差分進(jìn)化算法的C語言實(shí)現(xiàn),有大量的注釋,簡(jiǎn)單易懂!
- /*DE_test
- *對(duì)相應(yīng)的Matlab程序進(jìn)行測(cè)試
- #include <iostream>
- #include <cmath>
- #include <ctime>
- using namespace std;
- //產(chǎn)生隨機(jī)數(shù),隨機(jī)數(shù)為(0.0,1.0)
- double Rand_Double(void)
- return static_cast<double>(rand()) / static_cast<double>(RAND_MAX);
- //測(cè)試函數(shù)Hansen
- //參數(shù)個(gè)數(shù)為2
- double Hansen(double *p_pars)
- return ( cos(1.0) + 2.0*cos(p_pars[0]+2.0) + 3.0*cos(2.0*p_pars[0]+3.0)
- + 4.0*cos(3.0*p_pars[0]+4.0) + 5.0*cos(4.0*p_pars[0]+5.0) )
- * ( cos(2.0*p_pars[1]+1.0) + 2.0*cos(3.0*p_pars[1]+2.0) +
- 3.0*cos(4.0*p_pars[1]+3.0) + 4.0*cos(5.0*p_pars[1]+4.0) + 5.0*cos(6.0*p_pars[1]+5.0) );
- class CFunction
- public:
- void *m_p_fun;//指向測(cè)試函數(shù)的指針
- int m_pars_num;//參數(shù)個(gè)數(shù)
- double m_min;//下限
- double m_max;//上限
- bool m_pos;//求解最小值還是最大值,如果是最小值則m_pos為false,如果是最大值則m_pos為true
- public:
- CFunction(void *p_fun,int pars_num,double min,double max,bool pos)
- :m_p_fun(p_fun),m_pars_num(pars_num),m_min(min),m_max(max),m_pos(pos)
- virtual double Compute(double *p_pars) = 0;
- class CHansen:public CFunction
- public:
- //注冊(cè)函數(shù)
- CHansen(void)
- :CFunction(Hansen,2,-10.0,10.0,false)
- double Compute(double *p_pars)
- return Hansen(p_pars);
- //個(gè)體
- class CIndividual
- public:
- double *m_p_DNA;//參數(shù)
- double m_f;//適應(yīng)值
- int m_DNA_length;//DNA的長(zhǎng)度
- public:
- CIndividual(void)
- :m_f(0.0),m_DNA_length(0),m_p_DNA(NULL)
- ~CIndividual(void)
- if(m_p_DNA!=NULL)
- delete[] m_p_DNA;
- //初始化,分配內(nèi)存空間
- void Ini(int pars_num)
- m_DNA_length = pars_num;
- m_p_DNA = new double[m_DNA_length];
- //假定兩者分配的內(nèi)存空間的大小一樣
- CIndividual& operator=(CIndividual& ind)
- m_f = ind.m_f;
- //m_DNA_length = ind.m_DNA_length;
- for(int i=0;i<m_DNA_length;++i)
- m_p_DNA[i] = ind.m_p_DNA[i];
- return *this;
- friend ostream& operator<<(ostream& o,CIndividual& ind)
- return o<<ind.m_f;
- int main()
- //---------------------------設(shè)置隨機(jī)數(shù)------------------------------------
- srand((unsigned int)(time(NULL)));
- //獲得參數(shù)
- int Num,T;
- double zoom,cr;
- cout<<"種群大小:";
- cin>>Num;
- cout<<"進(jìn)化代數(shù):";
- cin>>T;
- cout<<"縮放因子:";
- cin>>zoom;
- cout<<"交叉因子:";
- cin>>cr;
- //----------------------對(duì)函數(shù)進(jìn)行操作,注冊(cè)函數(shù)------------------------------
- CHansen fun_Hansen;
- CFunction *p_fun = &fun_Hansen;//為了實(shí)現(xiàn)多態(tài)
- int pars_num = p_fun->m_pars_num;//參數(shù)個(gè)數(shù)
- double min = p_fun->m_min;//下限
- double max = p_fun->m_max;//上限
- bool pos = p_fun->m_pos;//求最大值還是最小值
- //----------------------注冊(cè)種群,并分配內(nèi)存空間-----------------------------
- CIndividual *p_old = new CIndividual[Num];
- CIndividual *p_new = new CIndividual[Num];
- for(int i=0;i<Num;++i)
- p_old[i].Ini(pars_num);
- p_new[i].Ini(pars_num);
- //-------------------------產(chǎn)生初始的隨機(jī)種群--------------------------------
- for(int i=0;i<Num;++i)//對(duì)種群進(jìn)行遍歷
- for(int j=0;j<pars_num;++j)//對(duì)參數(shù)列表進(jìn)行遍歷
- p_old[i].m_p_DNA[j] = Rand_Double()*(max-min)+min;
- p_old[i].m_f = p_fun->Compute(p_old[i].m_p_DNA);
- CIndividual ind_best;
- ind_best.Ini(pars_num);
- for(int t=0;t<T;++t)//開始一代一代地進(jìn)化
- //顯示結(jié)果
- ind_best = p_old[0];
- for(int i=1;i<Num;++i)
- if(pos==true && ind_best.m_f<p_old[i].m_f)//求最大值
- ind_best = p_old[i];
- else if(pos==false && ind_best.m_f>p_old[i].m_f)//求最小值
- cout<<ind_best<<"\n";
- //差分變異
- //產(chǎn)生三個(gè)隨機(jī)數(shù)
- int x1,x2,x3;
- x1 = rand() % Num;
- do
- x2 = rand() % Num;
- }while(x1==x2);
- do
- x3 = rand() % Num;
- }while(x1==x3||x2==x3);
- p_new[i].m_p_DNA[j] = p_old[x1].m_p_DNA[j] + zoom * ( p_old[x2].m_p_DNA[j] - p_old[x3].m_p_DNA[j] );
- if(p_new[i].m_p_DNA[j]<min || p_new[i].m_p_DNA[j]>max)//越界
- p_new[i].m_p_DNA[j] = p_old[i].m_p_DNA[j];
- //交叉操作,注意,交叉要對(duì)每個(gè)實(shí)數(shù)位進(jìn)行交叉
- if(Rand_Double()>cr)//不交叉
- p_new[i].m_f = p_fun->Compute(p_new[i].m_p_DNA);
- //選擇操作
- if(pos==true && p_new[i].m_f < p_old[i].m_f)//求最大值
- p_new[i] = p_old[i];
- else if(pos==false && p_new[i].m_f > p_old[i].m_f)//求最小值
- //交換
- CIndividual *p_tmp;
- p_tmp = p_old;
- p_old = p_new;
- p_new = p_tmp;
- //此時(shí),新種群的值被保存到p_old中
- return 0;
Main.rar
2018-1-23 21:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
1.79 KB, 下載次數(shù): 7, 下載積分: 黑幣 -5
