非接芯片驅動程序
N12_SDK_STC_V1.8.0-MH523
- * @file main.c
- * @brief main entry of test.
- * @author
- * INCLUDE FILES
- #include "define.h"
- #include<stdlib.h>
- #include<stdio.h>
- #include<string.h>
- #include "stc_new_8051.h"
- #include "spi.h"
- #include "uart.h"
- #include "timer.h"
- #include "mh523.h"
- #include "rfid.h"
- #include "iso14443_4.h"
- #include "iso14443a.h"
- #define COM_BUF_SIZE 50
- #define HEAD 0x68
- typedef struct r_w_reg_s
- u8 addr;//讀寫的寄存器地址
- u8 rw_dat;//讀寫的寄存器值
- }r_w_reg;
- typedef struct pc_tx_pkt_s
- u8 head;//包頭
- u8 len; //包長:從包頭到校驗和
- u8 cmd; //包命令
- union datu
- r_w_reg reg;
- u8 dat[1];//發(fā)送或接收的數(shù)據(jù)
- }datu;
- }pc_tx_pkt;
- typedef struct lpcd_config_s
- u8 delta;
- u32 t_inactivity_ms;
- u8 skip_times;
- u8 t_detect_us;
- }lpcd_config_t;
- lpcd_config_t XDATA g_lpcd_config;
- static u8 XDATA com_tx_buf[ COM_BUF_SIZE ];//pc to stc
- static u16 tx_buf_index = 0;
- static U8 xdata Snr_RC500[4];
- #if (POWERON_POLLING)
- bit g_query_mode = 1; //手動操作芯片模式
- bit g_typa_poll = TRUE;
- bit g_typb_poll = TRUE;
- bit g_need_reconfig = TRUE;//需要重新初始化PCD的協(xié)議類型
- #else
- bit g_query_mode = 0; //手動操作芯片模式
- bit g_typa_poll = FALSE;
- bit g_typb_poll = FALSE;
- bit g_need_reconfig = FALSE;//需要重新初始化PCD的協(xié)議類型
- #endif
- u32 XDATA g_polling_cnt = 0;
- bit g_lpcd_started = FALSE; //LPCD周期自動探測卡功能是否開啟
- bit g_lpcd_config_test_start = FALSE;//LPCD周期自動探測卡功能是否開啟
- pc_tx_pkt XDATA *recv_packet(void);
- char prase_packet(pc_tx_pkt XDATA *ppkt);
- void discard_pc_pkt(pc_tx_pkt XDATA *ppkt);
- u8 check_sum(u8 XDATA *buf, int len)
- u8 sum = 0;
- while (len--)
- sum += *buf++;
- return sum;
- void make_packet(u8 cmd, u8 *buf, u8 len)
- u8 sum = 0;
- sum += HEAD;
- sendc(HEAD);
- sum += len + 4;
- sendc(len + 4);
- sum += cmd;
- sendc(cmd);
- while (len--)
- sendc(*buf);
- sum += *buf++;
- sendc(sum);
- pc_tx_pkt XDATA * recv_packet(void)
- pc_tx_pkt *XDATA ppkt;
- while(get_bytes() && tx_buf_index < COM_BUF_SIZE )
- com_tx_buf[tx_buf_index] = _getkey() ;
- tx_buf_index++;
- if ( tx_buf_index >= 4 )
- u8 i;
- u8 rest = 4;
- for (i=0; i<tx_buf_index-3; )//
- ppkt = (pc_tx_pkt *)(com_tx_buf + i);
- if (ppkt->head == 0x68 && ppkt->len > 0
- && ppkt->len + i < COM_BUF_SIZE)//判斷是不是能接受完包
- if (ppkt->len + i <= tx_buf_index)//判斷該包有沒有接受完包?
- u8 sum = check_sum((u8 XDATA *)ppkt, ppkt->len - 1);
- if (sum == ppkt->datu.dat[ppkt->len - 4] )
- return ppkt;
- else
- i++;
- else
- rest = tx_buf_index - i;
- break;
- else
- i++;
- memmove(com_tx_buf, com_tx_buf + tx_buf_index - rest, rest);
- tx_buf_index = rest;
- return NULL;
- switch(ppkt->cmd)
- case COM_PKT_CMD_READ_REG: //要求把地址和值都返回給pc
- r_w_reg XDATA reg;
- reg.addr = ppkt->datu.reg.addr;
- reg.rw_dat = read_reg(ppkt->datu.reg.addr);
- make_packet(COM_PKT_CMD_READ_REG, (u8 *)®, sizeof(reg));
- break;
- case COM_PKT_CMD_WRITE_REG:
- write_reg(ppkt->datu.reg.addr, ppkt->datu.reg.rw_dat);
- break;
- case COM_PKT_CMD_QUERY_MODE:
- if (ppkt->datu.dat[0] == 1)
- g_query_mode = TRUE;
- if (ppkt->datu.dat[1] == 1)
- {//typeA poll
- pcd_config('A');
- g_typa_poll = TRUE;
- else
- g_typa_poll = FALSE;
- if (ppkt->datu.dat[2] == 1)
- {//typeB poll
- pcd_config('B');
- g_typb_poll = TRUE;
- else
- g_typb_poll = FALSE;
- if (g_typa_poll && g_typb_poll)
- g_need_reconfig = TRUE;
- else
- g_need_reconfig = FALSE;
- g_polling_cnt = *((u32*)&ppkt->datu.dat[3]);
- printf("g_polling_cnt=%lu\n", g_polling_cnt);
- else
- g_query_mode = FALSE;
- break;
- case COM_PKT_CMD_CHIP_RESET:
- pcd_reset();
- mdelay(7);//carrier off 7ms
- pcd_antenna_on();
- break;
- case COM_PKT_CMD_HALT:
- pcd_hlta();
- printf("HltA\n");
- break;
- case COM_PKT_CMD_LPCD:
- g_lpcd_started = TRUE;
- pcd_lpcd_start();
- break;
- case COM_PKT_CMD_LPCD_CONFIG_TEST:
- int XDATA z;
- memcpy(&g_lpcd_config, &ppkt->datu.dat[0], sizeof(g_lpcd_config));
- for (z = 0; z < sizeof(g_lpcd_config);z++)
- printf(" %02x", ppkt->datu.dat[z]);
- pcd_lpcd_config_start(g_lpcd_config.delta, g_lpcd_config.t_inactivity_ms, g_lpcd_config.skip_times, g_lpcd_config.t_detect_us);
- printf("config=%bd,%lu,%bd,%bd\n",g_lpcd_config.delta, g_lpcd_config.t_inactivity_ms, g_lpcd_config.skip_times, g_lpcd_config.t_detect_us);
- g_lpcd_config_test_start = TRUE;
- break;
- case COM_PKT_CMD_LPCD_CONFIG_TEST_STOP:
- pcd_lpcd_end();
- g_lpcd_config_test_start = FALSE;
- break;
- default:
- return FALSE;
- //break;
- return TRUE;
- int bytes;
- u8 XDATA *p = ((u8 XDATA *)ppkt) + ppkt->len;
- bytes = (p - com_tx_buf);
- if (bytes <= tx_buf_index)
- memmove(com_tx_buf, com_tx_buf + bytes, tx_buf_index - bytes);
- tx_buf_index -= bytes;
- else
- tx_buf_index = 0;
- void main()
- pc_tx_pkt XDATA *ppkt;
- tick XDATA g_statistic_last_t = 0;
- u8 XDATA status;
- //復位鍵下載功能支持代碼
- if((PCON&0x10)==0) //如果POF位=0
- PCON=PCON|0x10; //將POF位置1
- IAP_CONTR=0x60; //軟復位,從ISP監(jiān)控區(qū)啟動
- else
- PCON=PCON&0xef; //將POF位清零
- led_success_on();
- led_fail_on();
- init_uart();
- init_timer0();
- EA = 1;
- init_spi();
- EA = 1;
- printf("NFC_SDK_STC_V%s start...\n", VERSION);
- pcd_init();//初始化pcd寄存器
- rfid_init();//初始化rfid本地變量
- while(1)
- ppkt = recv_packet();
- if (ppkt)
- //檢查是否是調試命令包
- if (FALSE == prase_packet(ppkt))
- //RFID命令包
- rfid_operation(&ppkt->cmd);
- discard_pc_pkt(ppkt);
- //自動輪詢尋卡模式
- if (g_query_mode && (g_typa_poll || g_typb_poll))
- u8 cmd[2];
- u8 status_a = 1, status_b = 1;
- pcd_antenna_off();
- mdelay(10);
- pcd_antenna_on();
- mdelay(10);
- if (g_typa_poll == TRUE)
- if (g_typa_poll & g_typb_poll)
- pcd_config('A');
- cmd[1] = 0x52;
- //pcd_default_info();
- status_a = com_reqa(&cmd);//詢所有A卡
- if (g_typb_poll == TRUE)
- pcd_config('B');
- cmd[1] = 0x08;
- status_b = com_reqb(&cmd);//詢所有B卡
- //點亮對應燈
- if (status_a == MI_OK || status_b == MI_OK)
- led_success_on();//成功
- else
- led_fail_on();//失敗
- //cos指令輪詢操作
- if (g_cos_loop == TRUE)
- if (g_cos_loop_times > 0)
- com_exchange(g_loop_buf);
- g_cos_loop_times--;
- mdelay(20);
- else
- mdelay(200);
- g_cos_loop = FALSE;
- g_statistic_refreshed = TRUE;
- statistic_print();
- make_packet(COM_PKT_CMD_TEST_STOP, NULL, NULL);
- //自動卡檢測
- if (g_lpcd_started == TRUE)
- if (TRUE == pcd_lpcd_check())
- g_lpcd_started = FALSE;
- make_packet(COM_PKT_CMD_LPCD, NULL, NULL);
- //自動卡檢測參數(shù)測試
- if (g_lpcd_config_test_start == TRUE)
- u8 XDATA tag_type[2];
- g_statistics.lpcd_cnt++;
- //驗證是否有卡入場
- pcd_config('A');
- status = pcd_request(0x52, tag_type);
- //剛檢測到卡時可能處于距離邊緣,有可能第一次尋卡失敗,所以增加第二次尋卡驗證
- if (status != MI_OK)
- ///剛檢測到卡時可能處于距離邊緣,如果前兩次尋卡失敗,則第三次尋卡驗證
- if (status == MI_OK)
- {//有卡片入場
- //可添加具體的應用功能代碼
- //等待卡離場,應用代碼中可不必等待離場
- while(1)
- mdelay(10);
- pcd_antenna_on();
- mdelay(10);
- if(status != MI_OK)
- {//一次驗證卡離場
- mdelay(100);
- {//二次驗證卡離場
- mdelay(100);
- {//三次驗證卡離場
- mdelay(100);
- break;
- else
- g_statistics.lpcd_fail++;
- //輸出統(tǒng)計信息
- if (is_timeout(g_statistic_last_t, 100))
- g_statistic_last_t = get_tick();
N12_SDK_STC_V1.8.0-MH523.zip
(191.79 KB, 下載次數(shù): 37)
2018-2-9 20:22 上傳
