提示內容:
//===================================================== Build target 'Target 1' compiling LEDtest2.C... linking... *** ERROR L121: IMPROPER FIXUP MODULE: LEDtest2.obj (LEDTEST2) SEGMENT: ABSOLUTE OFFSET: 000BH Program Size: data=12.0 xdata=0 code=210 Target not created
編譯環境是KEIL 51
源程序
#include<reg51.h> #define LED P0 #define count 50000 #define TH_M1 (65636-count)/256 #define TL_M1 (65636-count)%256 char bdata mark50; sbit mark_0=mark50^0; int intcount=0;
main() { IE=0x82; TMOD&=0xf1; TMOD|=0x01; TH0=TH_M1; TL0=TL_M1; TR0=1; LED=0xf0; while(1) { if(mark_0==1) mark_0=0; if(++intcount==5) { LED=~LED; intcount=0; } } }
//===================================================== void timer0(void)interrupt 1 { TF0=0; TH0=TH_M1; TL0=TL_M1; mark50=0xff; }
[此貼子已經被作者于2010-11-1 22:01:09編輯過]
