買了很久的板子了,一直沒(méi)時(shí)間玩 ,今天搞到03:13,終于靠自己寫出了一個(gè)數(shù)碼顯示程序,他可以在51hei開發(fā)板上輪流顯示數(shù)字和字母. #include<reg52.h>
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code we[]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf};
sbit dula=P2^6;
sbit wela=P2^7;
uchar num,du,num1;
//設(shè)置計(jì)數(shù)器
//選取計(jì)數(shù)方式1
TMOD = 0x11;
//給計(jì)數(shù)器寫初值
TH0 = (65536-10000)/256;
TL0 = (65536-10000)%256;
//操作單片機(jī)
//開啟CPU中斷
EA = 1;
//開啟定時(shí)器T0位中斷
ET0 = 1;
//開啟計(jì)數(shù)器
TR0 = 1;
//操作數(shù)碼管
if(du==100)
du=0;
num++;
if(num<16)
dula=1;
P0=table[num];
dula=0;
if(num==16)
num=0;
if(num1<2)
wela=1;
P0=we[num1];
wela=0;
num1++;
if(num1==2)
num1=0;
//中斷函數(shù)
void time () interrupt 1
//自變量自加
du++;
