stm32GPS源碼,可以在上位機上顯示
- #include "sys.h"
- #include "delay.h"
- #include "usart.h"
- #include "led.h"
- #include "lcd.h"
- #include "usmart.h"
- #include "gps.h"
- #include "usart3.h"
- #include "key.h"
- #include "string.h"
- //ALIENTEK 戰艦V3/精英開發板擴展實驗16
- //ATK-S1216F8 GPS模塊測試實驗
- u8 USART1_TX_BUF[USART3_MAX_RECV_LEN]; //串口1,發送緩存區
- nmea_msg gpsx; //GPS信息
- __align(4) u8 dtbuf[50]; //打印緩存器
- const u8*fixmode_tbl[4]={"Fail","Fail"," 2D "," 3D "}; //fix mode字符串
- //顯示GPS定位信息
- void Gps_Msg_Show(void)
- float tp;
- POINT_COLOR=BLUE;
- tp=gpsx.longitude;
- sprintf((char *)dtbuf,"Longitude:%.5f %1c ",tp/=100000,gpsx.ewhemi); //得到經度字符串
- LCD_ShowString(30,120,200,16,16,dtbuf);
- tp=gpsx.latitude;
- sprintf((char *)dtbuf,"Latitude:%.5f %1c ",tp/=100000,gpsx.nshemi); //得到緯度字符串
- LCD_ShowString(30,140,200,16,16,dtbuf);
- tp=gpsx.altitude;
- sprintf((char *)dtbuf,"Altitude:%.1fm ",tp/=10); //得到高度字符串
- LCD_ShowString(30,160,200,16,16,dtbuf);
- tp=gpsx.speed;
- sprintf((char *)dtbuf,"Speed:%.3fkm/h ",tp/=1000); //得到速度字符串
- LCD_ShowString(30,180,200,16,16,dtbuf);
- if(gpsx.fixmode<=3) //定位狀態
- sprintf((char *)dtbuf,"Fix Mode:%s",fixmode_tbl[gpsx.fixmode]);
- LCD_ShowString(30,200,200,16,16,dtbuf);
- sprintf((char *)dtbuf,"GPS+BD Valid satellite:%02d",gpsx.posslnum); //用于定位的GPS衛星數
- LCD_ShowString(30,220,200,16,16,dtbuf);
- sprintf((char *)dtbuf,"GPS Visible satellite:%02d",gpsx.svnum%100); //可見GPS衛星數
- LCD_ShowString(30,240,200,16,16,dtbuf);
- sprintf((char *)dtbuf,"BD Visible satellite:%02d",gpsx.beidou_svnum%100); //可見北斗衛星數
- LCD_ShowString(30,260,200,16,16,dtbuf);
- sprintf((char *)dtbuf,"UTC Date:%04d/%02d/%02d ",gpsx.utc.year,gpsx.utc.month,gpsx.utc.date); //顯示UTC日期
- LCD_ShowString(30,280,200,16,16,dtbuf);
- sprintf((char *)dtbuf,"UTC Time:%02d:%02d:%02d ",gpsx.utc.hour,gpsx.utc.min,gpsx.utc.sec); //顯示UTC時間
- LCD_ShowString(30,300,200,16,16,dtbuf);
- int main(void)
- u16 i,rxlen;
- u16 lenx;
- u8 key=0XFF;
- u8 upload=0;
- delay_init(); //延時函數初始化
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設置中斷優先級分組為組2:2位搶占優先級,2位響應優先級
- uart_init(115200); //串口初始化為115200
- usmart_dev.init(72); //初始化USMART
- LED_Init(); //初始化與LED連接的硬件接口
- KEY_Init(); //初始化按鍵
- LCD_Init(); //初始化LCD
- usart3_init(38400); //初始化串口3
- POINT_COLOR=RED;
- LCD_ShowString(30,20,200,16,16,"ALIENTEK STM32F1 ^_^");
- LCD_ShowString(30,40,200,16,16,"S1216F8 GPS TEST");
- LCD_ShowString(30,60,200,16,16,"ATOM@ALIENTEK");
- LCD_ShowString(30,80,200,16,16,"KEY0:Upload NMEA Data SW");
- LCD_ShowString(30,100,200,16,16,"NMEA Data Upload:OFF");
- if(SkyTra_Cfg_Rate(5)!=0) //設置定位信息更新速度為5Hz,順便判斷GPS模塊是否在位.
- LCD_ShowString(30,120,200,16,16,"SkyTraF8-BD Setting...");
- do
- usart3_init(9600); //初始化串口3波特率為9600
- SkyTra_Cfg_Prt(3); //重新設置模塊的波特率為38400
- usart3_init(38400); //初始化串口3波特率為38400
- key=SkyTra_Cfg_Tp(100000); //脈沖寬度為100ms
- }while(SkyTra_Cfg_Rate(5)!=0&&key!=0);//配置SkyTraF8-BD的更新速率為5Hz
- LCD_ShowString(30,120,200,16,16,"SkyTraF8-BD Set Done!!");
- delay_ms(500);
- LCD_Fill(30,120,30+200,120+16,WHITE);//清除顯示
- while(1)
- delay_ms(1);
- if(USART3_RX_STA&0X8000) //接收到一次數據了
- rxlen=USART3_RX_STA&0X7FFF; //得到數據長度
- for(i=0;i<rxlen;i++)USART1_TX_BUF[i]=USART3_RX_BUF[i];
- USART3_RX_STA=0; //啟動下一次接收
- USART1_TX_BUF[i]=0; //自動添加結束符
- GPS_Analysis(&gpsx,(u8*)USART1_TX_BUF);//分析字符串
- Gps_Msg_Show(); //顯示信息
- if(upload)printf("\r\n%s\r\n",USART1_TX_BUF);//發送接收到的數據到串口1
- key=KEY_Scan(0);
- if(key==KEY0_PRES)
- upload=!upload;
- POINT_COLOR=RED;
- if(upload)LCD_ShowString(30,100,200,16,16,"NMEA Data Upload:ON ");
- else LCD_ShowString(30,100,200,16,16,"NMEA Data Upload:OFF");
- if((lenx%500)==0)
- LED0=!LED0;
- lenx++;
(庫函數版本,適合戰艦V3和精英STM32開發板)擴展實驗16 ATK-S1216F8 GPS模塊實驗.rar
(398.26 KB, 下載次數: 32)
2018-2-21 10:01 上傳
stm32GPS源碼
