查看: 6432|回復(fù): 2
MAX3232芯片引腳圖與pdf資料下載
The MAX3222/MAX3232/MAX3237/MAX3241 trans-ceivers have a proprietary low-dropout transmitter out-put stage enabling true RS-232 performance from a 3.0V to 5.5V supply with a dual charge pump. The devices require only four small 0.1µF external charge-pump capacitors. The MAX3222, MAX3232, and MAX3241 are guaranteed to run at data rates of 120kbps while maintaining RS-232 output levels. The MAX3237 is guaranteed to run at data rates of 250kbps in the normal operating mode and 1Mbps in the MegaBaud™ operating mode, while maintaining RS-232 output levels.
MAX3232引腳圖:
pdf資料下載:
MAX3232.pdf (752.83 KB, 下載次數(shù): 28)
ID:292632 發(fā)表于 2018-4-26 13:19 | 只看該作者
你好,有封裝嗎
ID:613151 發(fā)表于 2019-12-9 23:10 | 只看該作者
我就是來找封裝信息的 這里有不
