查看: 4533|回復(fù): 2
我的基于單片機(jī)的信號(hào)發(fā)生器仿真設(shè)計(jì)
ID:276332 發(fā)表于 2018-1-15 22:36 | 顯示全部樓層 |閱讀模式
這是我做的信號(hào)發(fā)生器課設(shè),用proteus畫的原理圖,keil4.1編寫的C語言。(都在壓縮包里)有不合理的地方請(qǐng)各位指點(diǎn)
這只是一部分原理圖
這只是一部分原理圖
單片機(jī)源程序如下:
  1. #include<reg52.h>
  3. #define uint  unsigned int
  4. #define DAdata P0 //DA數(shù)據(jù)端口
  5. sbit DA_S1=P2^0;
  6. sbit DA_S2=P2^1;
  7. sbit key =P3^2;
  8. uchar wavecount; //波形波碼計(jì)數(shù)標(biāo)志
  9. uchar THtemp,TLtemp;//傳遞頻率的中間變量
  10. uchar judge=1;   //用于方波函數(shù),作標(biāo)志
  11. uchar waveform;  //波形計(jì)數(shù)標(biāo)志,值不同代表不同的波形
  12. uchar code         freq_unit[3]={10,50,200};//3種波形的頻率單位
  13. uchar idata wavefreq[3]={1,1,1}; //數(shù)組單元,用于存放單位頻率的個(gè)數(shù)
  14. uchar code  lcd_hang1[]={"SineWave  ""TriangleWave  ""SquareWave " "sawtoothWave "   "Select Wave   "   "  Press No.1 key!    "};
  15. uchar idata lcd_hang2[16]={"f=    Hz      "};
  16. uchar code waveTH[]={0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
  17.                                            0xf9,0xfc,0xfd,0xfe,0xfe,0xfe,0xff,0xff,0xff,0xff,
  18.                                          0xf6,0xfb,0xfd,0xfb,0xfe,0xff,0xff,0xff,0xff,0xff};
  19. /**********************************/
  20. uchar code waveTL[]={
  21. 0x79,0x3d,0x7e,0x9e,0xbe,0xbf,0xc8,0xcf,0xd4,0xd9,//正弦波頻率調(diào)整中間值
  22. 0xe8,0xf4,0xf8,0x7a,0x7c,0xfc,0x23,0x3d,0x53,0x64,//鋸齒波頻率調(diào)整中間值
  23. 0x3c,0x1e,0x8f,0x32,0xc7,0x63,0xb1,0xd8,0xec,0xf6};//方波頻率調(diào)整中間值
  24. /*********************************/
  25. uchar code sawtooth_tab[]={
  26. 0x00,0x04,0x08,0x0c,0x10,0x14,0x18,0x1c,0x20,0x24,0x28,0x2c,
  27. 0x30,0x34,0x38,0x3c,0x40,0x44,0x48,0x4c,0x50,0x54,0x58,0x5c,
  28. 0x60,0x64,0x68,0x6c,0x70,0x74,0x78,0x7c,0x80,0x84,0x88,0x8c,
  29. 0x90,0x94,0x98,0x9c,0xa0,0xa4,0xa8,0xac,0xb0,0xb4,0xb8,0xbc,
  30. 0xc0,0xc4,0xc8,0xcc,0xd0,0xd4,0xd8,0xdc,0xe0,0xe4,0xe8,0xec,
  31. 0xf0,0xf4,0xf8,0xfc};
  32. /*****************************/
  33. uchar code sine_tab[256]={
  34. 0x80,0x83,0x86,0x89,0x90,0x93,0x96,0x99,0x9c,0x9f,
  35. 0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,
  36. 0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd8,0xda,0xdd,0xdf,
  37. 0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,
  38. 0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,
  39. 0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xfe,
  40. 0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,
  41. 0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,
  42. 0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,
  43. 0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,
  44. 0x8d,0x89,0x86,0x83,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,
  45. 0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,
  46. 0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,
  47. 0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,
  48. 0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,
  49. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,
  50. 0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,
  51. 0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,
  52. 0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,
  53. 0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
  54. /**************************************************/
  55. void delay(uchar z)
  56. {
  57.      uchar x,y;
  58.          for(x=z;x>0;x--)
  59.           for(y=110;y>0;y--);
  60. }
  61. /*
  62. void sawtooth_out()//鋸齒波輸出
  63. {
  64.          uchar i;
  65.      for(i=255;i>0;i--)
  66.          {
  67.                     DAdata=i;
  68.                  DA_S1=0;//打開8位輸入寄存器
  69.              DA_S1=1;//關(guān)閉8位輸入寄存器
  70.          }
  71. }
  72. */
  73. void sawtooth_out()//鋸齒波輸出
  74. {
  75.             DAdata=sawtooth_tab[wavecount++];
  76.          if(wavecount>64) wavecount=0;
  77.              DA_S1=0;//打開8位輸入寄存器
  78.              DA_S1=1;
  79. }
  80. void sine_out()//正弦波輸出
  81. {
  82.      DAdata=sine_tab[wavecount++];
  83.          DA_S1=0;//打開8位輸入寄存器
  84.          DA_S1=1;//關(guān)閉8位輸入寄存器
  85. }
  86. void square_out()//方波輸出
  87. {
  88.          judge=~judge;
  89.          if(judge==1)
  90.             DAdata=0xff;
  91.          else
  92.             DAdata=0x00;
  93.                 DA_S1=0;//打開8位輸入寄存器
  94.             DA_S1=1;//關(guān)閉8位輸入寄存器
  95. }
  96. /******************************/
  97. /**********1602***************/
  98. /****************************/
  99. #define lcd_ports  P1
  100. sbit rs=P2^2;
  101. sbit rw=P2^3;
  102. sbit lcden=P2^4;
  103. void write_com(uchar com)
  104. {
  105.          rs=0; //寫指令
  106.          lcden=0;
  107.          lcd_ports=com;
  108.          delay(5);
  109.          lcden=1;
  110.          delay(5);
  111.      lcden=0;
  112. }
  113. void write_date(uchar date)
  114. {
  115.          rs=1; //寫數(shù)據(jù)
  116.          lcden=0;
  117.          lcd_ports=date;
  118.          delay(10);
  119.      lcden=1;
  120.          delay(10);
  121.      lcden=0;
  122. }
  123. void disp_lcd(uchar addr,uchar *temp1)
  124. {
  125.          uchar num;
  126.          write_com(addr);
  127.          delay(1);
  128.          for(num=0;num<16;num++)
  129.          {
  130.              write_date(temp1[num]);
  131.                  delay(10);
  132.          }
  133. }
  134. void init_lcd()
  135. {
  136.      lcden=0;
  137.          rw=0;        //初始化一定要設(shè)置為零,表示寫數(shù)據(jù)
  138.          write_com(0x38);//使液晶顯示點(diǎn)陣,為下面做準(zhǔn)備
  139.          write_com(0x0c);//初始設(shè)置
  140.          write_com(0x06);//初始設(shè)置
  141.          write_com(0x01);//清零
  142.          write_com(0x80);//使指針指向第一行第一格
  143.          disp_lcd(0x80,&lcd_hang1[3*16]);//在第一行顯示
  144.          disp_lcd(0xc0,&lcd_hang2[4*16]);//在第二行顯示
  145. }
  146. /**********************************************/
  147. void main()
  148. {
  149.            DA_S2=0;
  150.      DAdata=0;
  151.          DA_S1=1; //關(guān)閉8位輸入寄存器
  152.          init_lcd();
  153.          waveform=0;
  154.          TMOD=0x01;//設(shè)定定時(shí)器0為16位工作方式
  155.          IT0=1;//設(shè)置外部中斷0為下降沿觸發(fā)
  156.          ET0=1;//開定時(shí)器中斷
  157.          EA=1;
  158.          while(1)
  159.          {
  160.          }
  161. }
  162. void key_int0() interrupt 0
  163. {
  164.      uchar keytemp;
  165.          uint  total_freq;//總頻率
  166.          EA=0;
  167.          TR0=0;
  168.          delay(10);
  169.          if(key==0)           //判斷按鍵是否按下
  170.          {
  171.             keytemp=P3&0xf0;//獲取P3口高四位的值
  172.                 switch(keytemp) //根據(jù)按鍵次數(shù)選擇波形
  173.                 {
  174.                     case 0xe0:
  175.                                   waveform++;
  176.                               if(waveform>2)waveform=0;
  177.                                           break;
  178.                         case 0xd0:
  179.                                         wavefreq[waveform]++; //        頻率按單位增加
  180.                               if(wavefreq[waveform]>10)wavefreq[waveform]=1;
  181.                                           break;
  182.                         case 0xb0:                                                 //        頻率按單位遞減
  183.                                           wavefreq[waveform]--;
  184.                               if(wavefreq[waveform]<1)wavefreq[waveform]=10;
  185.                                           break;
  186.                 }
  187.         THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)];
  188.                 //方括號(hào)中選取第幾個(gè)數(shù)后,并把該值賦給T_temp
  189.                 TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
  190. ……………………
  191. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
Jason.zip (57.29 KB, 下載次數(shù): 55)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
ID:272376 發(fā)表于 2018-4-22 22:15 | 顯示全部樓層
仿真的都不對(duì)
ID:665679 發(fā)表于 2019-12-16 22:32 | 顯示全部樓層
仿真的都不對(duì)
