error 1: Out of memory 內存溢出
error 2: Identifier expected 缺標識符
error 3: Unknown identifier 未定義的標識符
error 4: Duplicate identifier 重復定義的標識符
error 5: Syntax error 語法錯誤
error 6: Error in real constant 實型常量錯誤
error 7: Error in integer constant 整型常量錯誤
error 8: String constant exceeds line 字符串常量超過一行
error 10: Unexpected end of file 文件非正常結束
error 11: Line too long 行太長
error 12: Type identifier expected 未定義的類型標識符
error 13: Too many open files 打開文件太多
error 14: Invalid file name 無效的文件名
error 15: File not found 文件未找到
error 16: Disk full 磁盤滿
error 17: Invalid compiler directive 無效的編譯命令
error 18: Too many files 文件太多
error 19: Undefined type in pointer def 指針定義中未定義類型
error 20: Variable identifier expected 缺變量標識符
error 21: Error in type 類型錯誤
error 22: Structure too large 結構類型太長
error 23: Set base type out of range 集合基類型越界
error 24: File components may not be files or objectsfile分量不能是文件或對象
error 25: Invalid string length 無效的字符串長度
error 26: Type mismatch 類型不匹配
error 27:error 27:Invalid subrange base type 無效的子界基類型
error 28:Lower bound greater than upper bound 下界超過上界
error 29:Ordinal type expected 缺有序類型
error 30:Integer constant expected 缺整型常量
error 31:Constant expected 缺常量
error 32:Integer or real constant expected 缺整型或實型常量
error 33:Pointer Type identifier expected 缺指針類型標識符
error 34:Invalid function result type 無效的函數結果類型
error 35:Label identifier expected 缺標號標識符
error 36:BEGIN expected 缺BEGIN
error 37:END expected 缺END
error 38:Integer expression expected 缺整型表達式
error 39:Ordinal expression expected 缺有序類型表達式
error 40:Boolean expression expected 缺布爾表達式
error 41:Operand types do not match 操作數類型不匹配
error 42:Error in expression 表達式錯誤
error 43:Illegal assignment 非法賦值
error 44:Field identifier expected 缺域標識符
error 45:Object file too large 目標文件太大
error 46:Undefined external 未定義的外部過程與函數
error 47:Invalid object file record 無效的OBJ文件格式
error 48:Code segment too large 代碼段太長
error 49:Data segment too large 數據段太長
error 50:DO expected 缺DO
error 51:Invalid PUBLIC definition 無效的PUBLIC定義
error 52:Invalid EXTRN definition 無效的EXTRN定義
error 53: Too many EXTRN definitions 太多的EXTRN定義
error 54:OF expected 缺OF
error 55:INTERFACE expected 缺INTERFACE
error 56:Invalid relocatable reference 無效的可重定位引用
error 57:THEN expected 缺THEN
error 58:TO or DOWNTO expected 缺TO或DOWNTO
error 59:Undefined forward 提前引用未經定義的說明
error 61:Invalid typecast 無效的類型轉換
error 62:Division by zero 被零除
error 63:Invalid file type 無效的文件類型
error 64:Cannot read or write variables of this type 不能讀寫此類型變量
error 65:Pointer variable expected 缺指針類型變量
error 66:String variable expected 缺字符串變量
error 67:String expression expected 缺字符串表達式
error 68:Circular unit reference 單元UNIT部件循環引用
error 69:Unit name mismatch 單元名不匹配
error 70:Unit version mismatch 單元版本不匹配
error 71:Internal stack overflow 內部堆棧溢出
error 72:Unit file format error 單元文件格式錯誤
error 73:IMPLEMENTATION expected 缺IMPLEMENTATION
error 74:Constant and case types do not match 常量和CASE類型不匹配
error 75:Record or object variable expected 缺記錄或對象變量
error 76:Constant out of range 常量越界
error 77:File variable expected 缺文件變量
error 78:Pointer expression expected 缺指針表達式
error 79:Integer or real expression expected 缺整型或實型表達式
error 80:Label not within current block 標號不在當前塊內
error 81:Label already defined 標號已定義
error 82:Undefined label in preceding statement part 在前面未定義標號
error 83:Invalid @ argument 無效的@參數
error 84:UNIT expected 缺UNIT
error 85: ";" expected 缺“;”
error 86: ":" expected 缺“:”
error 87: "," expected 缺“,”
error 88: "(" expected 缺“(”
error 89: ")" expected 缺“)”
error 90: "=" expected 缺“=”
error 91: ":=" expected 缺“:=”
error 92: "[" or "(." Expected 缺“[”或“(.”
error 93: "]" or ".)" expected 缺“]”或“.)”
error 94: "." expected 缺“.”
error 95: ".." expected 缺“..”
error 96:Too many variables 變量太多
error 97:Invalid FOR control variable 無效的FOR循環控制變量
error 98:Integer variable expected 缺整型變量
error 99:Files and procedure types are not allowed here 該處不允許文件和過程類型
error 100:String length mismatch 字符串長度不匹配
downfile.zip
2018-1-17 22:25 上傳
下載積分: 黑幣 -5
257.92 KB, 下載次數: 15, 下載積分: 黑幣 -5
