查看: 3720|回復: 1
單片機計算器(實現加減乘除運算)proteus仿真與源程序
單片機計算器仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include<at89x52.h>
  3. uchar LED[]={0x3f,0x60,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  4. uchar Lamp[]={0x07,0x06,0x05,0x04,0x30,0x02,0x01,0x00} ;
  5. unsigned char key=0;
  6. unsigned long int num=0;
  7. unsigned long int num_old=0;
  8. long int result=0;
  9. unsigned char res[10]={0};
  10. unsigned char pos=0;
  11. unsigned char flag=0;
  12. unsigned char hang=0,lie=0;
  13. unsigned char i=0;
  14. void delayms(unsigned char i)
  15. { unsigned char k;
  16.   while(i--)
  17.   for(k=0;k<120;k++) ;
  18. }
  19. unsigned char keycode[4][4]={{1,2,3,'*'},
  20.                              {4,5,6,'/'},
  21.                                                          {7,8,9,'C'},
  22.                                                          {0,'+','-','='}  };
  23. unsigned char keyScan()
  24. {
  25.    P1 = 0x0f;
  26.    switch(P1&0x0f)
  27.    {
  28.      case 0x0e: hang=0;break;
  29.          case 0x0d: hang=1;break;
  30.          case 0x0b: hang=2;break;
  31.          case 0x07: hang=3;break;
  32.      default: break;
  33.         }
  34.     P1 = 0xf0;
  35.         switch(P1&0xf0)
  36.         {
  37.          case 0xe0: lie=0;break;
  38.          case 0xd0: lie=1;break;
  39.          case 0xb0: lie=2;break;
  40.          case 0x70: lie=3;break;
  41.          default: break;
  42.         }
  43.     return keycode[hang][lie];
  44. }
  45. void Display(uchar DisplayNum,uchar LEDNum)
  46. {
  47. P2=Lamp[LEDNum];
  48. P0=LED[DisplayNum];
  49. delayms(3);
  50. }
  51. void T1_isr() interrupt 3
  52. {
  53. #define KEY_DOWN P1!=0x0f
  54. #define KEY_UP   P1==0x0f
  55.   static uchar flag = 0;
  56.   TH1 = (65536-50000)/256;
  57.   TL1 = (65536-50000)%256;
  58.   P1  = 0x0f;
  59.    if(flag == 0 && KEY_DOWN)
  60.      flag = 1;
  61.    else if(flag == 1 && KEY_UP)
  62.      flag = 0;
  63.    else if(flag == 1 && KEY_DOWN)
  64.    {
  65.           flag = 2;
  66.           pos++;
  67.           Display(keyScan(),pos);
  68.    }
  69.    else if(flag == 2 &&        KEY_UP)
  70.       flag = 0;
  71. }
  72. void show()
  73. {
  74.   unsigned char i=0;
  75.   if(pos==0) Display(0,0);
  76.   else
  77.   for(i=0;i<pos;i++)
  78.   {
  79.         Display(keyScan(),pos-i-1);
  80.
  81.    }
  82. }
  83. void main()
  84. {
  85.    TMOD = 0x10;
  86.    TH1  = (65536-50000)/256;
  87.    TL1  = (65536-50000)%256;
  88. ……………………
  89. …………限于本文篇幅 余下代碼請從51黑下載附件…………
新建文件夾01.rar (40.24 KB, 下載次數: 34)
ID:458161 發表于 2018-12-30 17:24 | 只看該作者
這個不能用啊
