附件是基于proteus的電子負(fù)載仿真,主控芯片是AVR。
ElectronicLoad-master
2018-1-2 02:24 上傳
2018-1-2 02:25 上傳
2018-1-2 02:26 上傳
Arduino單片機(jī)源程序如下:
- #define DEBUG
- #include <LiquidCrystal.h>
- #include <Encoder.h>
- #include "variables.h"
- #include "lcd.h"
- #include "pwm16Bit.h"
- #include "iSet.h"
- #include "timer2.h"
- #include "misc.h"
- #include "voltageAndCurrentSensors.h"
- void setup() {
- #ifdef DEBUG
- Serial.begin(115200);
- #endif
- //ILOAD_PIN as PWM output
- setupPWM16();
- //Configure TIMER2 so that it calls ISR(TIMER2_COMPA_vect) @ 500Hz (every 2mS)
- //ISR(TIMER2_COMPA_vect) is used to update CC waveforms
- setupTimer2();
- //LCD Setup
- lcd.begin(16, 2);
- lcd.print("ElectronicLoad");
- lcd.setCursor(0,1);
- lcd.print(" [Version 1.07]");
- lcd.createChar(0, ohm);
- lcd.createChar(1, vLoad);
- lcd.createChar(2, iLoad);
- lcd.createChar(3, hi);
- lcd.createChar(4, lo);
- delay(1500);
- //Button and Led pinmode setup
- pinMode(OUTPUT, outputEnabledLed);
- pinMode(INPUT, encBtn);
- digitalWrite(encBtn, HIGH); //Enable internal pullup
- pinMode(INPUT, modeSelectorBtn);
- digitalWrite(modeSelectorBtn, HIGH); //Enable internal pullup
- pinMode(INPUT, outputEnableBtn);
- digitalWrite(outputEnableBtn, HIGH); //Enable internal pullup
- //ISet calibration (Finds a proper ISetOneAmp value where IL=1A)
- //calibrateISet();
- ISetOneAmp=14280;
- resetLcdToDefault();
- lcd.setCursor(0, 0);
- lcd.write("C.Cur:");
- void loop() {
- if(mode == CONSTANT_CURRENT) {
- int encoderPos = getEncoderMovement(); //getEncoderMovement() returns either -1, 0 or 1
- if(encoderPos > 0 && ISetVal < ISET_CC_MAX) //Encoder incremented
- ISetVal+=ISET_CC_STEP;
- else if (encoderPos < 0 && ISetVal >= ISET_CC_STEP) //Encoder decremented
- ISetVal-=ISET_CC_STEP;
- lcd.setCursor(0, 1);
- lcdPrintIntWhitespace(ISetVal, 4);
- lcd.print(ISetVal);
- lcd.write("mA");
- if(mode == CONSTANT_RESISTANCE) {
- byte encoderPos = getEncoderMovement(); //getEncoderMovement() returns either -1, 0 or 1
- if(encoderPos > 0 && ISetVal < ISET_CR_MAX) //Encoder incremented
- ISetVal+=ISET_CR_STEP;
- else if (encoderPos < 0 && ISetVal >= ISET_CR_MIN) //Encoder decremented
- ISetVal-=ISET_CR_STEP;
- lcd.write(byte(0)); //ohm char
- if(mode == CONSTANT_POWER) {
- if(encoderPos > 0 && ISetVal < ISET_CP_MAX) //Encoder incremented
- ISetVal+=ISET_CP_STEP;
- else if (encoderPos < 0 && ISetVal >= ISET_CP_STEP) //Encoder decremented
- ISetVal-=ISET_CP_STEP;
- lcd.write("mW");
- if(mode == SQUARE_CURRENT) {
- int encoderPos = getEncoderMovement(); //encoderPos is either -1, 0 or 1
- if(encoderPos != 0) { //Encoder changed
- switch(SCCurrentParam) {
- case SC_PARAM_IHI:
- if(encoderPos > 0 && ISetSCIHi < ISET_SC_IMAX)
- ISetSCIHi += ISET_SC_I_STEP;
- else if(encoderPos < 0 && ISetSCIHi >= ISET_SC_I_STEP && ISetSCIHi > ISetSCILo)
- ISetSCIHi -= ISET_SC_I_STEP;
- break;
- case SC_PARAM_ILO:
- if(encoderPos > 0 && ISetSCILo < ISET_SC_IMAX && ISetSCILo < ISetSCIHi)
- ISetSCILo += ISET_SC_I_STEP;
- else if(encoderPos < 0 && ISetSCILo >= ISET_SC_I_STEP)
- ISetSCILo -= ISET_SC_I_STEP;
- break;
- case SC_PARAM_THI:
- if(encoderPos > 0 && ISetSCTHi < ISET_SC_TMAX)
- ISetSCTHi += ISET_SC_T_STEP;
- else if(encoderPos < 0 && ISetSCTHi >= ISET_SC_T_STEP)
- ISetSCTHi -= ISET_SC_T_STEP;
- break;
- case SC_PARAM_TLO:
- if(encoderPos > 0 && ISetSCTLo < ISET_SC_TMAX)
- ISetSCTLo += ISET_SC_T_STEP;
- else if(encoderPos < 0 && ISetSCTLo >= ISET_SC_T_STEP)
- ISetSCTLo -= ISET_SC_T_STEP;
- break;
- lcd.write("I");
- lcd.write(byte(3));
- lcdPrintIntWhitespace(ISetSCIHi, 4);
- lcd.print(ISetSCIHi);
- lcd.write("mA");
- break;
- lcd.write("I");
- lcd.write(byte(4));
- lcdPrintIntWhitespace(ISetSCILo, 4);
- lcd.print(ISetSCILo);
- lcd.write("mA");
- break;
- lcd.write("T");
- lcdPrintIntWhitespace(ISetSCTHi, 4);
- lcd.print(ISetSCTHi);
- lcd.write("mS");
- break;
- lcd.write("T");
- lcdPrintIntWhitespace(ISetSCTLo, 4);
- lcd.print(ISetSCTLo);
- lcd.write("mS");
- break;
- if(mode == TRIANGLE_CURRENT) {
- switch(TCCurrentParam) {
- case TC_PARAM_IHI:
- if(encoderPos > 0 && ISetTCIHi < ISET_TC_IMAX)
- ISetTCIHi += ISET_TC_I_STEP;
- else if(encoderPos < 0 && ISetTCIHi >= ISET_SC_I_STEP && ISetTCIHi > ISetTCILo)
- ISetTCIHi -= ISET_TC_I_STEP;
- break;
- case TC_PARAM_ILO:
- if(encoderPos > 0 && ISetTCILo < ISET_TC_IMAX && ISetTCILo < ISetTCIHi)
- ISetTCILo += ISET_TC_I_STEP;
- else if(encoderPos < 0 && ISetTCILo >= ISET_TC_I_STEP)
- ISetTCILo -= ISET_TC_I_STEP;
- break;
- case TC_PARAM_THI:
- if(encoderPos > 0 && ISetTCTHi < ISET_TC_TMAX)
- ISetTCTHi += ISET_TC_T_STEP;
- else if(encoderPos < 0 && ISetTCTHi >= ISET_TC_T_STEP)
- ISetTCTHi -= ISET_TC_T_STEP;
- break;
- case TC_PARAM_TLO:
- if(encoderPos > 0 && ISetTCTLo < ISET_TC_TMAX)
- ISetTCTLo += ISET_TC_T_STEP;
- else if(encoderPos < 0 && ISetTCTLo >= ISET_TC_T_STEP)
- ISetTCTLo -= ISET_TC_T_STEP;
- break;
- lcd.write("I");
- lcdPrintIntWhitespace(ISetTCIHi, 4);
- lcd.print(ISetTCIHi);
- lcd.write("mA");
- break;
- lcd.write("I");
- lcdPrintIntWhitespace(ISetTCILo, 4);
- lcd.print(ISetTCILo);
- lcd.write("mA");
- break;
- lcd.write("T");
- lcdPrintIntWhitespace(ISetTCTHi, 4);
- lcd.print(ISetTCTHi);
- lcd.write("mS");
- break;
- lcd.write("T");
- lcdPrintIntWhitespace(ISetTCTLo, 4);
- lcd.print(ISetTCTLo);
- lcd.write("mS");
- break;
- if(mode == SINE_CURRENT) {
- switch(SNCCurrentParam) {
- case SNC_PARAM_IHI:
- if(encoderPos > 0 && ISetSNCIHi < ISET_SNC_IMAX)
- ISetSNCIHi += ISET_SNC_I_STEP;
- else if(encoderPos < 0 && ISetSNCIHi >= ISET_SNC_I_STEP && ISetSNCIHi > ISetSNCILo)
- ISetSNCIHi -= ISET_SNC_I_STEP;
- break;
- case SNC_PARAM_ILO:
- if(encoderPos > 0 && ISetSNCILo < ISET_SNC_IMAX && ISetSNCILo < ISetSNCIHi)
- ISetSNCILo += ISET_SNC_I_STEP;
- else if(encoderPos < 0 && ISetSNCILo >= ISET_SNC_I_STEP)
- ISetSNCILo -= ISET_SNC_I_STEP;
- break;
- case SNC_PARAM_T:
- if(encoderPos > 0 && ISetSNCT < ISET_SNC_TMAX)
- ISetSNCT += ISET_SNC_T_STEP;
- else if(encoderPos < 0 && ISetSNCT >= ISET_SNC_T_STEP)
- ISetSNCT -= ISET_SNC_T_STEP;
- break;
- lcd.write("I");
- lcdPrintIntWhitespace(ISetSNCIHi, 4);
- lcd.print(ISetSNCIHi);
- lcd.write("mA");
- break;
- lcd.write("I");
- lcdPrintIntWhitespace(ISetSNCILo, 4);
- lcd.print(ISetSNCILo);
- lcd.write("mA");
- break;
- case SNC_PARAM_T:
- lcd.write("T:");
- lcdPrintIntWhitespace(ISetSNCT, 4);
- lcd.print(ISetSNCT);
- lcd.write("mS");
- break;
- //Always update and print VLoad and ILoad
- updateVLoad();
- updateILoad();
- printVLoadAndILoad();
- //Handle Mode change button press
- if(digitalRead(modeSelectorBtn) == LOW) {
- handleModeSelection();
- //Prevent double triggering?
- delay(400);
- //Handle Output Enable/Disable button press
- if(digitalRead(outputEnableBtn) == LOW) {
- outputEnabled = !outputEnabled;
- if(outputEnabled) {
- digitalWrite(outputEnabledLed, HIGH);
- enableTimer2();
- } else {
- digitalWrite(outputEnabledLed, LOW);
- disableTimer2();
- writeISet(0);
- delay(400);
- //Handle Encoder button press (toggle parameter change)
- if(digitalRead(encBtn) == LOW) {
- SCCurrentParam = SC_PARAM_ILO; break;
- SCCurrentParam = SC_PARAM_THI; break;
- SCCurrentParam = SC_PARAM_TLO; break;
- SCCurrentParam = SC_PARAM_IHI; break;
- } else if(mode == TRIANGLE_CURRENT) {
- TCCurrentParam = TC_PARAM_ILO; break;
- TCCurrentParam = TC_PARAM_THI; break;
- TCCurrentParam = TC_PARAM_TLO; break;
- TCCurrentParam = TC_PARAM_IHI; break;
- } else if(mode == SINE_CURRENT) {
- SNCCurrentParam = SNC_PARAM_ILO; break;
- SNCCurrentParam = SNC_PARAM_T; break;
- case SNC_PARAM_T:
- SNCCurrentParam = SNC_PARAM_IHI; break;
- delay(200);
- //A little delay for good luck
- delay(100);
ElectronicLoad-master.zip
(154.42 KB, 下載次數(shù): 62)
2018-1-1 08:22 上傳
點(diǎn)擊文件名下載附件
電子負(fù)載 下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
