#include <TimerOne.h>
#include <TM1637.h>
#define ON 1
#define OFF 0
int8_t TimeDisp[] = {0x00, 0x00, 0x00, 0x00};
unsigned char ClockPoint = 1;
unsigned char Update;
unsigned char halfsecond = 0;
unsigned char second;
unsigned char minute = 20;
unsigned char hour = 10;
int buttonpin2=2;//按鍵的一只腳接端口2,另一只腳接地
int buttonpin7=7;//按鍵的一只腳接端口7,另一只腳接地
#define CLK 10
#define DIO 11 //DIO接一個(gè)4.7k的下拉電阻,這點(diǎn)很重要,否則數(shù)碼管會假死。
TM1637 tm1637(CLK, DIO);
void setup()
pinMode(buttonpin2,INPUT_PULLUP);//輸入上拉模式
pinMode(buttonpin7,INPUT_PULLUP);//輸入上拉模式
tm1637.set();
tm1637.init();
Timer1.initialize(500000);//timing for 500ms
Timer1.attachInterrupt(TimingISR);//declare the interrupt serve routine:TimingISR
void loop()
if(digitalRead(buttonpin2)==0)//按鍵被按下,調(diào)整小時(shí)
delay(200);//延時(shí)去抖動
hour=hour+1;
if (hour == 24) {hour = 0;}
if(digitalRead(buttonpin7)==0)//按鍵被按下,調(diào)整分
minute=minute+1;
if (minute == 60){minute = 0;}
if (Update == ON) //每隔0.5秒調(diào)用一次
TimeUpdate();
tm1637.display(TimeDisp);
void TimingISR()
halfsecond ++; Update = ON;
if (halfsecond == 2)
second ++; halfsecond = 0;
if (second == 60)
minute ++; second = 0;
if (minute == 60)
hour ++; minute = 0;
ClockPoint = (~ClockPoint) & 0x01; //ClockPoint先是按位取反再按位與,結(jié)果就是0 1 0 1......這樣一直下去。我的理解是0.5秒為0,1秒為1,1.5秒為0,2秒為1。。。。。。
void TimeUpdate(void)
if (ClockPoint) tm1637.point(POINT_ON);
else tm1637.point(POINT_OFF);
TimeDisp[0] = hour / 10;
TimeDisp[1] = hour % 10;
TimeDisp[2] = minute / 10;
TimeDisp[3] = minute % 10;
Update = OFF;
