查看: 4420|回復: 7
求助。怎么用STC12C5A60S2的蜂鳴器放音樂
ID:278182 發表于 2018-1-21 22:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
求助各位大神,怎么用STC12C5A60S2的蜂鳴器放音樂啊,雖然有學過C語言,但是看到好多類似的單片機程序還是一臉蒙蔽。。。頭一次接觸單片機。謝謝各位大神了
ID:210244 發表于 2018-1-21 23:29 | 只看該作者
通過控制蜂鳴器的開關時間來生成調子,網上有很多蜂鳴器的曲譜,改改用就好了
ID:278453 發表于 2018-1-22 01:05 | 只看該作者
從網上直接搜索例程,現在這種做蜂鳴器的很簡單
ID:164602 發表于 2018-1-22 08:32 | 只看該作者
給你一個例程看看。
本實例利用無源蜂鳴器發出音樂聲音。
還用到了定時計數器0
#include <reg51.h>
sbit voice=P1^5;//蜂鳴器接口
uchar code sound[]={0xff,
0x30,0x10,0x2b,0x10,0x26,0x80,0xff,0x40,0x30,0x20,0x30,0x10,0x39,0x10,
0x40,0x80,0xff,0x40,0xff,0x20,0x40,0x20,0x26,0x20,0x26,0x10,0x2b,0x10,
0x2b,0x40,0xff,0x20,0x40,0x20,0x26,0x20,0x2b,0x20,0x2b,0x80,0xff,0x40,
0xff,0x10,0x40,0x10,0x40,0x10,0x40,0x10,0x1c,0x20,0x20,0x20,0x1c,0x20,
0x26,0x20,0x26,0x20,0xff,0x20,0x2b,0x30,0x30,0x10,0x26,0x10,0x2b,0x60,
0xff,0x20,0x39,0x20,0x30,0x20,0x39,0x20,0x30,0x40,0xff,0x20,0xff,0x20,
0xff,0x20,0x39,0x10,0x39,0x10,0x2b,0x20,0x2b,0x20,0x30,0x40,0xff,0x40,
0x26,0x80,0xff,0x20,0x2b,0x20,0x30,0x20,0x30,0x10,0x39,0x10,0x40,0x80,
0xff,0x40,0xff,0x20,0x40,0x10,0x40,0x10,0x1c,0x20,0x20,0x60,0xff,0x20,
0x30,0x20,0x2b,0x20,0x26,0x10,0x2b,0x10,0x2b,0x80,0xff,0x40,0xff,0x20,
0x40,0x10,0x40,0x10,0x39,0x20,0x40,0x20,0x1c,0x30,0x20,0x10,0xff,0x20,
0x1c,0x20,0x20,0x20,0x1c,0x20,0x26,0x80,0xff,0x30,0x2b,0x10,0x2b,0x20,
0x30,0x10,0x26,0x20,0x2b,0x60,0xff,0x40,0x39,0x20,0x30,0x20,0x30,0x80,
0xff,0x40,0xff,0x40,0x40,0x20,0x39,0x20,0x30,0x20,0x2b,0x20,0x26,0x20,
0x1c,0x20,0x20,0x40,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x1c,0x10,0x20,0x10,
0x20,0x20,0x20,0x10,0x26,0x10,0x26,0x40,0x26,0x20,0x26,0x20,0x26,0x20,
0x26,0x10,0x2b,0x10,0x2b,0x20,0x30,0x10,0x33,0x10,0x39,0x40,0x30,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x40,0x10,0x40,0x80,0x40,0x20,0x39,0x20,
0x30,0x20,0x2b,0x20,0x26,0x20,0x1c,0x20,0x20,0x40,0x1c,0x20,0x1c,0x20,
0x1c,0x20,0x1c,0x10,0x20,0x10,0x20,0x20,0x20,0x10,0x26,0x10,0x26,0x40,
0x26,0x20,0x26,0x20,0x26,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x10,
0x30,0x10,0x39,0x40,0x2b,0x20,0x2b,0x20,0x2b,0x20,0x2b,0x10,0x30,0x10,
0x30,0x80,0x00};
uchar zdjs=0, jp;
void del(yj);
void main(void)
        uint dpjs=0;
        uchar yj;
        TMOD=0x01;
        IE=0x82;
        TL0=0xf0;
        TR0=1;
                zdjs=0;
                dpjs++; yj=sound[dpjs];
                dpjs++; jp=sound[dpjs];
                while(zdjs!=jp)
                        if(yj!=0xff)
                                if(yj!=0)
                                        voice=!voice;
                                        del(yj);
                                        dpjs=0;
                                        break;
                                voice=1;
                                del(jp);
void time0() interrupt 1
        TH0=0xd8;
        TL0=0xf0;
        zdjs++;
void del(yj)
        uchar yj2=2;
        while(yj!=0)
                while(yj2!=0)
                        yj2--;
                        yj2=2;
                        yj--;
ID:123289 發表于 2018-1-22 13:06 | 只看該作者
先讀通單片機原理,C語言再好只是語言好,與懂不懂單片機無關!
ID:267935 發表于 2018-1-22 15:01 | 只看該作者
利用IO口輸出PWM波來驅動三極管,從而驅動蜂鳴器,曲子的話,網上都能百度到的
ID:278182 發表于 2018-1-22 21:53 | 只看該作者
謝謝各位,太感謝了
ID:247467 發表于 2018-1-23 08:50 | 只看該作者
找到你需要的曲譜在稍微修改,在單片機中運行看看看看效果咋樣。
