查看: 3073|回復: 1
基于STM32 hal庫實現的RTC實時時鐘設計源碼
基于STM32 hal庫實現的RTC實時時鐘設計所有資料51hei提供下載:
RTC.rar (5.06 MB, 下載次數: 37)
  1. /**
  2.   ******************************************************************************
  3.   * File Name          : main.c
  4.   * Description        : Main program body
  5.   ******************************************************************************
  6.   ** This notice applies to any and all portions of this file
  7.   * that are not between comment pairs USER CODE BEGIN and
  8.   * USER CODE END. Other portions of this file, whether
  9.   * inserted by the user or by software development tools
  10.   * are owned by their respective copyright owners.
  11.   *
  12.   * COPYRIGHT(c) 2018 STMicroelectronics
  13.   *
  14.   * Redistribution and use in source and binary forms, with or without modification,
  15.   * are permitted provided that the following conditions are met:
  16.   *   1. Redistributions of source code must retain the above copyright notice,
  17.   *      this list of conditions and the following disclaimer.
  18.   *   2. Redistributions in binary form must reproduce the above copyright notice,
  19.   *      this list of conditions and the following disclaimer in the documentation
  20.   *      and/or other materials provided with the distribution.
  21.   *   3. Neither the name of STMicroelectronics nor the names of its contributors
  22.   *      may be used to endorse or promote products derived from this software
  23.   *      without specific prior written permission.
  24.   *
  25.   * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  26.   * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  27.   * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  28.   * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  29.   * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  30.   * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  31.   * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  32.   * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  33.   * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  34.   * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
  35.   *
  36.   ******************************************************************************
  37.   */
  38. /* Includes ------------------------------------------------------------------*/
  39. #include "main.h"
  40. #include "stm32l0xx_hal.h"
  41. #include "lcd.h"
  42. #include "key.h"
  43. #include "time_con.h"
  44. /* USER CODE BEGIN Includes */
  45. /* USER CODE END Includes */
  46. /* Private variables ---------------------------------------------------------*/
  47. RTC_HandleTypeDef hrtc;
  48. /* USER CODE BEGIN PV */
  49. /* Private variables ---------------------------------------------------------*/
  50. /* USER CODE END PV */
  51. /* Private function prototypes -----------------------------------------------*/
  52. void SystemClock_Config(void);
  53. static void MX_GPIO_Init(void);
  54. static void MX_RTC_Init(void);
  55. /* USER CODE BEGIN PFP */
  56. /* Private function prototypes -----------------------------------------------*/
  57. /* USER CODE END PFP */
  58. /* USER CODE BEGIN 0 */
  59. HAL_StatusTypeDef RTC_Set_Time(u8 hour,u8 min,u8 sec);
  60. HAL_StatusTypeDef RTC_Set_Date(u8 year,u8 month,u8 date,u8 week);
  61. /* USER CODE END 0 */
  62. int main(void)
  63. {
  64.   /* USER CODE BEGIN 1 */
  65.         RTC_TimeTypeDef rtc_timeStruct;
  66.     RTC_DateTypeDef rtc_dateStruct;
  67.         u8 tbuf[40];
  68.         static u8 key,weeks;
  69.   /* USER CODE END 1 */
  70.   /* MCU Configuration----------------------------------------------------------*/
  71.   /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  72.   HAL_Init();
  73.   /* USER CODE BEGIN Init */
  74.   /* USER CODE END Init */
  75.   /* Configure the system clock */
  76.   SystemClock_Config();
  77.   /* USER CODE BEGIN SysInit */
  78.   /* USER CODE END SysInit */
  79.
  80.   /* Initialize all configured peripherals */
  81.   MX_GPIO_Init();
  82.   MX_RTC_Init();
  83.
  84.   /* USER CODE BEGIN 2 */
  85.   LCD1602_Init();
  86.   HAL_Delay(100);
  87.   HAL_RTC_GetTime(&hrtc, &rtc_timeStruct, RTC_FORMAT_BIN);
  88.   HAL_RTC_GetDate(&hrtc, &rtc_dateStruct, RTC_FORMAT_BIN);
  89.   /* USER CODE END 2 */
  90.
  91.   /* Infinite loop */
  92.   /* USER CODE BEGIN WHILE */
  93.   while (1)
  94.   {
  95.   /* USER CODE END WHILE */
  96.   /* USER CODE BEGIN 3 */
  97.
  98.          key=KEY_Scan();
  99.          switch(key)
  100.          {
  101.                  case 1:
  102.                          LCD1602_Show_Str(15,0," ");
  103.                          break;
  104.                  case 2://year
  105.                          LCD1602_cursor(8,0);
  106.                          if(KEY1==RESET)
  107.                          {
  108.                                  rtc_dateStruct.Year=down(rtc_dateStruct.Year,100);
  109.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  110.                          }
  111.                          if(KEY2==RESET)
  112.                          {
  113.                                  rtc_dateStruct.Year=up(rtc_dateStruct.Year,100);
  114.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  115.                          }
  116.                          break;
  117.                  case 3://month
  118.                          LCD1602_cursor(11,0);
  119.                          if(KEY1==RESET)
  120.                          {
  121.                                  rtc_dateStruct.Month--;
  122.                                  if((rtc_dateStruct.Month>=13)||rtc_dateStruct.Month==0)
  123.                                         rtc_dateStruct.Month=12;
  124.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  125.                          }
  126.                          if(KEY2==RESET)
  127.                          {
  128.                                  rtc_dateStruct.Month++;
  129.                                  if(rtc_dateStruct.Month==13)
  130.                                         rtc_dateStruct.Month=1;
  131.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  132.                          }
  133.                          break;
  134.                  case 4://date
  135.                          LCD1602_cursor(14,0);
  136.                          if(KEY1==RESET)
  137.                          {
  138.                                  rtc_dateStruct.Date--;
  139.                                  if((rtc_dateStruct.Date>=dates(rtc_dateStruct.Year,rtc_dateStruct.Month)+1)||rtc_dateStruct.Date==0)
  140.                                         rtc_dateStruct.Date=dates(rtc_dateStruct.Year,rtc_dateStruct.Month);
  141.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  142.                          }
  143.                          if(KEY2==RESET)
  144.                          {
  145.                                  rtc_dateStruct.Date++;
  146.                                  if(rtc_dateStruct.Date==dates(rtc_dateStruct.Year,rtc_dateStruct.Month)+1)
  147.                                         rtc_dateStruct.Date=1;
  148.                                  RTC_Set_Date(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date,rtc_dateStruct.WeekDay);
  149.                          }
  150.                          break;
  151.                  case 5://hour
  152.                          LCD1602_cursor(1,1);
  153.                          if(KEY1==RESET)
  154.                          {
  155.                                  rtc_timeStruct.Hours=down(rtc_timeStruct.Hours,24);
  156.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  157.                          }
  158.                          if(KEY2==RESET)
  159.                          {
  160.                                  rtc_timeStruct.Hours=up(rtc_timeStruct.Hours,24);
  161.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  162.                          }
  163.                          break;
  164.                  case 6://min
  165.                          LCD1602_cursor(4,1);
  166.                          if(KEY1==RESET)
  167.                          {
  168.                                  rtc_timeStruct.Minutes=down(rtc_timeStruct.Minutes,60);
  169.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  170.                          }
  171.                          if(KEY2==RESET)
  172.                          {
  173.                                  rtc_timeStruct.Minutes=up(rtc_timeStruct.Minutes,60);
  174.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  175.                          }
  176.                          break;
  177.                  case 7://sec
  178.                          LCD1602_cursor(7,1);
  179.                          if(KEY1==RESET)
  180.                          {
  181.                                  rtc_timeStruct.Seconds=down(rtc_timeStruct.Seconds,60);
  182.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  183.                          }
  184.                          if(KEY2==RESET)
  185.                          {
  186.                                  rtc_timeStruct.Seconds=up(rtc_timeStruct.Seconds,60);
  187.                                  RTC_Set_Time(rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  188.                          }
  189.                          break;
  190.          }
  191.          HAL_Delay(150);
  192.          HAL_RTC_GetTime(&hrtc, &rtc_timeStruct, RTC_FORMAT_BIN);
  193.      HAL_RTC_GetDate(&hrtc, &rtc_dateStruct, RTC_FORMAT_BIN);
  194.          sprintf((char*)tbuf,"%02d:%02d:%02d ",rtc_timeStruct.Hours,rtc_timeStruct.Minutes,rtc_timeStruct.Seconds);
  195.          LCD1602_Show_Str(0, 1,tbuf);
  196.          sprintf((char*)tbuf,"DATE:20%02d-%02d-%02d",rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date);
  197.          LCD1602_Show_Str(0, 0,tbuf);
  198.          weeks=week_update(rtc_dateStruct.Year,rtc_dateStruct.Month,rtc_dateStruct.Date);
  199.          switch(weeks)
  200.          {
  201.                 case 0:
  202.                         LCD1602_Show_Str(9, 1,"Sunday   ");
  203.                         break;
  204.                 case 1:
  205.                         LCD1602_Show_Str(9, 1,"Monday   ");
  206.                         break;
  207.                 case 2:
  208.                         LCD1602_Show_Str(9, 1,"Tuesday  ");
  209.                         break;
  210.                 case 3:
  211.                         LCD1602_Show_Str(9, 1,"Wednesday");
  212.                         break;
  213.                 case 4:
  214.                         LCD1602_Show_Str(9, 1,"Thursday ");
  215.                         break;
  216.                 case 5:
  217.                         LCD1602_Show_Str(9, 1,"Friday   ");
  218.                         break;
  219.                 case 6:
  220.                         LCD1602_Show_Str(9, 1,"Saturday ");
  221.                         break;
  222.          }
  223.   }
  224.   /* USER CODE END 3 */
  225. }
  226. /** System Clock Configuration
  227. */
  228. void SystemClock_Config(void)
  229. {
  230.   RCC_OscInitTypeDef RCC_OscInitStruct;
  231.   RCC_ClkInitTypeDef RCC_ClkInitStruct;
  232.   RCC_PeriphCLKInitTypeDef PeriphClkInit;
  233.     /**Configure the main internal regulator output voltage
  234.     */
  235.   __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  236.     /**Initializes the CPU, AHB and APB busses clocks
  237.     */
  238.   RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI|RCC_OSCILLATORTYPE_LSE;
  239.   RCC_OscInitStruct.LSEState = RCC_LSE_ON;
  240.   RCC_OscInitStruct.HSIState = RCC_HSI_DIV4;
  241.   RCC_OscInitStruct.HSICalibrationValue = 16;
  242.   RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  243.   RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSI;
  244.   RCC_OscInitStruct.PLL.PLLMUL = RCC_PLLMUL_16;
  245.   RCC_OscInitStruct.PLL.PLLDIV = RCC_PLLDIV_2;
  246.   if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
  247.   {
  248.     _Error_Handler(__FILE__, __LINE__);
  249.   }
  250.     /**Initializes the CPU, AHB and APB busses clocks
  251.     */
  252.   RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
  253.                               |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  254.   RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  255.   RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  256.   RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1;
  257.   RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
  258.   if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK)
  259.   {
  260.     _Error_Handler(__FILE__, __LINE__);
  261.   }
  262.   PeriphClkInit.PeriphClockSelection = RCC_PERIPHCLK_RTC;
  263.   PeriphClkInit.RTCClockSelection = RCC_RTCCLKSOURCE_LSE;
  264.   if (HAL_RCCEx_PeriphCLKConfig(&PeriphClkInit) != HAL_OK)
  265.   {
  266.     _Error_Handler(__FILE__, __LINE__);
  267.   }
  268.     /**Configure the Systick interrupt time
  269.     */
  270.   HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
  271.     /**Configure the Systick
  272.     */
  273.   HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
  274.   /* SysTick_IRQn interrupt configuration */
  275.   HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
  276. }
  277. /* RTC init function */
  278. static void MX_RTC_Init(void)
  279. {
  280.   RTC_TimeTypeDef sTime;
  281.   RTC_DateTypeDef sDate;
  282.     /**Initialize RTC Only
  283.     */
  284.   hrtc.Instance = RTC;
  285.   hrtc.Init.HourFormat = RTC_HOURFORMAT_24;
  286.   hrtc.Init.AsynchPrediv = 127;
  287.   hrtc.Init.SynchPrediv = 255;
  288.   hrtc.Init.OutPut = RTC_OUTPUT_DISABLE;
  289.   hrtc.Init.OutPutRemap = RTC_OUTPUT_REMAP_NONE;
  290.   hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH;
  291.   hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN;
  292.   if (HAL_RTC_Init(&hrtc) != HAL_OK)
  293.   {
  294.     _Error_Handler(__FILE__, __LINE__);
  295.   }
  296.     /**Initialize RTC and set the Time and Date
  297.     */
  298.   if(HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR0) != 0x32F2){
  299.   sTime.Hours = 0x20;//
  300.   sTime.Minutes = 0x19;
  301.   sTime.Seconds = 0x0;
  302.   sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE;
  303.   sTime.StoreOperation = RTC_STOREOPERATION_SET;
  304.   if (HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BCD) != HAL_OK)
  305.   {
  306.     _Error_Handler(__FILE__, __LINE__);
  307.   }
  308.   sDate.WeekDay = RTC_WEEKDAY_SUNDAY;
  309.   sDate.Month = RTC_MONTH_JANUARY;
  310.   sDate.Date = 0x21;
  311.   sDate.Year = 0x18;
  312.   if (HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BCD) != HAL_OK)
  313.   {
  314.     _Error_Handler(__FILE__, __LINE__);
  315.   }
  316.     HAL_RTCEx_BKUPWrite(&hrtc,RTC_BKP_DR0,0x32F2);
  317.   }
  318. }
  319. /** Configure pins as
  320.         * Analog
  321.         * Input
  322.         * Output
  323.         * EVENT_OUT
  324.         * EXTI
  325.      PA2   ------> USART2_TX
  326.      PA3   ------> USART2_RX
  327. */
  328. static void MX_GPIO_Init(void)
  329. {
  330.   GPIO_InitTypeDef GPIO_InitStruct;
  331.   /* GPIO Ports Clock Enable */
  332.         __HAL_RCC_GPIOC_CLK_ENABLE();
  333.         __HAL_RCC_GPIOH_CLK_ENABLE();
  334.         __HAL_RCC_GPIOA_CLK_ENABLE();
  335.         __HAL_RCC_GPIOB_CLK_ENABLE();
  336.   /*Configure GPIO pin Output Level */
  337.   HAL_GPIO_WritePin(LD2_GPIO_Port, LD2_Pin, GPIO_PIN_RESET);
  338.   /*Configure GPIO pin : B1_Pin */
  339.   GPIO_InitStruct.Pin = B1_Pin;
  340.   GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  341.   GPIO_InitStruct.Pull = GPIO_PULLUP;
  342.   HAL_GPIO_Init(B1_GPIO_Port, &GPIO_InitStruct);
  343.
  344.   /*Configure GPIO pins : PA0 PA1 PA4 */
  345.   GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_4|GPIO_PIN_7;
  346.   GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
  347.   GPIO_InitStruct.Pull = GPIO_PULLUP;
  348.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  349.   /*Configure GPIO pins : USART_TX_Pin USART_RX_Pin */
  350.   GPIO_InitStruct.Pin = USART_TX_Pin|USART_RX_Pin;
  351.   GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
  352.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  353.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH;
  354.   GPIO_InitStruct.Alternate = GPIO_AF4_USART2;
  355.   HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
  356.   /*Configure GPIO pin : LD2_Pin */
  357.   GPIO_InitStruct.Pin = LD2_Pin;
  358.   GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  359.   GPIO_InitStruct.Pull = GPIO_NOPULL;
  360.   GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  361.   HAL_GPIO_Init(LD2_GPIO_Port, &GPIO_InitStruct);
  362.
  363.     /*USER Configure : GPIOC_Pin : LCD1602 */
  364.         GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2|GPIO_PIN_3|GPIO_PIN_4|GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7;
  365.         GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;                        //推挽輸出
  366.         GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;                //IO口速度為高速
  367.         HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);                                //初始化GPIOD0~10
  368.
  369.         GPIO_InitStruct.Pin = GPIO_PIN_13|GPIO_PIN_14|GPIO_PIN_15;
  370.         GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;                        //推挽輸出
  371.         GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;                //IO口速度為高速
  372.         HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);                                //初始化GPIOD0~10
  373. }
  374. /* USER CODE BEGIN 4 */
  375. /* USER CODE BEGIN 0 */
  376. //RTC時間設置
  377. //hour,min,sec:小時,分鐘,秒鐘
  378. //ampm:@RTC_AM_PM_Definitions:RTC_HOURFORMAT12_AM/RTC_HOURFORMAT12_PM
  379. //返回值:SUCEE(1),成功
  380. //       ERROR(0),進入初始化模式失敗
  381. HAL_StatusTypeDef RTC_Set_Time(u8 hour,u8 min,u8 sec)//unsigned char ampm
  382. {
  383.         RTC_TimeTypeDef RTC_TimeStructure;
  384.
  385.         RTC_TimeStructure.Hours=hour;
  386.         RTC_TimeStructure.Minutes=min;
  387.         RTC_TimeStructure.Seconds=sec;
  388.         //RTC_TimeStructure.TimeFormat=ampm;
  389.         RTC_TimeStructure.DayLightSaving=RTC_DAYLIGHTSAVING_NONE;
  390.   RTC_TimeStructure.StoreOperation=RTC_STOREOPERATION_RESET;
  391.         return HAL_RTC_SetTime(&hrtc,&RTC_TimeStructure,RTC_FORMAT_BIN);
  392. }
  393. //RTC日期設置
  394. //year,month,date:年(0~99),月(1~12),日(0~31)
  395. //week:星期(1~7,0,非法!)
  396. //返回值:SUCEE(1),成功
  397. //       ERROR(0),進入初始化模式失敗
  398. HAL_StatusTypeDef RTC_Set_Date(u8 year,u8 month,u8 date,u8 week)
  399. {
  400.         RTC_DateTypeDef RTC_DateStructure;
  401.
  402.         RTC_DateStructure.Date=date;
  403.         RTC_DateStructure.Month=month;
  404.         RTC_DateStructure.WeekDay=week;
  405.         RTC_DateStructure.Year=year;
  406.         return HAL_RTC_SetDate(&hrtc,&RTC_DateStructure,RTC_FORMAT_BIN);
  407. }
  408. /* USER CODE END 4 */
  409. /**
  410.   * @brief  This function is executed in case of error occurrence.
  411.   * @param  None
  412.   * @retval None
  413.   */
  414. void _Error_Handler(char * file, int line)
  415. {
  416.   /* USER CODE BEGIN Error_Handler_Debug */
  417.   /* User can add his own implementation to report the HAL error return state */
  418.   while(1)
  419.   {
  420.   }
  421.   /* USER CODE END Error_Handler_Debug */
  422. }
  423. #ifdef USE_FULL_ASSERT
  424. /**
  425.    * @brief Reports the name of the source file and the source line number
  426.    * where the assert_param error has occurred.
  427.    * @param file: pointer to the source file name
  428.    * @param line: assert_param error line source number
  429.    * @retval None
  430.    */
  431. void assert_failed(uint8_t* file, uint32_t line)
  432. {
  433.   /* USER CODE BEGIN 6 */
  434.   /* User can add his own implementation to report the file name and line number,
  435.     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  436.   /* USER CODE END 6 */
  437. }
  438. #endif
  439. /**
  440.   * @}
  441.   */
  442. /**
  443.   * @}
  444. */
ID:279357 發表于 2018-1-25 10:12 | 只看該作者
初始代碼是由CubeMX自動生成的,小弟剛玩CubeMX,所以代碼可能有點亂,大家將就著看~不好意思啦
