Card OK");
  58.                 LCD_ShowString(60,90,200,16,16,"Font Updating...");
  59.                 key=update_font(20,110,16,0);//從SD卡更新
  60.                 while(key)//更新失敗
  61.                 {
  62.                         LCD_ShowString(60,110,200,16,16,"Font Update Failed!");
  63.                         delay_ms(200);
  64.                         LCD_Fill(20,110,200+20,110+16,WHITE);
  65.                         delay_ms(200);
  66.                 }
  67.                 LCD_ShowString(60,110,200,16,16,"Font Update Success!");
  68.                 delay_ms(1500);
  69.                 LCD_Clear(WHITE);        //清屏
  70.         }
  71.         atk_8266_test();                //進入ATK_ESP8266測試
  72. }
(適合戰艦V2 STM32開發板)擴展實驗6 ATK-ESP8266 WIFI模塊測試實驗.rar (847.32 KB, 下載次數: 316)
收藏收藏3 分享淘帖 頂 踩
ID:403087 發表于 2018-12-13 15:42 | 只看該作者
謝謝分享!
ID:445515 發表于 2019-1-2 22:32 | 只看該作者
這是stm32f4的嗎
ID:362745 發表于 2019-1-3 16:58 | 只看該作者
52是51的增強型,S52比C51,定時器多一個T2(這個東東強悍的很),RAM多128B,ROM多4K,中斷多2個,多一個看門狗,在掉電、數據指針等方面還有一些改進。
S52的最高外接晶振可以達到33MHz,C51大概只有24MHz。
現在市面上,C51都差不多淘汰了,價格兩者接近(可能一樣),要買的話,攤主一般會推薦你買S52。
ID:474606 發表于 2019-5-17 14:21 | 只看該作者
感謝樓主熱心分享,正好用的上。
ID:664066 發表于 2020-6-6 11:44 | 只看該作者
感謝分享。
