#include <avr/io.h>
#include <util/delay.h>
//口定義
#define PORT_DHT PORTC
//口方向定義
#define DDR_DHT DDRC
//讀取口定義
#define PIN_DHT PINC
//數據位定義
#define BIT_DHT PC4
#define RS PA0 //數據/命令控制端 0命令,1 數據
#define RW PA1 //讀/寫選擇控制端 0寫,1讀
#define E PA2 //使能端 下降沿讀,高電平寫
#define L_DHT PORT_DHT&=~(1<<BIT_DHT) //數據線強制拉低
#define H_DHT PORT_DHT|=(1<<BIT_DHT) //數據線強制拉高
#define O_DHT DDR_DHT|=(1<<BIT_DHT) //Mega16控制總線,PD4為輸出
#define P_DHT DDR_DHT&=~(1<<BIT_DHT) //釋放總線,PD4為輸入
#define I_DHT PIN_DHT&(1<<BIT_DHT) //數據線的狀態
void LCDPort_Init(void); //液晶端口初始化
void LCD_Init(void); //LCD 初始化
void Write_Com(unsigned char LCD_Com); //LCD 寫指令
void Write_Data_Byte(unsigned char LCD_Data); //LCD 寫字節數據
void Write_Place_xy(unsigned char x,unsigned char y); //指定當前寫字符的位置
void Write_Data_String(unsigned char x,unsigned char y,unsigned char *data);//在指定的(x,y)位置上寫入字符串數據
void Write_Data_Char(unsigned char x,unsigned char y,unsigned char data);//在指定的(x,y)位置上寫入字符數據
void Check_Busy(void); //讀寫檢測函數,每次對液晶操讀作前都要進行寫檢測
void Delayus(unsigned int lus); //us延時函數
void Delayms(unsigned int lms); //ms延時函數
unsigned Reset()
O_DHT;
H_DHT;
_delay_us(2);
L_DHT;
_delay_us(19);
P_DHT;
_delay_us(20);
if(I_DHT)
return 0;
return 1;
int main(void)
_delay_ms(1000);
unsigned char tdata[5];
unsigned long u16Flag; // 超時計數
unsigned char iiii;
unsigned long u32I; // 接收數據臨時變量
unsigned long ReceiveValue = 0; // 接收數據包變量
unsigned long ReceiveValue1 = 0; // 接收校驗和變量
unsigned int ReceiveHighByte; // 分解數據包 濕度
unsigned int ReceiveLowByte; // 分解數據包溫度
LCDPort_Init();
LCD_Init();
Write_Data_String(0,0,"ddddddd");
if(Reset())
{ P_DHT;
while((!(I_DHT)) && ((u16Flag++)<50000));
ReceiveValue = 0;
ReceiveValue1 = 0;
u16Flag = 0;
while((I_DHT) && ((u16Flag++)<50000));
for(u32I=0x80000000; u32I>0; u32I>>=1)
u16Flag = 0;
while((!(I_DHT))&& ((u16Flag++)<3000));
u16Flag = 0;
_delay_us(28);
if(I_DHT)
ReceiveValue |= u32I;
while((I_DHT)&&((u16Flag++)<300));
for(u32I=0x80;u32I>0;u32I>>=1)
u16Flag = 0;
while((!(I_DHT))&&((u16Flag++)<3000));
u16Flag = 0;
_delay_us(28);
if(I_DHT)
ReceiveValue1 |= u32I;
while(!(I_DHT));
O_DHT;
H_DHT;
ReceiveLowByte =(unsigned int )( ReceiveValue&0x0000FFFF);
ReceiveHighByte = ReceiveValue>>16;
/****************************display******************************/
tdata[0]=*((unsigned char*)(&ReceiveHighByte) + 1)/10;
tdata[1]=*((unsigned char*)(&ReceiveHighByte) + 1)%10;
tdata[2]=*((unsigned char*)(&ReceiveLowByte) + 1)/10;
tdata[3]=*((unsigned char*)(&ReceiveLowByte) + 1)%10;
Write_Com(0xc0);
Write_Data_Byte( tdata[0]+0x30 );//顯示濕度十位
Write_Com(0xc1);
Write_Data_Byte( tdata[1]+0x30 );//顯示濕度個位
Write_Com(0xc2);
// Write_Data_Byte("%");
Write_Com(0xc4);
Write_Data_Byte( tdata[2]+0x30 );//顯示溫度十位
Write_Com(0xc5);
Write_Data_Byte( tdata[3]+0x30 );//顯示溫度個位
Write_Com(0xc6);
Write_Data_Byte(0xdf);//顯示"。"
Write_Com(0xc7);
Write_Data_Byte('C');
void LCDPort_Init()
//LCD 數據端口設置
PORTD = 0X00; //
DDRD = 0XFF; //配置端口PD全部為輸出口,LCD 數據端口
//LCD 控制端口設置
PORTA &= ~((1 << RS) | (1 << RW) | (1 << E)); //
DDRA |= (1 << RS) | (1 << RW) | (1 << E);
//LCD 初始化
void LCD_Init()
Write_Com(0X01); //清屏
Delayms(5);
Write_Com(0X38); //顯示模式設置 16x2顯示,5x7點陣,8 位數據接口
Delayms(5);
//Write_Com(0X0f); //顯示開關控制,開顯示,光標顯示,光標閃爍
Write_Com(0X0c); //顯示開關控制,開顯示,光標不顯示,光標不閃爍
Delayms(5);
Write_Com(0X06); //光標設置,讀或寫一個字符后,地址指針加一,光標加一,整屏不移動
Delayms(5);
//LCD 寫指令
Check_Busy();
PORTA &= ~(1 << RS); //RS=0,寫命令
PORTA &= ~(1 << RW); //RW=0,寫指令
PORTA |= (1 << E); //E=1,寫操作
Delayms(1);
PORTD = LCD_Com; //指令送數據端口
PORTA &= ~(1 << E); //E=0,停止寫操作
Delayms(1);
//LCD 寫字節數據
Check_Busy();
PORTA |= (1 << RS); //RS=1,寫數據
Delayms(1);
PORTD = LCD_Data; // 數據送數據端口
Delayms(1);
//指定當前寫字符的位置
unsigned char address;
if(y == 0) //行位置
address = 0x80 + x; //列位置,
address = 0x80 + 0x40 + x; //
Write_Com(address); //寫地址
Write_Place_xy(x,y); //寫地址
while(*data)
Write_Data_Byte(*data); //寫字符串
data++; //指針地址加1
//在指定的(x,y)位置上寫入字符數據 x列位置,y行位置
Write_Data_Byte(data); //
//讀寫檢測函數,每次對液晶操作前都要進行讀寫檢測
void Check_Busy()
DDRD = 0X00; //PB口置為輸入口,準備讀取數據
PORTA &= ~(1 << RS); //RS=0,讀命令
PORTA |= (1 << RW); //RW=1,讀指令
PORTA |= (1 << E); //E=1,使能
while(0X80 & PIND); //監測忙信號,直到忙信號為0,才能進行讀寫操作
DDRD = 0XFF; //PB口置為輸出口,準備向端口發送數據
//us級別的延時函數
while(lus--)
_delay_loop_2(4); //_delay_loop_2(1)是延時4 個時鐘周期,參數為4 則延時16
//個時鐘周期,本實驗用16M晶體,則16 個時鐘周期為16/16=1us
//ms級別的延時函數
while(lms--)
Delayus(1000); //延時1ms
