#include <REG52.H>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#include <INTRINS.H>
typedef unsigned char uchar;
typedef unsigned short ushort;
typedef unsigned int uint;
// 定義51單片機(jī)端口
sbit SCL=P1^1; //IIC時(shí)鐘引腳定義
sbit SDA=P1^3; //IIC數(shù)據(jù)引腳定義
// 定義MPU6050內(nèi)部地址
#define SMPLRT_DIV 0x19 //陀螺儀采樣率,典型值:0x07(125Hz)
#define CONFIG 0x1A //低通濾波頻率,典型值:0x06(5Hz)
#define GYRO_CONFIG 0x1B //陀螺儀自檢及測(cè)量范圍,典型值:0x18(不自檢,2000deg/s)
#define ACCEL_CONFIG 0x1C //加速計(jì)自檢、測(cè)量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B //電源管理,典型值:0x00(正常啟用)
#define WHO_AM_I 0x75 //IIC地址寄存器(默認(rèn)數(shù)值0x68,只讀)
#define SlaveAddress 0xD0 //IIC寫(xiě)入時(shí)的地址字節(jié)數(shù)據(jù),+1為讀取
//函數(shù)聲明
void delay(unsigned int k); //延時(shí)
//MPU6050操作函數(shù)
void InitMPU6050(); //初始化MPU6050
void Delay5us();
void I2C_Start();
void I2C_Stop();
void I2C_SendACK(bit ack);
bit I2C_RecvACK();
void I2C_SendByte(uchar dat);
uchar I2C_RecvByte();
void I2C_ReadPage();
void I2C_WritePage();
void display_ACCEL_x();
void display_ACCEL_y();
void display_ACCEL_z();
uchar Single_ReadI2C(uchar REG_Address); //讀取I2C數(shù)據(jù)
void Single_WriteI2C(uchar REG_Address,uchar REG_data); //向I2C寫(xiě)入數(shù)據(jù)
//整數(shù)轉(zhuǎn)字符串
/*void SeriPushSend(uchar send_data)
SBUF=send_data;
while(!TI);TI=0;
//延時(shí)
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<940;j++);
//延時(shí)5微秒(STC11f04)
//不同的工作環(huán)境,需要調(diào)整此函數(shù)
//當(dāng)改用其他MCU時(shí),請(qǐng)調(diào)整此延時(shí)函數(shù)
void Delay5us()
//I2C起始信號(hào)
void I2C_Start()
SDA = 1;
SCL = 1;
Delay5us(); //延時(shí)
SDA = 0; //產(chǎn)生下降沿
Delay5us();
SCL=0; //延時(shí)
//I2C停止信號(hào)
void I2C_Stop()
SDA = 0; //拉低數(shù)據(jù)線(xiàn)
SCL = 1; //拉高時(shí)鐘線(xiàn)
SDA = 1; //產(chǎn)生上升沿
//I2C發(fā)送應(yīng)答信號(hào)
//入口參數(shù):ack (0:ACK 1:NAK)
SDA = ack; //寫(xiě)應(yīng)答信號(hào)
SCL = 0; //拉低時(shí)鐘線(xiàn)
//I2C接收應(yīng)答信號(hào)
bit I2C_RecvACK()
CY = SDA; //讀應(yīng)答信號(hào)
return CY;
//向I2C總線(xiàn)發(fā)送一個(gè)字節(jié)數(shù)據(jù)
uchar i;
for (i=0; i<8; i++) //8位計(jì)數(shù)器
dat <<= 1; //移出數(shù)據(jù)的最高位
SDA = CY; //送數(shù)據(jù)口
I2C_RecvACK();
//從I2C總線(xiàn)接收一個(gè)字節(jié)數(shù)據(jù)
uchar i;
uchar dat = 0;
SDA = 1; //使能內(nèi)部上拉,準(zhǔn)備讀取數(shù)據(jù),
dat <<= 1;
dat |= SDA; //讀數(shù)據(jù)
return dat;
//向I2C設(shè)備寫(xiě)入一個(gè)字節(jié)數(shù)據(jù)
I2C_Start(); //起始信號(hào)
I2C_SendByte(SlaveAddress); //發(fā)送設(shè)備地址+寫(xiě)信號(hào)
I2C_SendByte(REG_Address); //內(nèi)部寄存器地址,
I2C_SendByte(REG_data); //內(nèi)部寄存器數(shù)據(jù),
I2C_Stop(); //發(fā)送停止信號(hào)
//從I2C設(shè)備讀取一個(gè)字節(jié)數(shù)據(jù)
uchar REG_data;
I2C_SendByte(REG_Address); //發(fā)送存儲(chǔ)單元地址,從0開(kāi)始
I2C_SendByte(SlaveAddress+1); //發(fā)送設(shè)備地址+讀信號(hào)
REG_data=I2C_RecvByte(); //讀出寄存器數(shù)據(jù)
I2C_SendACK(1); //接收應(yīng)答信號(hào)
I2C_Stop(); //停止信號(hào)
return REG_data;
//初始化MPU6050
void InitMPU6050()
Single_WriteI2C(PWR_MGMT_1, 0x00); //解除休眠狀態(tài)
Single_WriteI2C(SMPLRT_DIV, 0x07);
Single_WriteI2C(CONFIG, 0x06);
Single_WriteI2C(GYRO_CONFIG, 0x18);
Single_WriteI2C(ACCEL_CONFIG, 0x01);
int GetData(uchar REG_Address) //獲得數(shù)據(jù) 不懂
uchar H,L;
H=Single_ReadI2C(REG_Address);
L=Single_ReadI2C(REG_Address+1);
return (H<<8)+L;
void init_uart()
TMOD=0x21;
TH1=0xfd;
TL1=0xfd;
SM0=0;
SM1=1;
REN=1;
//SCON=0x50;
PS=1; //串口中斷設(shè)為高優(yōu)先級(jí)別
// TR0=1; //啟動(dòng)定時(shí)器
TR1=1;
// ET0=1; //打開(kāi)定時(shí)器0中斷
ES=1;
EA=1;
//主程序
delay(500); //上電延時(shí)
init_uart();
delay(150);
// SeriPushSend(GetData(GYRO_XOUT_H));
// delay(10);
SBUF= GetData(0x43);
delay(10);
SBUF=GetData(0x45);
delay(10);
SBUF=GetData(0x47);
delay(10);
void ser() interrupt 4
TI=0;
