這是一個(gè)基于msp430f149做的可見光通信系統(tǒng)資料包含完整的程序源碼與設(shè)計(jì)論文,下面是內(nèi)容預(yù)覽:
基于大功率白光LED的可見光通信
摘要
本系統(tǒng)設(shè)計(jì)以 TI 公司的 MSP430F149 為主控芯片,完成了基于大功率白光 LED 的可見光 通信,實(shí)現(xiàn)了對(duì)兩路語音信號(hào)、m 序列信號(hào)和單音信號(hào)的無失真?zhèn)鬏敗T撏ㄐ叛b置由發(fā)送裝 置和接收裝置兩部分組成。發(fā)送裝置和接收裝置由放大電路、音頻鎖相環(huán) LM567、光電調(diào)制 電路、電源電路等模塊構(gòu)成,分別對(duì)信號(hào)進(jìn)行放大、調(diào)制、解調(diào)與供電等,從而實(shí)現(xiàn)了可見 光對(duì)信號(hào)的傳輸。同時(shí)使用 MSP430F149 為主控器,完成對(duì)發(fā)射裝置的溫度監(jiān)測、電壓采集及 信號(hào)傳輸記錄等功能。通過測試,本設(shè)計(jì)系統(tǒng)性能良好,各項(xiàng)指標(biāo)均能較好地完成設(shè)計(jì)要求 同時(shí) MSP430 系列單片機(jī)功耗低,滿足當(dāng)前低碳經(jīng)濟(jì)的發(fā)展理念。
Abstract
This system designs with MSP430F149 as main control chip of TI company, completed the visible light communication, based on high power white LED for two way voice signal and m sequence signal without distortion of the transmissionThe communication device consists of two parts, the transmitting and receiving deviceSending device and receiving device by amplifying circuit, audio phase-locked loop LM567, electro-optical modulation circuit, power circuit, such as modules, respectively for signal amplification, modulation and demodulation, and electricity, etc, thus realize signal through visible light transmissionAt the same time use MSP430F149 complete temperature detection of device, voltage acquisition and signal transmission record, etcThrough testing, this design system performance is good, all the indexes can be well complete design requirements for MSP430 series MCU low power consumption at the same time, satisfy the current low carbon economy development concept
目錄
摘要 1
1 、系統(tǒng)方案設(shè)計(jì)思路 3
2 、方案設(shè)計(jì)與選擇 4
21 CPU 的選擇 4
22 鎖相環(huán)的選擇 4
23 光調(diào)制中放大器件的選擇 4
24 顯示模塊的選擇 4
3、系統(tǒng)方案詳細(xì)設(shè)計(jì) 5
31 可見光通信裝置電源模塊 5
32 可見光通信裝置發(fā)送端 5
321 信號(hào)調(diào)制電路 5
3 3 可見光通信裝置接收端 6
331 信號(hào)解調(diào)放大電路 6
4、系統(tǒng)軟件設(shè)計(jì) 8
5、測試結(jié)果與分析 8
51 儀器設(shè)備 8
52 各模塊測試 9
521 語音傳輸模塊測試 9
522 模擬信號(hào)傳輸測試 9
523 LED 照明模塊測試 9
524 電源模塊測試 10
6、總結(jié) 10
參考文獻(xiàn) 11
本文所設(shè)計(jì)的可見光通信裝置以 MSP430F149 為控制核心,由發(fā)送端、接收端兩部分組成。 使用 MSP430F149 產(chǎn)生 m 序列并完成對(duì)裝置的溫度檢測、電壓采集及信號(hào)傳輸記錄等功能,
并且實(shí)時(shí)在 12864 上顯示。 發(fā)送端由主控芯片組成的最小系統(tǒng)、前置放大電路、音頻調(diào)制電路、光調(diào)制電路、白光
LED 發(fā)射燈、顯示模塊、24V 電源等模塊組成。該部分實(shí)現(xiàn)了對(duì)兩路語音信號(hào)和 m 序列的調(diào)制 并通過可見光發(fā)射給接收端的任務(wù)。
接收端由放大濾波電路、音頻信號(hào)功率放大電路、整形電路、音頻解調(diào)電路、PIIN 光電 二極管等模塊組成。該部分實(shí)現(xiàn)了來自發(fā)送端信號(hào)的解調(diào)、放大和語音輸出,以及完成來自 m 序列發(fā)生器的波形輸出的任務(wù)。
總系統(tǒng)框圖如下:
2018-2-28 04:27 上傳
2018-2-28 04:28 上傳
2 、方案設(shè)計(jì)與選擇
2.1 CPU 的選擇
方案一:采用 51 系列單片機(jī)。采用現(xiàn)在比較通用的 51 系列單片機(jī)作為整個(gè)系統(tǒng)方案的 主控 CPU。51 系列單片機(jī)應(yīng)用比較廣泛,各種技術(shù)都比較成熟,但此系列單片機(jī)是 8 位機(jī), 處理速度不是很快,I/O 端口較少,資源不夠充足。
方案二:采用 MSP430 系列單片機(jī)。TI 公司的 MSP430 系列單片機(jī)是一種 16 位超低功耗 的混合信號(hào)處理器,采用了精簡指令集(RISC)結(jié)構(gòu),具有豐富的尋址方式(7 種源操作數(shù) 尋址、4 種目的操作數(shù)尋址)、簡潔的 27 條內(nèi)核指令以及大量的模擬指令;大量的寄存器以 及片內(nèi)數(shù)據(jù)存儲(chǔ)器都可參加多種運(yùn)算;還有高效的查表處理指令;有較高的處理速度;接口 方便開發(fā);而且 MSP430 系列單片機(jī)的中斷源較多,并且可以任意嵌套,使用時(shí)靈活方便, 滿足當(dāng)前低碳經(jīng)濟(jì)的要求。
綜合以上方案,我們采用 TI 公司的 MSP430 系列單片機(jī),選擇方案二。
2.2 鎖相環(huán)的選擇
方案一:采用 CD4046 連成語音信號(hào)的收發(fā)電路。CD4046 是通用的 CMOS 鎖相環(huán)集成電路, 采用 16 腳雙列直插式封裝,其特點(diǎn)是電源電壓范圍寬(為 3V—18V),輸入阻抗高(約為
100MΩ),動(dòng)態(tài)功耗小,在中心頻率 f0 為 10KHz 下功耗僅為 600 μW,屬微功耗器件。 方案二:采用 LM567 連成語音信號(hào)的收發(fā)電路。LM567 是一塊鎖相環(huán)集成電路,采用雙列
直插式封裝。其靜態(tài)電流 8mA,最高工作頻率 500KHz,其中心工作頻率 f0 由 5 腳和 6 腳外
接定時(shí)電阻電容決定。其計(jì)算公式 f0 1 / (1.1RC ) 。另外 LM567 還具有抗光電干擾性能好, 接收角度寬、低功耗、靈敏度高的優(yōu)點(diǎn)。
綜合以上方案,我們采用 LM567,選擇方案二。
2.3 光調(diào)制中放大器件的選擇
方案一:采用 LM317 線性放大器件。LM317 除了有穩(wěn)壓功能外還有線性放大功能,它的 輸出電壓范圍是 1.2V 至 37V,負(fù)載電流最大為 1.5A。但是 LM317 效率不高,調(diào)制頻率不夠高 且發(fā)熱相當(dāng)嚴(yán)重,致使放大效果及其不佳。
方案二:采用 TIP41C 器件。TIP141C 放大倍數(shù)達(dá)到 65,頻率轉(zhuǎn)換達(dá)到 3MHZ,不僅能使音 頻信號(hào)放大還能放大功率。 與 LM317 做放大器件相比來說,性價(jià)比高。
綜合以上方案,我們采用 TIP41C 器件,選擇方案二。
2.4 顯示模塊的選擇
方案一:采用 1602 液晶屏顯示。液晶顯示屏具有微耗低,但是 1602 沒有字庫只能顯示 字母和數(shù)字,且屏幕過小以致于顯示的內(nèi)容太少,不能同步顯示大容量的信息,若多次切換 顯示會(huì)導(dǎo)致時(shí)間浪費(fèi)。
方案二:采用帶字庫的 12864 液晶屏顯示。12864 顯示分辨率為 128×64,內(nèi)置 8192 個(gè) 16*16
點(diǎn)漢字,和 128 個(gè) 16*8 點(diǎn) ASCII 字符集.利用該模塊靈活的接口方式和簡單、方便的操作指 令,可構(gòu)成全中文人機(jī)交互圖形界面。不僅可以顯示數(shù)字、字母和漢字還能顯示圖形,且低 功耗是其一大特點(diǎn)。
綜合以上方案,我們采用 12864,選擇方案二。
3.1 可見光通信裝置電源模塊
電源電路的任務(wù)是為可見光通信裝置提供電壓。該模塊將 220V 的市電轉(zhuǎn)化為 24V 的輸出 電壓和 1A 的輸出電流。電源電路如下:
2018-2-28 04:29 上傳
工作原理:220V 市電經(jīng)整流橋?qū)⒔涣麟娦盘?hào)轉(zhuǎn)化為直流電信號(hào),經(jīng)電容濾波減少信號(hào)波 動(dòng),LM317 的穩(wěn)壓范圍是 1.25~37V,最終輸出 24V 電壓,電流為 1A。
3.2 可見光通信裝置發(fā)送端
3.2.1 信號(hào)調(diào)制電路
信號(hào)調(diào)制電路的有兩個(gè)任務(wù),一是接收語音信號(hào)及 M 序列信號(hào),并將其轉(zhuǎn)化為電信號(hào), 二是通過光調(diào)制電路進(jìn)行信號(hào)調(diào)制,由白光 LED 發(fā)光管將信號(hào)發(fā)送給接收端的 PIN 光電二極 管。信號(hào)調(diào)制電路原理圖如下:
2018-2-28 04:30 上傳
圖 3 信號(hào)調(diào)制電路
電路工作原理:A 路語音信號(hào)從 A singnal 端口,經(jīng) RP1 衰減由 Ca1 緩沖經(jīng) Qa1、Qa2 放 大后從 C 端輸入與其他兩路信號(hào)混合。B 路語音信號(hào)從 B singnal 端口輸入,經(jīng) RP2 衰減后 由 Cb1、Qb1 緩沖放大后從 Qb1 的發(fā)射極取出后經(jīng)壓控振蕩器,D1、D2 對(duì)信號(hào)進(jìn)行限幅。然 后進(jìn)入 LM567 可對(duì) PLL 的頻率進(jìn)行調(diào)制,當(dāng)音頻信號(hào)處于上升段時(shí),調(diào)制頻率受壓控振蕩器
(LM567 的 2 腳)控制,在壓控振蕩器中心工作頻率的基礎(chǔ)上增加,當(dāng)音頻信號(hào)處于下降段 時(shí),調(diào)制頻率受壓控振蕩器(LM567 的 2 腳)控制,在壓控振蕩器中心頻率的基礎(chǔ)上降低, 從而實(shí)現(xiàn)頻率調(diào)制。由于采用了鎖相環(huán)壓控振蕩器,所以電路的調(diào)制線性較好。調(diào)制后的信 號(hào)經(jīng) LM567 的 5 腳出,三路信號(hào)在 C 端混合,由光調(diào)制電路后經(jīng) Q2 放大后推動(dòng) LED 發(fā)送可見 光。m 序列信號(hào)由 MSP430F149 輸入,其他部分與 B 路語音信號(hào)相同,在接收端由示波器顯示 信息。
3. 3 可見光通信裝置接收端
3.3.1 信號(hào)解調(diào)放大電路
信號(hào)解調(diào)電路的任務(wù)是利用 PIN 光電二極管接收來自發(fā)送端的可見光線,經(jīng)音頻鎖相環(huán) 解調(diào)和 LM386 放大功率后語音信號(hào)由揚(yáng)聲器發(fā)出,m 序列信號(hào)則由示波器顯示。信號(hào)解調(diào)放 大電路如下:
2018-2-28 04:31 上傳
圖4.1 B路信號(hào)和 m 序列信號(hào)接收電路
2018-2-28 04:31 上傳
圖 4.2 A路信號(hào)接收電路
電路工作原理:可見光光信號(hào)由 LED2 接收,經(jīng)放大濾波電路后,A 路語音信號(hào)經(jīng)單 管放大電路放大,由 LM386 進(jìn)行功率放大后由揚(yáng)聲器發(fā)聲,而 B 路語音信號(hào)和 M 序列信號(hào)則 進(jìn)入 LM567 解調(diào),信號(hào)解調(diào)后,B 路語音信號(hào)由 LM386 放大功率又揚(yáng)聲器發(fā),對(duì)于 M 序列信 號(hào)則由示波器顯示信號(hào)。
TI 公司研發(fā)的 430 系列單片機(jī)功耗極低,應(yīng)用 MSP430F149 可實(shí)現(xiàn)通信裝置功能的實(shí)現(xiàn)。 系統(tǒng)軟件設(shè)計(jì)的整體思路:使用 MSP430F149 在發(fā)送端產(chǎn)生 M 序列,通過 LM567 和光調(diào)制電路 由發(fā)光管發(fā)送,在接收端由示波器觀測,同時(shí)采集發(fā)光管 LED 的溫度,若當(dāng)前溫度過高不利 于通信則報(bào)警提示,應(yīng)用芯片自帶的 ADC12 采集 LED 兩端的電壓,通過按鍵可調(diào)當(dāng)前時(shí)間, 并且記錄發(fā)送的語音信息的時(shí)間,以上信息通過 12864 顯示,另外在液晶屏上也可顯示本隊(duì) 詳細(xì)信息。
2018-2-28 04:32 上傳
2018-2-28 04:32 上傳
2018-2-28 04:33 上傳
2018-2-28 04:33 上傳
5.2 各模塊測試
5.2.1 語音傳輸模塊測試 為了在調(diào)試電路的過程中更方便的調(diào)整電路參數(shù),在測試語音信號(hào)之前先進(jìn)行音頻范圍
內(nèi)不同頻率的正弦波的測試。然后,我們分別通過 MP3、麥克向輸入端輸入聲音信號(hào),通過 揚(yáng)聲器實(shí)際觀測其失真情況。
在使用正弦波測試時(shí),首先使用函數(shù)信號(hào)發(fā)生器向發(fā)送端輸入不同頻率的正弦波信號(hào),然 后用示波器檢測接收端分別接收到的波形,檢測輸出電壓的幅值,發(fā)現(xiàn)當(dāng)發(fā)射端輸入語音信 號(hào)為 300Hz、1000Hz、8000Hz 單音信號(hào)時(shí),在 8Ω 電阻負(fù)載上,接收裝置的輸出電壓有效值 大于 0.4V,并且在更高的頻率上也能達(dá)到 0.4V。不改變電路原有狀態(tài),減小發(fā)射端輸入信號(hào) 的幅度至 0V,采用低頻毫伏表測量此時(shí)接收端輸出端噪聲電壓,讀數(shù)基本維持在 0V。檢測結(jié) 果表明輸出電壓能夠超過題目所要求的電壓。將它與輸入波形進(jìn)行比對(duì),發(fā)現(xiàn)波形無明顯失 真。
在使用MP3、麥克向輸入端輸入聲音信號(hào)時(shí),通過揚(yáng)聲器實(shí)際體驗(yàn)該設(shè)備的性能指標(biāo),聲 音清晰度良好,基本無失真。通過對(duì)MP3輸出波形和接收端輸出波形對(duì)比,也沒有明顯失真之 處。
2018-2-28 04:33 上傳
5.2.2 模擬信號(hào)傳輸測試
在 A 路傳輸 2000Hz、B 路傳輸 8000Hz 單音信號(hào)時(shí),在 8Ω負(fù)載上,A 路、B 路的輸出電 壓有效值均不小于 0.4V。A 路、B 路分別輸入 1000Hz 頻率以下的方波、鋸齒波時(shí),在接收裝 置的 8Ω負(fù)載上,A 路、B 路的輸出電壓有效值均不小于 0.4V,甚至在更低頻率下,也能保持 不小于 0.4V 的水平。
將 m 序列信號(hào)加于 A 路的輸入端,用示波器觀察發(fā)端設(shè)備的輸入波形以及收端設(shè)備的輸 出波形,沒有出現(xiàn)無明顯的碼間串?dāng)_。
5.2.3 LED 照明模塊測試
在 10W 白光 LED 只用于照明的情況下,滿足 I2=1±0.01A 的前提下,由 24 V 電源的供電 電流 I1 約為 1.12A
5.2.4 電源模塊測試
接通電路后,在測試點(diǎn)處用萬用表對(duì)電源電壓和電流進(jìn)行測量,兩者均滿足題目要求, 且無明顯波動(dòng),非常穩(wěn)定。
6、總結(jié)
本系統(tǒng)設(shè)計(jì)以 TI 公司的 MSP430F149 為主控芯片,完成了基于大功率白光 LED 的可見光 通信,實(shí)現(xiàn)了對(duì)兩路語音信號(hào)和 M 序列的無失真?zhèn)鬏,并且?yīng)用該芯片采集 LED 發(fā)光管的溫 度和其兩端的電壓,并且記錄發(fā)送信息等。在設(shè)計(jì)中,我們既考慮了系統(tǒng)的功耗,又充分發(fā) 揮了系統(tǒng)中芯片的高性能。通過測試,系統(tǒng)不但完成了題目要求,而且還擴(kuò)展了相應(yīng)功能。 經(jīng)過幾天不斷的改進(jìn)程序和電路,一點(diǎn)點(diǎn)的攻克難關(guān),最終很好的完成了設(shè)計(jì),在比賽過程 中,首先要感謝指導(dǎo)老師對(duì)我們的幫助和指導(dǎo),也要感謝我們的隊(duì)員,有了他們,我們才能 更好的完成設(shè)計(jì)。對(duì)自身能力來說也是一種質(zhì)的提高,也充分體現(xiàn)了團(tuán)隊(duì)合作的重要性。在 以后的學(xué)習(xí)和生活中我們還需繼續(xù)努力,不斷學(xué)習(xí),不斷改善自己,以創(chuàng)造更好的成績。
單片機(jī)源程序如下:
- #include "control.h"
- #include "key.h"
- #include "LCD12864.h"
- #include "ADC12.h"
- #include "DS18B20.h"
- unsigned char mark=1;
- extern unsigned char flag;
- unsigned char sign=0;
- void control()
- Settime();
- ADC12CTL0 |=ENC;
- ADC12CTL0 |=ADC12SC;
- while(1)
- wait();
- system_info1();
- if(flag==0)
- system_info2();
- if(mark==0&&flag==0)
- system_info2();
- void wait()
- while(1)
- Key4Scan();
- if(key!=0)
- flag=0;
- LCD_clear();
- break;
- void system_info1()
- LCD_write_str(2,1,"系統(tǒng)信息");
- LCD_write_str(0,2,"1.電壓:");
- LCD_write_str(0,3,"2.電流:");
- LCD_write_str(0,4,"3.LED");
- LCD_write_str(4,3,"1A");
- LCD_write_str(3,4,"溫度:");
- while(1)
- sign=1;
- LCD_write_str(4,2,tempda);
- LCD_show_T();
- ADC12CTL0 |=ENC;
- Key4Scan();
- if(key==3)
- { flag=0;
- LCD_clear();
- sign=0;
- break;
- else if(key==4)
- { sign=0;
- flag=1;
- break;
- void system_info2()
- mark=1;
- LCD_clear();
- LCD_write_str(0,2,"1.系統(tǒng)時(shí)間");
- LCD_write_str(0,3,"2.序列信息");
- LCD_write_str(0,4,"3.音頻傳送記錄");
- while(1)
- Key4Scan();
- if(key==1)
- { mark=0;
- flag=0;
- LCD_clear();
- timeshow();
- else if(key==2)
- mark=0;
- flag=0;
- LCD_clear();
- LCD_write_str(1,1,"m");
- LCD_write_str(2,1,"序列為:");
- LCD_write_str(0,2,"000111101011001");
- else if(key==3)
- mark=0;
- flag=0;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
2018-2-28 04:36 上傳
論文:
2014省賽A題論文.pdf
(337.07 KB, 下載次數(shù): 112)
2018-2-27 18:49 上傳
點(diǎn)擊文件名下載附件
論文 下載積分: 黑幣 -5
源碼:
2014電賽程序.zip
(404.39 KB, 下載次數(shù): 100)
2018-2-27 18:49 上傳
點(diǎn)擊文件名下載附件
程序 下載積分: 黑幣 -5
