原理圖:
RC522上位機delphi軟件源碼與界面:
- #include "reg52.h"
- #include "main.h"
- #include "mfrc522.h"
- #include <string.h>
- //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
- //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
- unsigned char code data2[4] = {0x12,0,0,0};
- unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- unsigned char g_ucTempbuf[20];
- unsigned char idata MLastSelectedSnr[4];
- unsigned char idata RevBuffer[30];
- unsigned char data SerBuffer[20];
- bit CmdValid;
- void iccardcode()
- unsigned char cmd;
- unsigned char status;
- cmd = RevBuffer[0];
- switch(cmd)
- case 1: // Halt the card //終止卡的操作
- status= PcdHalt();;
- RevBuffer[0]=1;
- RevBuffer[1]=status;
- break;
- case 2: // Request,Anticoll,Select,return CardType(2 bytes)+CardSerialNo(4 bytes)
- // 尋卡,防沖突,選擇卡 返回卡類型(2 bytes)+ 卡系列號(4 bytes)
- status= PcdRequest(RevBuffer[1],&RevBuffer[2]);
- if(status!=0)
- if(status!=0)
- RevBuffer[0]=1;
- break;
- RevBuffer[0]=3;
- break;
- case 3: // 防沖突 讀卡的系列號 MLastSelectedSnr
- status = PcdAnticoll(&RevBuffer[2]);
- if(status!=0)
- RevBuffer[0]=1;
- break;
- memcpy(MLastSelectedSnr,&RevBuffer[2],4);
- RevBuffer[0]=5;
- break;
- case 4: // 選擇卡 Select Card
- status=PcdSelect(MLastSelectedSnr);
- if(status!=MI_OK)
- RevBuffer[0]=1;
- break;
- RevBuffer[0]=3;
- break;
- case 5: // Key loading into the MF RC500's EEPROM
- status = PcdAuthState(RevBuffer[1], RevBuffer[3], DefaultKey, MLastSelectedSnr);// 校驗卡密碼
- RevBuffer[0]=1;
- break;
- case 6:
- RevBuffer[0]=1;
- break;
- case 7:
- RevBuffer[0]=1;
- break;
- case 8: // Read the mifare card
- // 讀卡
- status=PcdRead(RevBuffer[1],&RevBuffer[2]);
- if(status==0)
- {RevBuffer[0]=17;}
- else
- {RevBuffer[0]=1;}
- break;
- case 9: // Write the mifare card
- // 寫卡 下載密碼
- status=PcdWrite(RevBuffer[1],&RevBuffer[2]);
- RevBuffer[0]=1;
- break;
- case 10:
- PcdValue(RevBuffer[1],RevBuffer[2],&RevBuffer[3]);
- RevBuffer[0]=1;
- break;
- case 12: // 參數設置
- PcdBakValue(RevBuffer[1], RevBuffer[2]);
- RevBuffer[0]=1; //contact
- RevBuffer[1]=0;
- break;
- //系統初始化
- void InitializeSystem()
- P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;
- ET2 = 0;
- T2CON = 0x04;
- PCON = 0x80;
- SCON = 0x70;
- TMOD = 0x21; //TMOD = 0x22;
- TH1 = BAUD_9600;
- TL1 = TH1;
- TR1 = 1; // 波特率發生器
- TH0 = 0x60;
- TL0 = 0x60;
- TR0 = 0;
- ET0=0;
- ET1=0;
- EA=1;
- EX0=1;
- IT0 = 1;
- TR2=0;
- ES = 1;
- CmdValid=0;
- LED_GREEN = 1;
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- M500PcdConfigISOType( 'A' );
- LED_GREEN = 0;
- delay_10ms(10);
- LED_GREEN = 1;
- delay_10ms(10);
- LED_GREEN = 0;
- //用T2做延時子程序
- // 接收和發送中斷
- void isr_UART(void) interrupt 4 using 1
- unsigned char len, i;
- unsigned int j=0;
- if(RI)
- len=SBUF;
- RI=0;
- for(i=0;i<len;i++)
- while(!RI)
- j++;
- if(j>1000)
- break;
- if(j<1000)
- RevBuffer[i]=SBUF;
- RI=0;
- j=0;
- else
- break;
- if(i==len)
- REN=0;
- CmdValid=1;
- else if(!RI && TI)
- TI=0;
- len=RevBuffer[0];
- for(i=0;i<len+1;i++)
- SBUF=RevBuffer[i];
- while(!TI);
- TI=0;
- REN=1;
- void main( )
- unsigned char baud;
- InitializeSystem( );
- while (1)
- if (CmdValid)
- CmdValid = FALSE;
- if(RevBuffer[0]==11) //為了加快相應速度 測試風鳴器
- RevBuffer[2]=RevBuffer[1];
- RevBuffer[1]=0;
- CALL_isr_UART();
- LED_GREEN = 1;
- delay_10ms(RevBuffer[2]);
- LED_GREEN = 0;
- else if(RevBuffer[0]==13) //設置通訊波特率
- switch(RevBuffer[1])
- case 0:
- baud=BAUD_9600;
- break;
- case 1:
- baud=BAUD_14400;
- break;
- case 2:
- baud=BAUD_19200;
- break;
- case 3:
- baud=BAUD_28800;
- break;
- case 4:
- baud=BAUD_38400;
- break;
- case 5:
- baud=BAUD_57600;
- break;
51讀寫卡參考例程及上位機調試軟件.zip
(880.84 KB, 下載次數: 160)
2018-1-22 21:56 上傳
