查看: 3156|回復(fù): 2
nrf24l01無線報(bào)警器主機(jī)和叢機(jī)源碼
ID:163705 發(fā)表于 2018-2-28 08:40 | 顯示全部樓層 |閱讀模式
nrf24l01無線報(bào)警器
當(dāng)兩個(gè)單片機(jī)之間的無線通信消失時(shí)會發(fā)出警報(bào)
單片機(jī)源程序如下:
  1. #include <reg52.h>
  2. #include <intrins.h>
  4. #define uint unsigned int
  5. //*****************************************************************************************
  6. bit crrent=1;      //定義DS18B20初始化返回值,表示初始化是否成功
  7. sbit beep=P0^0;
  8. sbit led=P0^1;
  9. uint value=0;
  10. uchar tflag;     //  是否正負(fù)
  11. uchar data disdat[6];
  12. uchar data setdat[4];
  13. void writelcdcmd(uchar);
  14. void writelcddat(uchar);
  15. //*****************************************************************************************
  16.
  17. #define TX_ADR_WIDTH    5  // 發(fā)射地址的字節(jié)個(gè)數(shù)
  18. #define TX_PLOAD_WIDTH  2  //發(fā)射字節(jié)
  19. uchar const TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x55,0x10,0x10,0x01};
  20. uchar rx_buf[TX_PLOAD_WIDTH];
  21. uchar tx_buf[TX_PLOAD_WIDTH];
  22. uchar distance_data[2];
  23. uchar flag;//標(biāo)志
  24. //nRF24L01引腳定義
  25. sbit CE   = P2^7;  // Chip Enable pin signal (output)
  26. sbit CSN  = P2^2;  // Slave Select pin, (output to CSN, nRF24L01)
  27. sbit IRQ  = P2^7;  // Interrupt signal, from nRF24L01 (input)
  28. sbit MISO = P2^5;  // Master In, Slave Out pin (input)
  29. sbit MOSI = P2^3;  // Serial Clock pin, (output)
  30. sbit SCK  = P2^6;  // Master Out, Slave In pin (output)
  31. uchar         bdata sta;
  32. sbit        RX_DR        =sta^6;          //接收數(shù)據(jù)準(zhǔn)備就緒
  33. sbit        TX_DS        =sta^5;          //已發(fā)送數(shù)據(jù)
  34. sbit        MAX_RT        =sta^4;
  35. unsigned char time;   //設(shè)置全局變量,專門用于嚴(yán)格延時(shí)
  36. //*********************************************NRF24L01*************************************
  37.
  38. //***************************************NRF24L01寄存器指令*******************************************************
  39. #define READ_REG        0x00          // 讀寄存器指令
  40. #define WRITE_REG       0x20         // 寫寄存器指令
  41. #define RD_RX_PLOAD     0x61          // 讀取接收數(shù)據(jù)指令
  42. #define WR_TX_PLOAD     0xA0          // 寫待發(fā)數(shù)據(jù)指令
  43. #define FLUSH_TX        0xE1         // 沖洗發(fā)送 FIFO指令
  44. #define FLUSH_RX        0xE2          // 沖洗接收 FIFO指令
  45. #define REUSE_TX_PL     0xE3          // 定義重復(fù)裝載數(shù)據(jù)指令
  46. #define NOP             0xFF          // 保留
  47. //*************************************SPI(nRF24L01)寄存器地址****************************************************
  48. #define CONFIG          0x00  // 配置收發(fā)狀態(tài),CRC校驗(yàn)?zāi)J揭约笆瞻l(fā)狀態(tài)響應(yīng)方式
  49. #define EN_AA           0x01  // 自動(dòng)應(yīng)答功能設(shè)置
  50. #define EN_RXADDR       0x02  // 可用信道設(shè)置
  51. #define SETUP_AW        0x03  // 收發(fā)地址寬度設(shè)置
  52. #define SETUP_RETR      0x04  // 自動(dòng)重發(fā)功能設(shè)置
  53. #define RF_CH           0x05  // 工作頻率設(shè)置
  54. #define RF_SETUP        0x06  // 發(fā)射速率、功耗功能設(shè)置
  55. #define STATUS          0x07  // 狀態(tài)寄存器
  56. #define OBSERVE_TX      0x08  // 發(fā)送監(jiān)測功能
  57. #define CD              0x09  // 地址檢測
  58. #define RX_ADDR_P0      0x0A  // 頻道0接收數(shù)據(jù)地址
  59. #define RX_ADDR_P1      0x0B  // 頻道1接收數(shù)據(jù)地址
  60. #define RX_ADDR_P2      0x0C  // 頻道2接收數(shù)據(jù)地址
  61. #define RX_ADDR_P3      0x0D  // 頻道3接收數(shù)據(jù)地址
  62. #define RX_ADDR_P4      0x0E  // 頻道4接收數(shù)據(jù)地址
  63. #define RX_ADDR_P5      0x0F  // 頻道5接收數(shù)據(jù)地址
  64. #define TX_ADDR         0x10  // 發(fā)送地址寄存器
  65. #define RX_PW_P0        0x11  // 接收頻道0接收數(shù)據(jù)長度
  66. #define RX_PW_P1        0x12  // 接收頻道0接收數(shù)據(jù)長度
  67. #define RX_PW_P2        0x13  // 接收頻道0接收數(shù)據(jù)長度
  68. #define RX_PW_P3        0x14  // 接收頻道0接收數(shù)據(jù)長度
  69. #define RX_PW_P4        0x15  // 接收頻道0接收數(shù)據(jù)長度
  70. #define RX_PW_P5        0x16  // 接收頻道0接收數(shù)據(jù)長度
  71. #define FIFO_STATUS     0x17  // FIFO棧入棧出狀態(tài)寄存器設(shè)置
  72. //**************************************************************************************
  73.
  74. void init_io(void)
  75. {
  76.            CE=0;
  77.            CSN=1;
  78.            SCK=0;
  79. }
  80. uchar SPI_RW(uchar byte)//發(fā)送指令,接受狀態(tài) ,返回值為狀態(tài)值
  81. {
  82.           uchar bit_ctr;
  83.            for(bit_ctr=0;bit_ctr<8;bit_ctr++)
  84.            {
  85.                    MOSI = (byte&0x80);
  86.                    byte = (byte<<1);
  87.                    SCK = 1;
  88.                    byte|=MISO;
  89.                    SCK=0;
  90.            }
  91.     return(byte);
  92. }
  93.     uchar SPI_RW_Reg(uchar reg, uchar value)
  94. {
  95.         uchar status;
  96.           CSN = 0;
  97.           status = SPI_RW(reg);
  98.           SPI_RW(value);
  99.           CSN = 1;
  100.           return(status);
  101. }
  102. uchar SPI_Read(uchar reg)
  103. {
  104.         uchar reg_val;
  105.           CSN = 0;
  106.           SPI_RW(reg); //寫指令
  107.           reg_val = SPI_RW(0); //讀reg的內(nèi)容
  108.           CSN = 1;
  109.           return(reg_val);
  110. }
  111. uchar SPI_Write_Buf(uchar reg, uchar *pBuf, uchar bytes)
  112. {
  113.         uchar status,byte_ctr;
  114.           CSN = 0;
  115.           status = SPI_RW(reg);
  116.           for(byte_ctr=0; byte_ctr<bytes; byte_ctr++)
  117.         SPI_RW(*pBuf++);
  118.           CSN = 1;
  119.           return(status);
  120. }
  121. void TX_Mode(void)
  122. {
  123.         CE=0;
  124.           SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); /*接收模塊的地址*/
  125.           SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH);   /*通道0 接收數(shù)據(jù)地址*/
  126.           SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH);         /*寫待發(fā)數(shù)據(jù)指令a0*/
  127.           SPI_RW_Reg(WRITE_REG + EN_AA, 0x01);  //數(shù)據(jù)通道0應(yīng)答允許
  128.           SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); //接收數(shù)據(jù)通道0允許
  129.           SPI_RW_Reg(WRITE_REG + SETUP_RETR, 0x1a);//等待 500+86us 自動(dòng)重發(fā)10次
  130.           SPI_RW_Reg(WRITE_REG + RF_CH,40);
  131.           SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x07);   //數(shù)據(jù)傳輸率1Mbps ,發(fā)射功率0dBm
  132.           SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); //配置寄存器
  133.         CE=1;
  134. }
  135. void checkflag()
  136. {           sta=SPI_Read(STATUS);//讀狀態(tài)寄存器
  137.         if(MAX_RT)
  138.           {
  139.                    SPI_RW_Reg(FLUSH_TX,0);                 //沖洗發(fā)送FIFO指令//
  140.              }
  141.                 SPI_RW_Reg(WRITE_REG+STATUS,sta);//清除中斷
  142. }
  143. //**********************************主函數(shù)************************************************
  144. void main(void)
  145. {
  146.         uchar xx;
  147.         init_io();
  148.         while(1)
  149.         {
  150.                 checkflag();
  151.                 for(xx=0;xx<2;xx++)
  152.                 {
  153.                         tx_buf[xx]= 0x11;        //發(fā)數(shù)據(jù)之前必須把要發(fā)送的數(shù)據(jù)裝入它
  154.                 }
  155.                 TX_Mode();                                //必須啟動(dòng)發(fā)送模塊
  156.         }
  157. }
nrf24l01無線報(bào)警器.zip (80.19 KB, 下載次數(shù): 32)
參與人數(shù) 1黑幣 +50 收起 理由
ID:130345 發(fā)表于 2018-3-3 10:27 | 顯示全部樓層
回去試著安裝一個(gè)在貴重物品上面
ID:130345 發(fā)表于 2018-3-3 10:31 | 顯示全部樓層
CE和IRQ為何共用一個(gè)IO口呢
