查看: 7426|回復: 7
51單片機倒車雷達測距系統仿真+源代碼
單片機倒車雷達測距proteus仿真圖如下,附帶源碼和仿真工程文件
  1. #include <reg51.h>
  2. #include "intrins.h"
  3. #include "Lcd1602.h"
  5. #define uint unsigned int
  6. sbit BEEP = P1^6;  //報警提示口
  7. sbit vout = P1^7;  //脈沖發送口
  8. sbit P3_2 = P3^2;  //中斷接收口
  9. //sbit INT = P1^6;
  10. bit flag;
  11. //unsigned char discol[4]={0xef,0xdf,0xbf,0x7f};
  12. unsigned char code Anum_code[]={"0123456789"};
  13. //unsigned char disbuf[4]={0,1,2,3};
  14. float high,low;
  15. unsigned char qian,bai,shi,ge;
  16. //unsigned char j=600;
  17. /*void delay_1ms(void)  //12mhz delay 1.01ms
  18. {
  19.    unsigned char x,y;
  20.    x=3;
  21.    while(x--)
  22.   {
  23.      y=40;
  24.      while(y--);
  25.   }
  26. }
  27. void delay_1us(unsigned char i) //i=1, 5us; i=2,7us; i=3,9us
  28. {
  29.     while(--i);
  30. }*/
  31. void delay_50us(unsigned int t) // t=100, 5ms; t=1000, 50ms
  32. {
  33. unsigned char j;
  34. for(;t>0;t--)
  35.   for(j=19;j>0;j--);
  36. }
  37. /*void delay_50ms(unsigned int t) // t=10, 500ms; t=100, 5s;
  38. {
  39. unsigned int j;
  40. for(;t>0;t--)
  41.   for(j=6245;j>0;j--);
  42. }*/
  43. void display(void)
  44. {
  45.   Write_Comm(0x01); //清顯示屏
  46.   Write_Comm(0x80);
  47.   Write_Data(Anum_code[qian]);
  48.   //Write_Comm(0x80);
  49.   Write_Data(Anum_code[bai]);
  50.   //Write_Comm(0x80);
  51.   Write_Data(Anum_code[shi]);
  52.   //Write_Comm(0x83);
  53.   Write_Data(Anum_code[ge]);
  54. }
  55. void work(void)
  56. {
  57.   //unsigned char qian,bai,shi,ge;
  58.   float value;
  59.   value=(high*256+low)*17/100;
  60.   qian=value/1000;
  61.   bai=(value-qian*1000)/100;
  62.   shi=(value-qian*1000-bai*100)/10;
  63.   ge=value-qian*1000-bai*100-shi*10;
  64.   if(value<=1000)
  65.   {
  66.     BEEP=0;
  67.   }
  68.   else
  69.   {
  70.     BEEP=1;
  71.   }
  72.   /*disbuf[0] = qian;
  73.   disbuf[1] = bai;
  74.   disbuf[2] = shi;
  75.   disbuf[3] = ge;*/
  76. }
  77. main()
  78. {
  79.   //unsigned char i;
  80.   //unsigned int t;
  81.   Lcd_Init();
  82.   TMOD = 0x11;
  83.   TH0 =  0;
  84.   TL0 = 0;
  85.   TH1 = 0;
  86.   TL1 = 0;
  87.   P0 = 0xff;
  88.   P1 = 0xff;
  89.   P2 = 0xff;
  90.   P3 = 0xff;
  91.   //EX0 = 1;         //允許外部中斷0
  92.   ET1 = 1;         //允許定時器1中斷
  93.   EA = 1;
  94.   TR1 = 1;
  95.   while(1)
  96. {
  97.   //display();
  98.   if(flag)
  99.   {
  100.     EA = 0;
  101.     work();
  102.     //EA = 0;
  103.     display();
  104.         //delay_50ms(100);
  105.         //for(i=5;i>0;i--)
  106.        //for(t=6245;t>0;t--);
  107.     flag = 0;
  108.     ET0 = 0;        //禁止定時器0中斷
  109.     TH0 = 0;
  110.     TL0 = 0;
  111.     ET1 = 1;
  112.         TR1 = 1;
  113.     EA = 1;
  114.   }
  115. }
  116. }
  117. void INTT1() interrupt 3
  118. {
  119.   unsigned char i;
  120.   EA = 0;
  121.   TR1 = 0;
  122.   EX0 = 0;           //禁止外部中斷
  123.   TH0 = 0;
  124.   TL0 = 0;
  125.   TH1 = 0;
  126.   TL1 = 0;
  127.   EA = 1;
  128.   TR0 = 1;
  129.   for(i=0;i<4;i++)
  130.    {
  131.      vout = ~vout;
  132.      _nop_();
  133.      _nop_();
  134.      _nop_();
  135.      _nop_();
  136.      _nop_();
  137.      _nop_();
  138.      _nop_();
  139.      _nop_();
  140.    }
  141.    delay_50us(40);
  142.    EX0 = 1;        //開啟外部中斷
  143.    //ET0 = 1;          //允許定時器0中斷
  144.    /*if(j==600)
  145.    {
  146.    j=j+200;
  147.    TR0 = 1;
  148.    EX0 = 1;        //開啟外部中斷
  149.    delay_50us(j);
  150.    INT=0;
  151.    }
  152.    else
  153.    {
  154.    j=j-200;
  155.    TR0 = 1;
  156.    EX0 = 1;        //開啟外部中斷
  157.    delay_50us(j);
  158.    INT=0;
  159.    }*/
  160.
  161. }
  162. void PINT0() interrupt 0
  163. {
  164.   //_nop_();
  165.   TR0 = 0;       //關閉定時器0
  166.   EX0 = 0;
  167.   EA = 0;
  168.   low = TL0;
  169.   high = TH0;
  170. ……………………
  171. …………限于本文篇幅 余下代碼請從51黑下載附件…………
超聲波測距及報警程序.rar (67.67 KB, 下載次數: 166)
收藏收藏2 分享淘帖 頂 踩
ID:296658 發表于 2018-3-25 14:07 | 只看該作者
可以講解下嗎
ID:296658 發表于 2018-3-25 14:33 | 只看該作者
謝謝拉】
ID:296923 發表于 2018-3-25 20:49 | 只看該作者
學習學習 支持一下
ID:296658 發表于 2018-3-26 11:05 | 只看該作者
可以外加個蜂鳴器嗎
ID:449337 發表于 2018-12-20 20:50 | 只看該作者
正好最近需要
ID:442022 發表于 2018-12-20 21:12 | 只看該作者
正好需要學習。謝謝樓主
ID:895873 發表于 2021-3-25 09:20 | 只看該作者
能給講解一下嗎?
