查看: 2371|回復: 1
串口通信匯編代碼
ID:272488 發(fā)表于 2018-1-6 21:48 | 顯示全部樓層 |閱讀模式
ORG 0000H
BUFS EQU 30H
BUFR EQU 50H
NUMB EQU 10H
SUMS EQU 7EH
SUMR EQU 7FH
MAIN:
        LCALL InitArray
        LCALL DELAY
        LCALL InitUart
MAIN2:
        JB P1.0,SEND
        LCALL RECEIVE
HERE:
        SJMP HERE
SEND:
        LCALL SEND1
HERE1:
        SJMP HERE1
InitArray:
        MOV R2,#NUMB
        MOV R0,#BUFS
        MOV A,#00H
LOOP:
        MOV @R0,A
        INC R0
        INC A
        DJNZ R2,LOOP
        RET
InitUart:
        MOV SCON,#50H
        MOV TMOD,#20H
        MOV PCON,#00H
        MOV TH1,#0FDH
        MOV TCON,#40H
        RET
SEND1:
        MOV P2,#0AAH
        MOV SBUF,#0AAH
LOOP1:
        JNB TI,LOOP1
        CLR TI
LOOP2:
        JNB RI,LOOP2
        CLR RI
        MOV A,SBUF
        CJNE A,#0BBH,LOOP2
        MOV P2,#0BBH
        LCALL DELAY
SEND2:
        MOV SUMS,#00H
        MOV R0,#BUFS
        MOV R2,#NUMB
LOOP3:
        MOV A,@R0
        MOV P2,A
        LCALL DELAY
        MOV SBUF,A
LOOP4:
        JNB TI,LOOP4
        CLR TI
        ADD A,SUMS
        MOV SUMS,A
        INC R0;
        DJNZ R2,LOOP3
LOOP5:
        JB P1.7,LOOP6
        ADD A,#01H
        MOV SUMS,A
LOOP6:
        MOV P2,A
        LCALL DELAY
        MOV SBUF,A
LOOP7:
        JNB TI,LOOP7
        CLR TI
LOOP8:
        JNB RI,LOOP8
        CLR RI
        MOV P2,SBUF
        LCALL DELAY
        MOV A,SBUF
        CJNE A,#00H,LOOP9
ENDS:
        RET
LOOP9:
        LJMP SEND2
RECEIVE:
        JNB RI,RECEIVE
        CLR RI
        MOV P2,SBUF
        LCALL DELAY
        MOV A,SBUF
        CJNE A,#0AAH,RECEIVE
        MOV P2,#0BBH
        LCALL DELAY
        MOV SBUF,#0BBH
LOOP11:
        JNB TI,LOOP11
        CLR TI;
LOOP12:
        MOV SUMR,#00H
        MOV R1,#BUFR
        MOV R3,#NUMB
LOOP13:
        JNB RI,LOOP13
        CLR RI
        MOV P2,SBUF
        LCALL DELAY
        MOV A,SBUF
        MOV @R1,A
        ADD A,SUMR
        MOV SUMR,A
        INC R1
        DJNZ R3,LOOP13
        MOV P2,SUMR
LOOP14:
        JNB RI,LOOP14
        CLR RI
        MOV P2,SBUF
        LCALL DELAY
        MOV A,SBUF
        CJNE A,SUMR,LOOP16
        MOV P2,#00H
        LCALL DELAY
        MOV SBUF,#00H
LOOP15:
        JNB TI,LOOP15
        CLR TI;
        RET
LOOP16:
        MOV P2,#0FFH
        LCALL DELAY
        MOV SBUF,#0FFH
LOOP17:
        JNB TI,LOOP17;
        CLR TI
        LJMP LOOP12
DELAY:
        MOV R7,#04H
DL:
        MOV R6,#0FFH
DL1:
        MOV R5,#0FFH
DL5:
        DJNZ R5,DL5
        DJNZ R6,DL1
        DJNZ R7,DL
        RET
END
串口通信匯編代碼.doc
20 KB, 下載次數(shù): 13, 下載積分: 黑幣 -5
完整可運行
ID:367783 發(fā)表于 2018-9-23 18:31 | 顯示全部樓層
請問有仿真文件嗎
