MFRC522電路原理圖:
天線部分:
單片機+MFRC522測試源程序如下:
- /**********************RC522實驗開發板例程************************
- * CPU:STC89C52RC
- * 晶振:11.0592MHZ
- //實驗目的:
- 名稱:MF RC522
- 內容:通過標準程序靜態顯示字符
- 引腳定義如下:
- sbit MF522_NSS = P1^7; //SDA
- sbit MF522_SCK = P1^6;
- sbit MF522_SI = P1^5;
- sbit MF522_SO = P1^4;
- sbit MF522_RST = P1^3;
- //蜂鳴器OR指示燈
- sbit LED_GREEN = P2^3;
- #include "lpcreg.h"
- #include "main.h"
- #include "mfrc522.h"
- #include <STDIO.H>
- #include <string.h>
- unsigned char code data1[16] = {0x12,0x34,0x56,0x78,0xED,0xCB,0xA9,0x87,0x12,0x34,0x56,0x78,0x01,0xFE,0x01,0xFE};
- //M1卡的某一塊寫為如下格式,則該塊為錢包,可接收扣款和充值命令
- //4字節金額(低字節在前)+4字節金額取反+4字節金額+1字節塊地址+1字節塊地址取反+1字節塊地址+1字節塊地址取反
- unsigned char code data2[4] = {0,0,0,0x01};
- unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- unsigned char g_ucTempbuf[20];
- void delay1(unsigned int z)
- unsigned int x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void main( )
- unsigned char status,i;
- unsigned int temp;
- InitializeSystem( );
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- while ( 1 )
- status = PcdRequest(PICC_REQALL, g_ucTempbuf);//尋卡
- if (status != MI_OK)
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- continue;
- printf("卡的類型:");
- for(i=0;i<2;i++)
- temp=g_ucTempbuf[i];
- printf("%X",temp);
- status = PcdAnticoll(g_ucTempbuf);//防沖撞
- { continue; }
- ////////以下為超級終端打印出的內容////////////////////////
- printf("卡序列號:"); //超級終端顯示,
- for(i=0;i<4;i++)
- status = PcdSelect(g_ucTempbuf);//選定卡片
- { continue; }
- status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, g_ucTempbuf);//驗證卡片密碼
- { continue; }
- status = PcdWrite(1, data1);//寫塊
- { continue; }
- while(1)
- PcdReset();
- PcdAntennaOff();
- PcdAntennaOn();
- continue;
- { continue; }
- { continue; }
- { continue; }
- status = PcdValue(PICC_DECREMENT,1,data2);//扣款
- { continue; }
- status = PcdBakValue(1, 2);//塊備份
- { continue; }
- status = PcdRead(2, g_ucTempbuf);//讀塊
- { continue; }
- printf("卡讀塊:"); //超級終端顯示,
- for(i=0;i<16;i++)
- printf("\n");
- LED_GREEN = 0;
- delay1(100);
- LED_GREEN = 1;
- delay1(100);
- LED_GREEN = 0;
- delay1(200);
- LED_GREEN = 1;
- PcdHalt();
- //系統初始化
- void InitializeSystem()
- P0M1 = 0x0; P0M2 = 0x0;
- P1M1 = 0x0; P1M2 = 0x0;
- P3M1 = 0x0; P3M2 = 0xFF;
- P0 = 0xFF; P1 = 0xFF; P3 = 0xFF;P2 = 0xFF;
- TMOD=0x21; //設T0為方式1,GATE=1;
MFRC522測試程序.rar
(104.75 KB, 下載次數: 225)
2018-1-14 19:24 上傳
MFRC522測試程序
