查看: 3629|回復: 2
MAX7219級聯的單片機驅動程序
ID:284600 發表于 2018-2-21 14:24 | 顯示全部樓層 |閱讀模式
網上找來的,大家共享!MAX7219級聯程序和驅動程序
  1. //單片機晶振12M
  2. //顯示0-9中國
  3. #include <reg52.h>
  4. #include <intrins.h>
  5. #define uchar unsigned char
  6. #define uint  unsigned int
  7. #define count 20           //級聯個數
  8. //定義Max7219端口
  9. sbit Max7219_pinCLK = P2^2;
  10. sbit Max7219_pinCS  = P2^1;
  11. sbit Max7219_pinDIN = P2^0;
  12. uchar code disp1[20][8]=
  13. {
  14. {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0
  15. {0x10,0x30,0x50,0x10,0x10,0x10,0x10,0x38},//1
  16. {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2
  17. {0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3
  18. {0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x00},//4
  19. {0x0,0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C},//5
  20. {0x0,0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C},//6
  21. {0x0,0x3E,0x22,0x4, 0x8, 0x8, 0x8, 0x8},//7
  22. {0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8
  23. {0x3E,0x22,0x22,0x3E,0x2,0x2,0x3E,0x00},//9
  24. {0x0,0x8,0x14,0x22,0x3E,0x22,0x22,0x22},//A
  25. {0x0,0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C},//B
  26. {0x0,0x3C,0x40,0x40,0x40,0x40,0x40,0x3C},//C
  27. {0x0,0x7C,0x42,0x42,0x42,0x42,0x42,0x7C},//D
  28. {0x7C,0x40,0x40,0x7C,0x40,0x40,0x7c,0x00},//E
  29. {0x00,0x7C,0x40,0x40,0x7C,0x40,0x40,0x40},//F
  30. {0x00,0x3C,0x40,0x40,0x40,0x44,0x44,0x3C},//G
  31. {0x00,0x44,0x44,0x44,0x7C,0x44,0x44,0x44},//H
  32. {0x00,0x10,0xFE,0x92,0x92,0xFE,0x10,0x10},//中
  33. {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//國
  34. };
  35. void Delay_xms(uint x);
  36. void Write_Max7219_byte(uchar DATA);//寫入一字節
  37. void Write_Max7219(uchar address1,uchar dat1,uchar address2,uchar dat2);
  38. void Init_MAX7219(void);
  39.                       // 鎖存進相應寄存器
  40. void main(void)
  41. {
  42. uchar i,j;
  43. Delay_xms(50);
  44. Init_MAX7219();
  45. while(1)
  46. {
  47.   // for(i=1;i<9;i++)
  48. //   Write_Max7219(i,disp1[1][i-1],i,disp1[0][i-1]);
  49.    for(i=1;i<9;i++)
  50.    {
  51.
  52. //  Write_Max7219(i,disp1[1][i-1],i,disp1[0][i-1]);
  53.     Max7219_pinCS=0;
  54.     for(j=0;j<count;j++)
  55.     {
  56.         Write_Max7219_byte(i);           //寫入地址,即數碼管編號
  57.         Write_Max7219_byte(disp1[count-1-j][i-1]);              //寫入數據,即數碼管顯示數字
  58.                 _nop_();
  59.      }
  60.      Max7219_pinCS=1;
  61.    }
  62.    Delay_xms(1000);
  63.
  64. }
  65. }
  66. void Init_MAX7219(void)
  67. {
  68. /*   Write_Max7219(0x09, 0x00,0x09, 0x00);       //譯碼方式:BCD碼
  69.   Write_Max7219(0x0a, 0x03,0x0a, 0x03);       //亮度
  70.   Write_Max7219(0x0b, 0x07,0x0b, 0x07);       //掃描界限;8個數碼管顯示
  71.   Write_Max7219(0x0c, 0x01,0x0c, 0x01);       //掉電模式:0,普通模式:1
  72.   Write_Max7219(0x0f, 0x00,0x0f, 0x00);       //顯示測試:1;測試結束,正常顯示:0
  73.   */
  74. uchar  i;
  75.   Max7219_pinCS=0;
  76.   for(i=0;i<count;i++)
  77.   {
  78.     Write_Max7219_byte(0x09); //譯碼方式:BCD碼
  79.     Write_Max7219_byte(0x00);
  80.   }
  81.   Max7219_pinCS=1;
  82.   _nop_();
  83.   Max7219_pinCS=0;
  84.   for(i=0;i<count;i++)
  85.   {
  86.     Write_Max7219_byte(0x0a); //亮度
  87.     Write_Max7219_byte(0x03);
  88.   }
  89.   Max7219_pinCS=1;
  90. _nop_();
  91.    Max7219_pinCS=0;
  92.   for(i=0;i<count;i++)
  93.   {
  94.     Write_Max7219_byte(0x0b); // //掃描界限;8個數碼管顯示
  95.     Write_Max7219_byte(0x07);
  96.   }
  97.   Max7219_pinCS=1;
  98.   _nop_();
  99.   Max7219_pinCS=0;
  100.   for(i=0;i<count;i++)
  101.   {
  102.     Write_Max7219_byte(0x0c); //   //掉電模式:0,普通模式:1
  103.     Write_Max7219_byte(0x01);
  104.   }
  105.   Max7219_pinCS=1;
  106.   Max7219_pinCS=0;
  107.   for(i=0;i<count;i++)
  108.   {
  109.     Write_Max7219_byte(0x0f); //顯示測試:1;測試結束,正常顯示:0
  110.     Write_Max7219_byte(0x00);
  111.   }
  112.   Max7219_pinCS=1;
  113.   _nop_();
  114. }
  115. void Write_Max7219(uchar address1,uchar dat1,uchar address2,uchar dat2)
  116. {
  117.      uchar i;
  118.      Max7219_pinCS=0;
  119.      Write_Max7219_byte(address1);           //寫入地址,即數碼管編號
  120.      Write_Max7219_byte(dat1);              //寫入數據,即數碼管顯示數字
  121.      Write_Max7219_byte(address2);           //寫入地址,即數碼管編號
  122.      Write_Max7219_byte(dat2);      //寫入數據,即數碼管顯示數字
  123.               _nop_();
  124.
  125.      Max7219_pinCS=1;
  126. }
  127. //--------------------------------------------
  128. //功能:向MAX7219(U3)寫入字節
  129. //入口參數:DATA
  130. //出口參數:無
  131. //說明:
  132. void Write_Max7219_byte(uchar DATA)
  133. {
  134.             uchar i;
  135.             for(i=8;i>=1;i--)
  136.           {
  137.             Max7219_pinCLK=0;
  138.             Max7219_pinDIN=DATA&0x80;
  139.             DATA=DATA<<1;
  140.             Max7219_pinCLK=1;
  141.            }
  142. }
  143. void Delay_xms(uint x)
  144. {
  145. uint i,j;
  146. for(i=0;i<x;i++)
  147.   for(j=0;j<112;j++);
  148. }
級聯程序和MAX7219驅動程序.zip (58.27 KB, 下載次數: 66)
ID:367948 發表于 2019-2-28 13:43 | 顯示全部樓層
謝謝,下來學習
ID:574634 發表于 2019-8-5 22:57 | 顯示全部樓層
一直在找16片MAX7219的級聯參考,太感謝了。
