根據(jù)論壇的帖子http://www.raoushi.com/bbs/dpj-88507-1.html
自己移植了最新版FATS 0.13a
測試成功,可以讀寫文件,追加文件。
部分代碼如下
- void SD_ReadTest(void)
- unsigned int offset = 0;
- disk_initialize(DEV_MMC);
- res = f_mount(&fs,"1:",0); // 掛載
- res = f_open(&fsrc,"1:/KILLL.BAT",FA_OPEN_EXISTING | FA_READ); // 打開文件
- if(res != FR_OK)
- printf("%d ",res);
- printf("open error\r\n");
- else
- file_size = f_size(&fsrc);
- printf("filesize:%d\r\n",file_size);
- do{
- res = f_lseek(&fsrc,offset); // 指針往后推128
- res = f_read(&fsrc,buffer,sizeof(buffer),&br);
- if(res == FR_OK)
- USART1_SendBuf(buffer,br);
- printf("\r\n");
- else
- printf("read fils err\r\n");
- offset += 128;
- file_size -= 128;
- }while(file_size>128);
- if(file_size>0)
- res = f_read(&fsrc,buffer,file_size,&br);
- if(res == FR_OK)
- printf("EndOfFile\r\n");
- else
- f_close(&fsrc);// 關閉文件
- f_mount(NULL,"1:",0); //卸載磁盤
復制代碼 獲取文件長度并串口輸出文件內(nèi)容,適用于讀取bin文件做系統(tǒng)軟件升級IAP.
- FRESULT open_append (
- FIL* fp, /* [OUT] File object to create */
- const char* path /* [IN] File name to be opened */
- FRESULT fr;
- /* Opens an existing file. If not exist, creates a new file. */
- fr = f_open(fp, path, FA_WRITE | FA_OPEN_ALWAYS);
- if (fr == FR_OK) {
- /* Seek to end of the file to append data */
- fr = f_lseek(fp, f_size(fp));
- if (fr != FR_OK)
- f_close(fp);
- return fr;
- void SD_WriteTest(void)
- unsigned char write_f[20]={"ming write file test"};
- disk_initialize(0);
- res = open_append(&fdst,"1:/testa.txt");
- // res = f_open(&fdst, "1:/testa.txt", FA_CREATE_ALWAYS | FA_WRITE);
- if(res != FR_OK)
- else
- f_printf(&fdst, "%d\n", runtime);
- //res = f_write(&fdst,write_f,sizeof(write_f),&bw);
- //res = f_puts("hello",&fdst);
- if(res <0)
- printf("write err! %d\r\n",res);
- else
- printf("write ok! %d\r\n",res);
- f_close(&fdst);
- f_mount(NULL,"1:",0);// 卸載
- printf("write test passed! \r\n");
復制代碼 文件內(nèi)容追加,適合保存日志log
- void ReadSDFile(void)
- // FIL file;
- FILINFO finfo;
- DIR dirs;
- int i_name=0;
- // char *fn;
- f_mount(&fs,"1:",1);
- res = f_opendir(&dirs, "1:/");
- if (res == FR_OK)
- while (f_readdir(&dirs, &finfo) == FR_OK)
- if (finfo.fattrib & AM_ARC)
- if(!finfo.fname[0]) break; //文件名不為空,如果為空,則表明該目錄下面的文件已經(jīng)讀完了
- stringcopy(buff_filename[i_name], (BYTE*)finfo.fname);
- i_name++;
- file_cnt = i_name;
- f_close(&fsrc);
- i_name = 0;
- do{
- //USART1_SendBuf(buff_filename[i_name],br);
- printf("%s\r\n",buff_filename[i_name]);
- i_name++;
- file_cnt--;
- }while(file_cnt);
- f_mount(NULL,"1:",1);
復制代碼 獲取文件列表。
STM32_SDIO_FAT13.zip
(1.44 MB, 下載次數(shù): 39)
2018-3-2 09:35 上傳
下載積分: 黑幣 -5
如果需要解壓密碼,請雙擊壓縮包或右鍵壓縮包查看注釋。
