附錄 課設(shè)總原理圖(附件中有清晰的圖片下載):
VHDL直流電機(jī)控制系統(tǒng)課設(shè)頂層文件: - LIBRARY ieee;
- USE ieee.std_logic_1164.all;
- LIBRARY work;
- ENTITY FX IS
- PORT
- C0 : IN STD_LOGIC;
- K2 : IN STD_LOGIC;
- K1 : IN STD_LOGIC;
- C1 : IN STD_LOGIC;
- KIN : IN STD_LOGIC;
- clk1 : IN STD_LOGIC;
- M0 : OUT STD_LOGIC;
- M1 : OUT STD_LOGIC;
- M : OUT STD_LOGIC;
- CLK : OUT STD_LOGIC;
- LK : OUT STD_LOGIC;
- KOUT : OUT STD_LOGIC;
- ADR : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
- CIN : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
- DOUT : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
- DOUT1 : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
- LED : OUT STD_LOGIC_VECTOR(6 DOWNTO 0);
- Q : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
- END FX;
- ARCHITECTURE bdf_type OF FX IS
- COMPONENT cnt8b
- PORT(CLK : IN STD_LOGIC;
- DOUT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
- END COMPONENT;
- COMPONENT erzp
- END COMPONENT;
- COMPONENT tf_ctrl
- PORT(CLK1 : IN STD_LOGIC;
- CNT_EN : OUT STD_LOGIC;
- CLR : OUT STD_LOGIC;
- LOCK : OUT STD_LOGIC
- END COMPONENT;
- COMPONENT cnt10d
- CLR : IN STD_LOGIC;
- ENABL : IN STD_LOGIC;
- COUT : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
- DOUT2 : OUT STD_LOGIC_VECTOR(3 DOWNTO 0)
- END COMPONENT;
- COMPONENT lock8
- PORT(LK : IN STD_LOGIC;
- D : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
- END COMPONENT;
- COMPONENT cnt4b
- END COMPONENT;
- COMPONENT squ1
- PORT(ADR : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
- CIN : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
- OT : OUT STD_LOGIC
- END COMPONENT;
- COMPONENT slt
- PORT(SL : IN STD_LOGIC;
- M : IN STD_LOGIC;
- m0 : OUT STD_LOGIC;
- m1 : OUT STD_LOGIC
- END COMPONENT;
- COMPONENT decl7s
- PORT(A : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
- LED7S : OUT STD_LOGIC_VECTOR(6 DOWNTO 0)
- END COMPONENT;
- SIGNAL SYNTHESIZED_WIRE_0 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_1 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_2 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_3 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_4 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_5 : STD_LOGIC_VECTOR(7 DOWNTO 0);
- SIGNAL SYNTHESIZED_WIRE_6 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_7 : STD_LOGIC_VECTOR(7 DOWNTO 0);
- SIGNAL SYNTHESIZED_WIRE_8 : STD_LOGIC_VECTOR(7 DOWNTO 0);
- SIGNAL SYNTHESIZED_WIRE_9 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_10 : STD_LOGIC;
- SIGNAL SYNTHESIZED_WIRE_11 : STD_LOGIC_VECTOR(3 DOWNTO 0);
- BEGIN
- M <= SYNTHESIZED_WIRE_9;
- CLK <= SYNTHESIZED_WIRE_6;
- LK <= SYNTHESIZED_WIRE_4;
- KOUT <= SYNTHESIZED_WIRE_1;
- ADR <= SYNTHESIZED_WIRE_7;
- CIN <= SYNTHESIZED_WIRE_8;
- b2v_inst : cnt8b
- PORT MAP(CLK => C0,
- DOUT => SYNTHESIZED_WIRE_7);
- b2v_inst1 : erzp
- KIN => SYNTHESIZED_WIRE_0,
- KOUT => SYNTHESIZED_WIRE_6);
- b2v_inst11 : tf_ctrl
- PORT MAP(CLK1 => clk1,
- CNT_EN => SYNTHESIZED_WIRE_3,
- CLR => SYNTHESIZED_WIRE_2,
- LOCK => SYNTHESIZED_WIRE_4);
- b2v_inst12 : cnt10d
- PORT MAP(CLK => SYNTHESIZED_WIRE_1,
- ENABL => SYNTHESIZED_WIRE_3,
- COUT => SYNTHESIZED_WIRE_5,
- DOUT1 => DOUT1,
- DOUT2 => DOUT);
- b2v_inst13 : lock8
- PORT MAP(LK => SYNTHESIZED_WIRE_4,
- D => SYNTHESIZED_WIRE_5,
- Q => Q);
- b2v_inst2 : cnt4b
- PORT MAP(CLK => SYNTHESIZED_WIRE_6,
- CIN => SYNTHESIZED_WIRE_8,
- DOUT => SYNTHESIZED_WIRE_11);
- b2v_inst3 : squ1
- PORT MAP(ADR => SYNTHESIZED_WIRE_7,
- OT => SYNTHESIZED_WIRE_10);
- b2v_inst4 : slt
- PORT MAP(SL => K1,
- M => SYNTHESIZED_WIRE_9,
- m0 => M0,
- m1 => M1);
- SYNTHESIZED_WIRE_0 <= NOT(K2);
- SYNTHESIZED_WIRE_9 <= NOT(SYNTHESIZED_WIRE_10);
- b2v_inst7 : decl7s
- PORT MAP(A => SYNTHESIZED_WIRE_11,
- LED7S => LED);
- b2v_inst8 : erzp
- PORT MAP(CLK => C1,
- KIN => KIN,
- KOUT => SYNTHESIZED_WIRE_1);
- END bdf_type;
- 消抖模塊:
- LIBRARY IEEE;
- USE IEEE.STD_LOGIC_1164.ALL;
- USE IEEE.STD_LOGIC_UNSIGNED.ALL;
- ENTITY ERZP IS
- PORT(CLK,KIN : IN STD_LOGIC;
- KOUT : OUT STD_LOGIC );
- END;
- ARCHITECTURE BHV OF ERZP IS
- SIGNAL KL,KH : STD_LOGIC_VECTOR(3 DOWNTO 0);
- BEGIN
- PROCESS(CLK,KIN,KL,KH ) BEGIN
- IF CLK'EVENT AND CLK = '1' THEN
- IF(KIN='0') THEN KL<=KL+1;
- ELSE KL<="0000"; END IF;
- IF(KIN='1') THEN KH<=KH+1;
- ELSE KH<="0000"; END IF;
- IF(KH>"0101") THEN KOUT<='1';
- ELSIF (KL>"0101") THEN KOUT<='0';
- END IF; END IF;
- END PROCESS;
- END;
- 頻率控制模塊:
- LIBRARY IEEE;
- ENTITY TF_CTRL IS
- PORT (CLK1 : IN STD_LOGIC; -- 1Hz
- CNT_EN : OUT STD_LOGIC; -- 計(jì)數(shù)器時(shí)鐘使能
- CLR : OUT STD_LOGIC; -- 計(jì)數(shù)器清零
- LOCK : OUT STD_LOGIC ); -- 輸出鎖存信號(hào)
- END TF_CTRL;
- ARCHITECTURE behav OF TF_CTRL IS
- SIGNAL Div2CLK : STD_LOGIC;
- BEGIN
- PROCESS( CLK1 )
- BEGIN
- IF CLK1'EVENT AND CLK1 = '1' THEN
- Div2CLK <= NOT Div2CLK;
- END IF;
- END PROCESS;
- PROCESS (CLK1, Div2CLK)
- BEGIN
- IF CLK1='0' AND Div2CLK='0' THEN CLR<='1';-- 產(chǎn)生計(jì)數(shù)器清零信號(hào)
- ELSE CLR <= '0'; END IF;
- END PROCESS;
- LOCK <= NOT Div2CLK; CNT_EN <= Div2CLK;
- END behav;
- 頻率計(jì)數(shù)模塊:
- LIBRARY IEEE; --8位計(jì)數(shù)器
- ENTITY CNT10D IS
- PORT (CLK : IN STD_LOGIC; -- 時(shí)鐘信號(hào)
- CLR : IN STD_LOGIC; -- 清零信號(hào)
- ENABL : IN STD_LOGIC; -- 計(jì)數(shù)使能信號(hào)
- DOUT2 : OUT STD_LOGIC_VECTOR(3 DOWNTO 0)); -- 計(jì)數(shù)結(jié)果
- END CNT10D;
- ARCHITECTURE behav OF CNT10D IS
- SIGNAL CQ2 : STD_LOGIC_VECTOR(3 DOWNTO 0);
- SIGNAL CQ3 : STD_LOGIC_VECTOR(3 DOWNTO 0);
- BEGIN
- PROCESS(CLK, CLR, ENABL)
- BEGIN
- IF CLR = '1' THEN CQ2 <= (OTHERS=>'0'); CQ3 <= (OTHERS=>'0'); -- 清零
- ELSIF CLK'EVENT AND CLK = '1' THEN
- IF ENABL = '1' THEN IF CQ2>8 THEN CQ2(3 DOWNTO 0)<="0000"; CQ3<=CQ3+1;
- ELSE CQ2 <=CQ2+1;
- END IF;
- END IF;
- END IF;
- END PROCESS;
- COUT <= CQ3&CQ2;
- DOUT1 <=CQ2;
- DOUT2 <=CQ3;
- END behav;
- 8位鎖存模塊:
- LIBRARY IEEE; --8位鎖存器
- ENTITY LOCK8 IS
- PORT ( LK : IN STD_LOGIC;
- LEDA: OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
- LEDB: OUT STD_LOGIC_VECTOR(3 DOWNTO 0));
- END LOCK8;
- ARCHITECTURE behav OF LOCK8 IS
- BEGIN
- PROCESS(LK, D)
- BEGIN
- IF LK'EVENT AND LK = '1' THEN LEDA <= D(7 DOWNTO 4); LEDB <= D(3 DOWNTO 0);
- END IF;
- END PROCESS;
- END behav;
- 8位計(jì)數(shù)器模塊:
- LIBRARY IEEE;
- ENTITY CNT8B IS
- DOUT: OUT STD_LOGIC_VECTOR(7 DOWNTO 0) );
- END CNT8B;
- ARCHITECTURE BHV OF CNT8B IS
- BEGIN
- PROCESS(CLK)
- VARIABLE CQ : STD_LOGIC_VECTOR(7 DOWNTO 0);
- BEGIN
- IF CQ<255 THEN --
- CQ := CQ + 1 ;
- ELSE CQ := (OTHERS=>'0') ;
- END IF;
- END IF;
- DOUT <= CQ;
- END PROCESS;
- END BHV;
- 4位計(jì)數(shù)器模塊:
- LIBRARY IEEE;
- ENTITY CNT4B IS
- CIN: OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
- DOUT: OUT STD_LOGIC_VECTOR(3 DOWNTO 0) );
- END CNT4B;
- ARCHITECTURE BHV OF CNT4B IS
- SIGNAL CQ1 : STD_LOGIC_VECTOR(3 DOWNTO 0);
- BEGIN
- PROCESS(CLK)
- VARIABLE CQ : STD_LOGIC_VECTOR(3 DOWNTO 0);
- BEGIN
- CQ1 <="1111";
- IF CQ<15 THEN
- CQ := CQ + 1 ;
- END IF;
- END IF;
- DOUT <=CQ(3 DOWNTO 0);
- CIN <=CQ&CQ1;
- END PROCESS;
- END BHV;
- PWM信號(hào)產(chǎn)生模塊:
- LIBRARY IEEE;
- ENTITY SQU1 IS
- PORT ( CIN,ADR : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
- OT : OUT STD_LOGIC );
- END SQU1;
- ARCHITECTURE BHV OF SQU1 IS
- BEGIN
- PROCESS(CIN) BEGIN
- IF (ADR<CIN) THEN OT<='0';
- ELSE OT<='1'; END IF;
- END PROCESS;
- END BHV;
- 正反轉(zhuǎn)模塊:
- LIBRARY IEEE;
- use ieee.std_logic_arith.all;
- ENTITY SLT IS
- PORT (SL, M, K : IN STD_LOGIC;
- m0, m1: OUT STD_LOGIC );
- END SLT;
- ARCHITECTURE BHV OF SLT IS
- TYPE FSM_ST IS (S0,S1);
- SIGNAL c_st, next_state: FSM_ST :=S0;
- BEGIN
- REG : PROCESS (SL)
- BEGIN
- IF SL='1'AND SL'EVENT THEN c_st <= next_state;
- END IF;
- END PROCESS REG ;
- COM : PROCESS (c_st, M) BEGIN
- IF K='1' THEN m0 <='0'; m1 <='0';
- ELSE
- CASE c_st IS
- WHEN S0 => m0 <= M; m1 <='0'; next_state <= S1;
- WHEN S1 => m1 <= M; m0 <='0'; next_state <= S0;
- END CASE;
- END IF;
- END PROCESS;
- END BHV;
- 分頻模塊: 實(shí)際測(cè)試時(shí)沒有用,因?yàn)殚_發(fā)箱直接有1Hz的時(shí)鐘。
- LIBRARY IEEE ;
- ENTITY CNT IS
- PORT(CLOCK : IN STD_LOGIC ;COUT : OUT STD_LOGIC);
- END ;
- ARCHITECTURE bhv OF CNT IS
- SIGNAL C1,C2 : STD_LOGIC_VECTOR(8 DOWNTO 0) ;
- SIGNAL M1,M2 : STD_LOGIC ;
- BEGIN
- PROCESS(CLOCK,C1) BEGIN
- IF RISING_EDGE(CLOCK) THEN
- IF (C1="111111111") THEN C1<="000000000"; ELSE C1<=C1+1; END IF;
- IF (C1="000000001") THEN M1<=NOT M1; ELSIF (C1="100000000") THEN M1<=NOT M1;
- END IF;END IF;
- END PROCESS;
- PROCESS (CLOCK,C2) BEGIN
- IF FALLING_EDGE(CLOCK) THEN
- IF(C2="111111111") THEN C2<="000000000"; ELSE C2<=C2+1;END IF;
- IF(C2="000000001") THEN M2<=NOT M2 ; ELSIF (C2="100000000") THEN M2<=NOT M2;
- END IF; END IF;
- END PROCESS;
- COUT<=M1 OR M2;
- END bhv
全部資料51hei下載地址:
基于VHDL的直流電機(jī)控制系統(tǒng)程序.7z
(42.82 KB, 下載次數(shù): 71)
2018-1-17 02:52 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
設(shè)計(jì)報(bào)告預(yù)覽(附件中可下載word格式的):
http://www.raoushi.com/bbs/dpj-105338-1.html
