查看: 6454|回復: 13
16x16點陣可實現拉幕,滾動交替等多種花樣顯示(單片機源程序+原理圖)制作資料包
ID:254297 發表于 2018-1-4 18:48 | 顯示全部樓層 |閱讀模式
這是我前段時間制作的16*16點陣屏。還有很多實用實例,總之很實用。
現上傳給大家,共同分享。
各種花樣顯示效果的源碼(交替顯示,拉幕式方式顯示,顯示數字,向上滾動顯示,歡迎光臨等等):
滿足先悅電子接口方法
//IO配置
sbit D_port = P1^7;
sbit C_port = P1^6;
sbit B_port = P1^5;
sbit A_port = P1^4;
sbit EN_port = P1^3;
sbit S_IN_port = P1^2;
sbit RCK_port = P1^1;
sbit SRCK_port = P1^0;
如果程序里面有說明使用的晶體頻率跟單片機芯片型號的,請按照要求使用,如果沒有要求的,可以使用任何51內核的單片機。
因為AT89S51,AT89S52,AT89C51,AT89C52的RAM只有128,里面的程序有很多個是要求使用256以上RAM的,因此建議你使用STC
系列的單片機。
僅供焊接完進行點陣測試用。
16*16電子的電路原理圖:
  1. /*字取模方法請參考本目錄圖片說明*/
  2. /*頭文件*/
  3. #include <reg52.h>
  4. #include <intrins.h>
  5. #define uint unsigned int
  6. #define uchar unsigned char
  7. #define _Nop() _nop_()
  8. /*端口定義*/
  9. sbit D_port    = P1^7;
  10. sbit C_port    = P1^6;
  11. sbit B_port    = P1^5;
  12. sbit A_port    = P1^4;
  13. sbit EN_port   = P1^3;
  14. sbit S_IN_port = P1^2;
  15. sbit RCK_port  = P1^1;
  16. sbit SRCK_port = P1^0;
  17. uchar code table[]={
  18. 0xFF,0xFC,0xFF,0xFC,0x80,0xFC,0x9F,0x80,0x1F,0x9E,0x49,0xCE,0x03,0xF9,0x87,0xF9,
  19. 0xE7,0xF9,0xC3,0xF0,0x93,0xF0,0x19,0xE6,0x7C,0xE6,0x3F,0xCF,0x9F,0x9F,0xCF,0x3F,/*"歡",0*/
  20. 0xFF,0xFF,0xF3,0xFC,0x27,0x82,0x27,0x93,0x3F,0x93,0x3F,0x93,0x20,0x93,0x27,0x93,
  21. 0x27,0x93,0x27,0x80,0x27,0xC2,0x27,0xF3,0xE7,0xF3,0xC3,0xF3,0x19,0x00,0xFF,0xFF,/*"迎",0*/
  22. 0x7F,0xFE,0x73,0xCE,0x67,0xCE,0x4F,0xE6,0x4F,0xF2,0x7F,0xFE,0x00,0x00,0x9F,0xF9,
  23. 0x9F,0xF9,0x9F,0xF9,0x9F,0xF9,0xCF,0x39,0xCF,0x39,0xE7,0x39,0xF3,0x03,0xF8,0xFF,/*"光",1*/
  24. 0xCF,0xFC,0xCF,0xFC,0xCF,0xFC,0x49,0x00,0x49,0xF8,0x09,0xF3,0x89,0xF3,0xC9,0xFF,
  25. 0x49,0x80,0x49,0x92,0x49,0x92,0x49,0x92,0x49,0x92,0x4F,0x80,0x4F,0x9E,0xCF,0xFF,/*"臨",2*/
  26.
  27. };
  28. /*-------------------------------------------------------
  29.     點陣LED第幾行顯示數據
  30.    其中daH為數據高8位,daL為數據低8位,han為第幾行顯示
  31. --------------------------------------------------------*/
  32. void HC595_Data_Send(uchar daH,daL,han)
  33. {
  34.         uchar i;
  35.         RCK_port = 0;  /*HC595鎖定輸出,避免數據傳輸過程中,屏數據變化從而顯示閃爍*/
  36.         SRCK_port = 0;
  37.         for(i=0;i<8;i++){
  38.                 if((daH&0x80)!=0) S_IN_port = 1;
  39.                 else S_IN_port = 0;
  40.                 SRCK_port = 1;
  41.                 SRCK_port = 0;
  42.                 daH <<= 1;
  43.                 }
  44.         for(i=0;i<8;i++){
  45.                 if((daL&0x80)!=0) S_IN_port = 1;
  46.                 else S_IN_port = 0;
  47.                 SRCK_port = 1;
  48.                 SRCK_port = 0;
  49.                 daL <<= 1;
  50.                 }
  51.         EN_port = 1; /*關屏顯示,原理為使HC138輸出全為1,從而三極管截止,點陣不顯示*/
  52.         switch (han){
  53.                 case 0:
  54.                         A_port = 0;        B_port = 0;        C_port = 0;        D_port = 0;
  55.                         break;
  56.                 case 1:
  57.                         A_port = 1;        B_port = 0;        C_port = 0;        D_port = 0;
  58.                         break;
  59.                 case 2:
  60.                         A_port = 0;        B_port = 1;        C_port = 0;        D_port = 0;
  61.                         break;
  62.                 case 3:
  63.                         A_port = 1;        B_port = 1;        C_port = 0;        D_port = 0;
  64.                         break;
  65.                 case 4:
  66.                         A_port = 0;        B_port = 0;        C_port = 1;        D_port = 0;
  67.                         break;
  68.                 case 5:
  69.                         A_port = 1;        B_port = 0;        C_port = 1;        D_port = 0;
  70.                         break;
  71.                 case 6:
  72.                         A_port = 0;        B_port = 1;        C_port = 1;        D_port = 0;
  73.                         break;
  74.                 case 7:
  75.                         A_port = 1;        B_port = 1;        C_port = 1;        D_port = 0;
  76.                         break;
  77.                 case 8:
  78.                         A_port = 0;        B_port = 0;        C_port = 0;        D_port = 1;
  79.                         break;
  80.                 case 9:
  81.                         A_port = 1;        B_port = 0;        C_port = 0;        D_port = 1;
  82.                         break;
  83.                 case 10:
  84.                         A_port = 0;        B_port = 1;        C_port = 0;        D_port = 1;
  85.                         break;
  86.                 case 11:
  87.                         A_port = 1;        B_port = 1;        C_port = 0;        D_port = 1;
  88.                         break;
  89.                 case 12:
  90.                         A_port = 0;        B_port = 0;        C_port = 1;        D_port = 1;
  91.                         break;
  92.                 case 13:
  93.                         A_port = 1;        B_port = 0;        C_port = 1;        D_port = 1;
  94.                         break;
  95.                 case 14:
  96.                         A_port = 0;        B_port = 1;        C_port = 1;        D_port = 1;
  97.                         break;
  98.                 case 15:
  99.                         A_port = 1;        B_port = 1;        C_port = 1;        D_port = 1;
  100.                         break;
  101.                 }
  102.         RCK_port = 1; /*允許HC595數據輸出到Q1-Q8端口*/
  103.         EN_port = 0; /*HC138輸出有效,打開顯示*/
  104.         RCK_port = 0;        /*鎖定HC595數據輸出*/
  105. }
  106. void delay_1ms(uchar x)
  107. {
  108.     uchar j;
  109.     while(x--){
  110.         for(j=0;j<15;j++)
  111.             {;}
  112.         }
  113. }
  114. void main()
  115. {
  116.         uint i;
  117.         uchar j=0; /*讀取對應的第幾行數據*/
  118.         uchar k=0; /*讀取對應的第幾個字數據*/
  119.         while (1){
  120.                 for(i=0;i<3000;i++){
  121.                         HC595_Data_Send(table[(k*16+j)*2+1],table[(k*16+j)*2],j);
  122.                         j++; /*行加1*/
  123.                         if(j==16) j=0;
  124.                         delay_1ms(1);
  125.                         }
  126.                 k++; /*字加1*/
  127.                 if(k==4) k=0;
  128.                 }
  129. }
  130. ……………………
  131. …………限于本文篇幅 余下代碼請從51黑下載附件…………
16x16點陣套件資料包.rar (15.84 MB, 下載次數: 128)
ID:1 發表于 2018-1-9 02:19 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:268196 發表于 2018-1-10 20:12 | 顯示全部樓層
樓主你好,點陣左邊接三極管是為了放大電流嗎?還是別的什么
ID:225216 發表于 2018-1-10 21:04 | 顯示全部樓層
admin 發表于 2018-1-9 02:19
好資料,51黑有你更精彩!!!
管理員很敬業,幾乎每篇帖子都要回。您也是電子愛好者嗎?能否加個QQ?
ID:267327 發表于 2018-1-10 21:25 | 顯示全部樓層
牛。這個可以有。
ID:265553 發表于 2018-1-14 07:51 來自觸屏版 | 顯示全部樓層
好資料,51黑有你更精彩
ID:248486 發表于 2018-3-3 16:16 | 顯示全部樓層
三極管實現時經常卡機,不過還好
ID:140489 發表于 2018-4-9 15:06 | 顯示全部樓層
下載了,仿真了一下,可以的,就是左移、右移沒有源程序,樓主把左移、右移沒有源程序也共享一下唄
ID:299231 發表于 2018-4-9 22:18 | 顯示全部樓層
掙夠了幣再來下載吧,先mark
ID:326016 發表于 2018-5-9 18:30 | 顯示全部樓層
為啥我沒有找到仿真設計呢?
ID:293762 發表于 2018-5-9 21:51 | 顯示全部樓層
學習中……謝謝樓主的分享!
ID:290014 發表于 2018-5-10 15:05 | 顯示全部樓層
看看看,好資料
ID:669659 發表于 2019-12-21 11:21 | 顯示全部樓層
有參考價值,謝謝大佬
ID:669652 發表于 2019-12-21 11:49 | 顯示全部樓層
感謝樓主分享,正在學習中
