查看: 2066|回復: 0
關于CC2430 用定時器中斷來實現秒表
ID:271566 發表于 2018-1-4 19:42 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "iocc2430.h"
#include "string.h"
#define LED3  P0_1
#define LED4  P1_4
#define LED5  P1_1
#define LED6  P1_0
void UartTX_Send_String(char *p);
void time2string(unsigned int value,char *result);
int counter;
int counter2;
char resultstr[6];
void Timer(void)
  counter=10;
  counter2=0;
  UartTX_Send_String("\r\n進入秒表,按任意鍵開始計時\r\n");
  P0DIR =  P0DIR | 0x02;// 0000 0010設置p0_1引腳為輸出
  P1DIR =  P1DIR | 0x13;// 0001 0011設置p1_0、p1_1、p1_4、引腳為輸出
  LED3=0;
  LED4=0;
  LED5=0;
  LED6=0;//初始熄滅指示燈LED6
  T1CTL = 0x0a;        //0000 1010單片機時鐘頻率16MHz,32分頻后是500 000Hz;自動重裝模式(0->T1CC0中的計數值);
  T1CC0L = 0x50;//計數次數50000 = 0xc350
  T1CC0H = 0xc3;//計數次數50000 = 0xc350
  //定時器中斷頻率是200 000/ 50 000 = 10Hz
  while(URX0IF == 0);
  URX0IF = 0; //清標識
  T1IE = 1;   //T1中斷使能
  EA   = 1;   //系統中斷使能
  UartTX_Send_String("\r\n計時中……\r\n");
  while(URX0IF == 0);
  URX0IF = 0; //清標識
  EA   = 0;   //關閉系統中斷
  T1IE = 0;   //關閉T1中斷
  time2string(counter2, resultstr);
  UartTX_Send_String("\r\n本次計數值:");
  UartTX_Send_String(resultstr);
  UartTX_Send_String(" 秒\r\n");
  UartTX_Send_String("\r\n退出秒表\r\n");
  LED3=0;
  LED4=0;
  LED5=0;
  LED6=0;
/*定時器每過0.1秒溢出一次*/
#pragma vector=T1_VECTOR
__interrupt void T1_ISR(void)
  counter--;
  if(counter%10==0)
    counter2++;
    if(counter2%1==0)
      LED3=!LED3;        //LED3亮滅切換
    if(counter2%2==0)
      LED4=!LED4;        //LED4亮滅切換
    if(counter2%4==0)
      LED5=!LED5;        //LED5亮滅切換
    if(counter2%8==0)
      LED6=!LED6;        //LED6亮滅切換
  unsigned int i,j;
  char temp[6];
  i=0;
  while(value!=0)
    temp[i]='0'+(value%10);
    value  = value/10;
    i++;
  j=0;
  while(i!=0)
   result[j++]=temp[--i];
  result[j]='\0';
