查看: 2182|回復: 0
舵機控制程序
ID:275069 發表于 2018-1-12 08:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. //
  2. //  dji.c
  3. //
  4. //
  5. //  Created by 倪剛 on 2018/1/12.
  6. //
  7. #include <reg52.h>
  8. #define Stop 0    //宏定義,停止
  9. #define Left 1   //宏定義,左轉
  10. #define Right 2   //宏定義,右轉
  11. sbit ControlPort = P2^0;  //舵機信號端口
  12. sbit KeyLeft = P1^0;   //左轉按鍵端口
  13. sbit KeyRight = P1^1;   //右轉按鍵端口
  14. sbit KeyStop = P1^2;   //歸位按鍵端口
  15. unsigned char TimeOutCounter = 0,LeftOrRight = 0;  //TimeOutCounter:定時器溢出計數   LeftOrRight:舵機左右旋轉標志
  16. void InitialTimer (void)
  17. {
  18.     TMOD=0x10;   //定時/計數器1工作于方式1
  19.     TH1 = ( 65535 - 500 ) / 256;   //0.25ms
  20.     TL1 = ( 65535 - 500 ) % 256;
  21.     EA=1;        //開總中斷
  22.     ET1=1;       //允許定時/計數器1 中斷
  23.     TR1=1;       //啟動定時/計數器1 中斷
  24.
  25. }
  26. void ControlLeftOrRight ( void )   //控制舵機函數
  27. {
  28.     if( KeyStop == 0 )
  29.     {
  30.         //while ( !KeyStop );    //使標志等于Stop(0),在中斷函數中將用到
  31.         LeftOrRight = Stop;
  32.     }
  33.     if( KeyLeft == 0 )
  34.     {
  35.         //while ( !KeyLeft );    //使標志等于Left(1),在中斷函數中將用到
  36.         LeftOrRight = Left;
  37.     }
  38.     if( KeyRight == 0 )
  39.     {
  40.         //while ( !KeyRight );   //使標志等于Right(2),在中斷函數中將用到
  41.         LeftOrRight = Right;
  42.     }
  43. }
  44. void main ( void )  //主函數
  45. {
  46.     InitialTimer();
  47.     for(;;)
  48.     {
  49.         ControlLeftOrRight();
  50.
  51.     }
  52. }
  53. void Timer1 ( void ) interrupt 3  //定時器中斷函數
  54. {
  55.     TH1 = ( 65535 - 500 ) / 256;
  56.     TL1 = ( 65535 - 500 ) % 256;
  57.     TimeOutCounter ++;
  58.     switch ( LeftOrRight )
  59.     {
  60.         case 0 :   //為0時,舵機歸位,脈寬1.5ms
  61.         {
  62.             if( TimeOutCounter <= 6 )
  63.             {
  64.                 ControlPort = 1;
  65.
  66.             } else {
  67.                 ControlPort = 0;
  68.             }
  69.             break;
  70.
  71.         }   case 1 :     //為1時,舵機左轉,脈寬1ms(理論值),實際可以調試得出
  72.         {
  73.             if( TimeOutCounter <= 2 )
  74.             {
  75.                 ControlPort = 1;
  76.
  77.             } else {
  78.                 ControlPort = 0;
  79.             }
  80.             break;
  81.
  82.         }   case 2 :   //為2時,舵機右轉,脈寬2ms(理論值),實際可以調試得出
  83.         {
  84.             if( TimeOutCounter <= 10 )
  85.                  {
  86.                     ControlPort = 1;
  87.
  88.                 }    else     {
  89.                     ControlPort = 0;
  90.
  91.                      }    break;
  92.         }
  93.          default : break;
  94.     }
  95.      if( TimeOutCounter == 80 )  //周期20ms(理論值),比較可靠,最好不要修改
  96.     {
  97.         TimeOutCounter = 0;
  98.     }
  99.
  100. }}
