查看: 1902|回復(fù): 1
這是我做的單片機(jī)設(shè)計(jì)代碼,實(shí)現(xiàn)密碼鎖功能
ID:278453 發(fā)表于 2018-1-22 01:09 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include <REG51.h>
#include<intrins.h>
//宏定義
#define LCM_Data  P0                  //將P0口定義為LCM_Data
#define uint  unsigned int
#define w 6                                //定義密碼位數(shù)
//1602的控制腳
sbit lcd1602_rs=P2^7;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^5;
sbit Scl=P3^4;                        //24C02串行時鐘
sbit Sda=P3^5;                        //24C02串行數(shù)據(jù)
sbit ALAM = P2^1;                //報(bào)警
sbit KEY = P3^6;                //開鎖
sbit open_led=P2^2;                //開鎖指示燈(選配)
bit  operation=0;                //操作標(biāo)志位
bit  pass=0;                        //密碼正確標(biāo)志
bit  ReInputEn=0;                //重置輸入允許標(biāo)志
bit  s3_keydown=0;                //3秒按鍵標(biāo)志位
bit  key_disable=0;                //鎖定鍵盤標(biāo)志
unsigned char countt0,second;        //t0中斷計(jì)數(shù)器,秒計(jì)數(shù)器
void Delay5Ms(void);                //聲明延時函數(shù)
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盤掃描控制表
//液晶顯示數(shù)據(jù)數(shù)組
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = { "===Coded Lock==="};        //顯示名稱
unsigned char code Correct[]         = {"     correct    "};                //輸入正確
unsigned char code Error[]           = {"      error     "};          //輸入錯誤
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};                //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};                //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //輸入密碼暫存區(qū)
unsigned char CurrentPassword[6]={1,3,1,4,2,0};                         //管理員密碼(只可在程序中修改)
unsigned char TempPassword[6];
unsigned char N=0;                                //密碼輸入位數(shù)記數(shù)
unsigned char ErrorCont;                        //錯誤次數(shù)計(jì)數(shù)
unsigned char CorrectCont;                        //正確輸入計(jì)數(shù)
unsigned char ReInputCont;                         //重新輸入計(jì)數(shù)
unsigned char code initpassword[6]={0,0,0,0,0,0};                        //輸入管理員密碼后將密碼初始為000000
//=====================5ms延時==============================
void Delay5Ms(void)
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延時==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02========================================================
void mDelay(uint t) //延時
        uchar i;
           while(t--)
                   for(i=0;i<125;i++)
void Nop(void)                  //空操作
         _nop_();                  //僅作延時用一條語句大約1us
         _nop_();
        _nop_();
/*****24c02程序參照24c02時序圖*****/
/*起始條件*/
void Start(void)
        Scl=1;
         Nop();
         Sda=0;
         Nop();
/*停止條件*/
void Stop(void)
         Sda=0;
         Scl=1;
         Nop();
         Sda=1;
         Nop();
/*應(yīng)答位*/
void Ack(void)
        Sda=0;
        Nop();
        Scl=1;
        Nop();
        Scl=0;
/*反向應(yīng)答位*/
void NoAck(void)
         Sda=1;
         Nop();
         Scl=1;
         Nop();
         Scl=0;
/*發(fā)送數(shù)據(jù)子程序,Data為要求發(fā)送的數(shù)據(jù)*/
void Send(uchar Data)
           uchar BitCounter=8;
           uchar temp;
           do
                   temp=Data;                                           //將待發(fā)送數(shù)據(jù)暫存temp
                   Scl=0;
                   Nop();
                   if((temp&0x80)==0x80)                   //將讀到的數(shù)據(jù)&0x80
                   Sda=1;
                   Sda=0;
                   Scl=1;
                   temp=Data<<1;                                   //數(shù)據(jù)左移
                   Data=temp;                                           //數(shù)據(jù)左移后重新賦值Data
                   BitCounter--;                                   //該變量減到0時,數(shù)據(jù)也就傳送完成了
           while(BitCounter);                                   //判斷是否傳送完成
           Scl=0;
/*讀一字節(jié)的數(shù)據(jù),并返回該字節(jié)值*/
uchar Read(void)
    uchar temp=0;
        uchar temp1=0;
        uchar BitCounter=8;
        Sda=1;
        do
                Scl=0;
                Nop();
                Scl=1;
                Nop();
                if(Sda)                                   //數(shù)據(jù)位是否為1
                        temp=temp|0x01;           //為1 temp的最低位為1(|0x01,就是將最低位變?yōu)?)
                else                                   //如果為0
                        temp=temp&0xfe;           //temp最低位為0(&0xfe(11111110)最低位就是0)
                if(BitCounter-1)           //BitCounter減1后是否為真
                        temp1=temp<<1;           //temp左移
                        temp=temp1;
                BitCounter--;                   //BitCounter減到0時,數(shù)據(jù)就接收完了
        while(BitCounter);                   //判斷是否接收完成
        return(temp);
參與人數(shù) 1黑幣 +50 收起 理由
大家可以試一試
