查看: 6046|回復: 2
基于STC89C52單片機的紅外線遙小車實現源碼
ID:280773 發(fā)表于 2018-2-12 09:40 | 顯示全部樓層 |閱讀模式
基于STC89C52單片機的小車實現
責任描述:
一、完成小車的原理設計和焊接。
二、用Keil4編寫單片機實現了五個功能:1.紅外線遙控前進后退轉彎功能。2.小車地面尋跡功能。3.超聲波感應避障功能。4.光敏感應行走功能。
ps:最后有文檔源代碼。
下載:
源代碼.docx (14.22 KB, 下載次數: 21)
單片機源程序:
  1. #include <REGX52.H>
  2. #include <intrins.h>
  3. sbit LeftLed=P2^0;
  4. sbit RightLed=P0^7;
  5. sbit FontLled=P1^7;
  6. sbit LeftIR=P3^5;
  7. sbit RightIR=P3^6;
  8. sbit FontIR=P3^7;
  9. sbit M1A=P0^0;
  10. sbit M1B=P0^1;
  11. sbit M2A=P0^2;
  12. sbit M2B=P0^3;
  13. sbit B1=P0^4;
  14. sbit SB1=P0^6;
  15. sbit IRIN=P3^3;
  16. unsigned char code  LedShowData[]={0x03,0x9F,0x25,0x0D,0x99,
  17.                                    0x49,0x41,0x1F,0x01,0x19};//0,1,2,3,4,5,6,7,8,9
  18. unsigned char code  RecvData[]={0x19,0x46,0x15,0x43,0x44,0x40,0x0D,0x0E,0x00,0x0F};
  19. unsigned char IRCOM[7];
  20. static unsigned int LedFlash;
  21. bit EnableLight=0;
  22. #define ShowPort P2
  23. unsigned char temp = 1;
  24. void tingzhi()
  25. {
  26.    M1A=0;
  27.    M1B=0;
  28.    M2A=0;
  29.    M2B=0;
  30. }
  31. void qianjin()
  32. {
  33.    M1A=1;
  34.    M1B=0;
  35.    M2A=1;
  36.    M2B=0;
  37. }
  38. void houtui()
  39. {
  40.    M1A=0;
  41.    M1B=1;
  42.    M2A=0;
  43.    M2B=1;
  44. }
  45. void zuozhuan()
  46. {
  47.    M1A=0;
  48.    M1B=1;
  49.    M2A=1;
  50.    M2B=0;
  51. }
  52. void youzhuan()
  53. {
  54.    M1A=1;
  55.    M1B=0;
  56.    M2A=0;
  57.    M2B=1;
  58. }
  59. void Delay1ms(unsigned int i)
  60. {
  61. unsigned char j,k;
  62. do{
  63.   j = 10;
  64.   do{
  65.    k = 50;
  66.    do{
  67.     _nop_();
  68.    }while(--k);
  69.   }while(--j);
  70. }while(--i);
  71. }
  72. void delay_nus(unsigned int i)
  73. {
  74.   i=i/10;
  75.   while(--i);
  76. }
  77. void delay_nms(unsigned int n)
  78. {
  79.   n=n+1;
  80.   while(--n)
  81.   delay_nus(900);
  82.
  83. }
  84. void delayms(unsigned char x)
  85. {
  86.   unsigned char i;
  87.   while(x--)
  88.   {
  89.     for (i = 0; i<13; i++) {}
  90.   }
  91. }
  92. void Delay()
  93. {
  94.   unsigned int DelayTime=30000;
  95.   while(DelayTime--);
  96.   return;
  97. }
  98. void ControlCar(unsigned char ConType)
  99. {
  100.   tingzhi();
  101. switch(ConType)
  102. {
  103.   case 1:  //前進
  104.   {
  105.     //tingzhi();
  106.         //Delay1ms(50);
  107.         LeftLed = 0 ;
  108.         qianjin();
  109.     break;
  110.   }
  111.   case 2: //后退
  112.   {
  113.    // tingzhi();
  114.    // Delay1ms(50);
  115.     LeftLed = 1 ;
  116.         houtui();
  117.     break;
  118.   }
  119.   case 3: //左轉
  120.   {
  121.      //tingzhi();
  122.         // Delay1ms(50);
  123.          zuozhuan();
  124.          break;
  125.   }
  126.   case 4: //右轉
  127.   {
  128.    // tingzhi();
  129. //        Delay1ms(50);
  130.         youzhuan();
  131.
  132.         break;
  133.   }
  134.   case 8: //停止
  135.   {
  136.     tingzhi();
  137.         break;
  138.   }
  139. }
  140. }
  141. void ControlCar_yaokong(unsigned char ConType)
  142. {
  143.   tingzhi();
  144. switch(ConType)
  145. {
  146.   case 1:  //前進
  147.   {
  148.     tingzhi();
  149.         Delay1ms(150);
  150.         LeftLed = 0 ;
  151.         qianjin();
  152.     break;
  153.   }
  154.   case 2: //后退
  155.   {
  156.     tingzhi();
  157.     Delay1ms(150);
  158.     LeftLed = 1 ;
  159.         houtui();
  160.     break;
  161.   }
  162.   case 3: //左轉
  163.   {
  164.      tingzhi();
  165.          Delay1ms(150);
  166.          zuozhuan();
  167.          break;
  168.   }
  169.   case 4: //右轉
  170.   {
  171.      tingzhi();
  172.          Delay1ms(150);
  173.      youzhuan();
  174.           break;
  175.   }
  176.   case 8: //停止
  177.   {
  178.     tingzhi();
  179.         break;
  180.   }
  181. }
  182. }
  183. void Robot_Avoidance()
  184. {
  185.    LeftLed=LeftIR;
  186.    RightLed=RightIR;
  187.    FontLled= FontIR;
  188.    SB1=FontIR;
  189.     if(FontIR == 0)
  190.    {
  191.       ControlCar(8);
  192.       delay_nms (300);
  193.           ControlCar(2);
  194.           delay_nms (1000);
  195.           ControlCar(3);
  196.           delay_nms (1800);
  197.   }
  198.    else
  199.    {
  200.       ControlCar(1);
  201.       delay_nms (10);
  202.    }
  203.     ControlCar(1);
  204. }
  205. //機器人循跡子程序
  206. void Robot_Traction()
  207. {
  208.    LeftLed=LeftIR;
  209.    RightLed=RightIR;
  210.    FontLled= FontIR;
  211.    SB1=LeftIR;
  212.    if(LeftIR == 0 && RightIR == 0)
  213.    {
  214.       ControlCar(1);
  215.       delay_nms (10);
  216.    }
  217.
  218.    else if(LeftIR == 0 && RightIR == 1)
  219.    {
  220.       ControlCar(3);
  221.       delay_nms (10);
  222.    }
  223.    else if(LeftIR == 1 && RightIR == 0)
  224.    {
  225.       ControlCar(4);
  226.       delay_nms (10);
  227.    }
  228.     ControlCar(8);
  229. }
  230. void main()
  231. {
  232.
  233.   bit RunFlag=0;
  234.   LedFlash=3000;
  235.   //EX1=1;
  236.   IT1=1;
  237.   EA=1;
  238.   ControlCar(8);
  239.   while(1)
  240.   {
  241.              if(P3_2 == 0)
  242.           {
  243.            delay_nms(10);
  244.            if(P3_2 == 0)
  245.            {
  246.                      temp++;
  247.                   while(!P3_2);
  248.            }
  249.           }
  250.           if(temp > 3)
  251.           {
  252.           temp = 1;
  253.           }
  254.           switch(temp)
  255.           {
  256.                    case 1:        ShowPort = LedShowData[1];Robot_Traction();EX1 = 0;break;
  257.                 case 2: ShowPort = LedShowData[2];Robot_Avoidance();EX1 = 0;break;
  258.                 case 3: ShowPort = LedShowData[3];EX1 = 1;break;
  259.           }
  260.   }
  261. }
  262. //----------紅外遙控-------------------------------------------------------------
  263. void IR_IN() interrupt 2 using 0
  264. {
  265.   unsigned char j,k,N=0;
  266.
  267.   EX1 = 0;
  268.   delayms(15);
  269.   if (IRIN==1)
  270.   {
  271.      EX1 =1;
  272.          return;
  273.   }
  274.
  275.   while (!IRIN)
  276.   {
  277.       delayms(1);
  278.   }
  279.   for (j=0;j<4;j++)
  280.   {
  281.     for (k=0;k<8;k++)
  282.     {
  283.        while (IRIN)
  284.        {
  285.          delayms(1);
  286.        }
  287.
  288.        while (!IRIN)
  289.        {
  290.          delayms(1);
  291.        }
  292.
  293.        while (IRIN)
  294.        {
  295.          delayms(1);
  296.          N++;
  297.          if (N>=30)
  298.              {
  299.            EX1=1;
  300.                return;
  301.          }
  302.        }
  303.
  304.       IRCOM[j]=IRCOM[j] >> 1;
  305.
  306.       if (N>=8)
  307.       {
  308.          IRCOM[j] = IRCOM[j] | 0x80;
  309.       }
  310.       N=0;
  311.     }
  312.   }
  313.
  314.   if (IRCOM[2]!=~IRCOM[3])
  315.   {
  316.      EX1=1;
  317.      return;
  318.   }
  319.   for(j=0;j<10;j++)
  320.    {
  321.       if(IRCOM[2]==RecvData[j])
  322.       {
  323.        // ControlCar(j);
  324.                 ControlCar_yaokong(j);
  325.       }
  326.    }
  327.    EX1 = 1;
  328. }
  329. //-------------------------------------------------------------------------------------------------------
ID:493533 發(fā)表于 2019-4-11 14:57 | 顯示全部樓層
調速的怎么改啊
ID:462827 發(fā)表于 2019-4-12 19:21 | 顯示全部樓層
小車是買成品還是散件自己裝?
