查看: 8532|回復: 2
8*8LED矩陣滾動顯示數字和字符
//8*8矩陣循環顯示字符和數字
//顯示字符串在數組disstr[]中申明
#include<reg51.h>
#include<intrins.h>
#include<string.h>
#include<absacc.h>
//X向字模
uchar code Table_of_Digits[40][8]=
        {0x00,0x3e,0x41,0x41,0x41,0x3e,0x00,0x00},//0
        {0x00,0x00,0x00,0x21,0x7f,0x01,0x00,0x00},//1
        {0x00,0x27,0x45,0x45,0x45,0x39,0x00,0x00},//2
        {0x00,0x22,0x49,0x49,0x49,0x36,0x00,0x00},//3
        {0x00,0x0c,0x14,0x24,0x7f,0x04,0x00,0x00},//4
        {0x00,0x72,0x51,0x51,0x51,0x4e,0x00,0x00},//5
        {0x00,0x3e,0x49,0x49,0x49,0x26,0x00,0x00},//6
        {0x00,0x40,0x40,0x40,0x4f,0x70,0x00,0x00},//7
        {0x00,0x36,0x49,0x49,0x49,0x36,0x00,0x00},//8
        {0x00,0x32,0x49,0x49,0x49,0x3e,0x00,0x00},//9
    {0x00,0x3E,0x48,0x48,0x48,0x3E,0x00,0x00},//A
    {0x00,0x00,0x7E,0x52,0x5A,0x6E,0x00,0x00},//B
    {0x00,0x00,0x3C,0x42,0x42,0x24,0x00,0x00},//C
    {0x00,0x00,0x7E,0x42,0x42,0x3C,0x00,0x00},//D
    {0x00,0x00,0x7E,0x52,0x52,0x52,0x00,0x00},//E
    {0x00,0x00,0x7E,0x50,0x50,0x40,0x00,0x00},//F
    {0x00,0x3C,0x42,0x42,0x4A,0x2E,0x00,0x00},//G
    {0x00,0x00,0x7E,0x10,0x10,0x7E,0x00,0x00},//H
    {0x00,0x00,0x00,0x7E,0x00,0x00,0x00,0x00},//I
    {0x00,0x00,0x0C,0x02,0x02,0x7C,0x00,0x00},//J
    {0x00,0x00,0x7F,0x08,0x14,0x22,0x00,0x00},//K
    {0x00,0x00,0x7E,0x02,0x02,0x02,0x00,0x00},//L
    {0x00,0x7E,0x20,0x10,0x20,0x7E,0x00,0x00},//M
    {0x00,0x00,0x7E,0x30,0x08,0x06,0x7E,0x00},//N
    {0x00,0x3C,0x42,0x42,0x42,0x42,0x3C,0x00},//O
    {0x00,0x00,0x7E,0x48,0x48,0x70,0x00,0x00},//P
    {0x00,0x3C,0x42,0x46,0x43,0x3C,0x00,0x00},//Q
    {0x00,0x00,0x7E,0x58,0x5C,0x72,0x00,0x00},//R
    {0x00,0x00,0x64,0x92,0x92,0x4C,0x00,0x00},//S
    {0x00,0x40,0x40,0x7E,0x40,0x40,0x00,0x00},//T
    {0x00,0x00,0x7C,0x02,0x02,0x7C,0x00,0x00},//U
    {0x00,0x00,0x60,0x18,0x06,0x18,0x60,0x00},//V
    {0x00,0x7E,0x0C,0x18,0x0C,0x7E,0x00,0x00},//W
    {0x00,0x42,0x24,0x18,0x18,0x24,0x42,0x00},//X
    {0x00,0x40,0x20,0x1E,0x20,0x40,0x00,0x00},//Y
    {0x00,0X00,0x46,0x5A,0x72,0x42,0x00,0x00},//Z
uchar code xdat[8]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
uchar code ydat[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};
uchar i=0;
uchar j=0;
uchar t=0;
uchar Num_Index,disnum,disnum1;
uchar key;
uchar xi;
uchar yi;
uint  len;        //顯示的字符串長度
uchar buffer[16];
uchar code disstr[]="ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789";         //顯示內容自己可以任意定義,注意只能是大些字母和數字
#define wei XBYTE[0xa000]
sbit dat=P1^1;
sbit clk=P1^0;
sbit ls0=P2^4;
sbit ls1=P2^5;
sbit ls2=P2^6;
sbit ls3=P2^7;
//用74LS164來輸出一個8位的數據,
//點亮相應的LED
void sendbyte(uchar byte)
uchar num,c;
num=byte;
for(c=0;c<8;c++)
  clk=0;
  dat=num&0x01;   //每一位的輸出
  clk=1;                 //每一次上升沿,輸出一位數據
  num>>=1;            //右移位賦值 ,以供下一位的輸出
//主程序
Num_Index=0; //從0 開始顯示
TMOD=0x01; //T0 方式0
TH0=(65536-2000)/256; //2ms 定時
TL0=(65536-2000)%256;
IE=0x82;
key=0;
xi=0;
yi=0;
TR0=1; //啟動T0
len=strlen(disstr);
while(1);
//定時器0 中斷函數
//顯示控制
void LED_Screen_Display() interrupt 1
uchar m,n;
         if(i==0)
         if(disstr[Num_Index]>='A')disnum=disstr[Num_Index]-'A'+10;           //求顯示字符在字庫中的位置
         else disnum=disstr[Num_Index]-'0';
         if(disstr[Num_Index+1]>='A')disnum1=disstr[Num_Index+1]-'A'+10; //連續取兩個賦給緩沖器,便于滾動顯示
         else disnum1=disstr[Num_Index+1]-'0';
                 for(m=0;m<8;m++)buffer[m]=Table_of_Digits[disnum][m];           //給顯示緩沖區賦值
                 for(m=0;m<8;m++)buffer[m+8]=Table_of_Digits[disnum1][m];
         P0=0xff;
         P2=0xa0;
         P0=~buffer[i+n];
         P2=0x00;
         sendbyte(xdat[n]);
     if(++n==8) n=0; //每屏一個數字由8 個字節構成
     if(++t>=60) //每個數字刷新顯示一段時間
         i++;i%=8;
     t=0;
         if(i==0)
                Num_Index++;
                if(Num_Index>=(len-1))Num_Index=0;  //顯示下一個數字
juzhen88.rar
37.5 KB, 下載次數: 51, 下載積分: 黑幣 -5
8*8LED仿真
ID:417574 發表于 2018-10-29 21:26 | 只看該作者
謝謝分享!學習了。
ID:657605 發表于 2019-12-6 15:24 來自觸屏版 | 只看該作者
謝謝分享了。
