#include<reg52.h>
#include "LCD1602.H"
#define u8 unsigned char
#define u16 unsigned int
sbit LED=P2^0;
sbit KEY=P2^1;
bit Time_f=0;
void Timer0_init() //50毫秒@12.000MHz
TMOD|=0x01;
TL0 = (65536-50000)%256; //設置定時初始值
TH0 = (65536-50000)/256; //設置定時初始值
TF0 = 0; //清除TF0標志
TR0 = 1; //定時器0開始計時
ET0=1;
EA=1;
void isr_timer0()interrupt 1 //定時器0中斷服務子函數
Time_f=1;
//50ms調用一次
//短按燈亮,長按燈滅
void KEY_SCAN()
static u8 i=0,c=0;
if(KEY==0)
if(i==0)
if(KEY==0&&c++>=200) //50ms*200=10000ms=10s
i=1;
LED=1; //燈滅
if(c>1&&c<200)
LED=0; //燈亮
i=0;
c=0;
Timer0_init();
if(Time_f)
Time_f=0;
KEY_SCAN();
