#include <reg52.h> #define uchar unsigned char /uchar 無符號字符型 unsigned 無符號的 #define uint unsigned int #define ulong unsigned long unsigned char i=100; unsigned char j,k,temp,key; sbit row1=P2^5; //行端口定義 sbit row2=P2^4; sbit row3=P2^3; sbit row4=P2^2; sbit col1=P1^7; //列端口定義 sbit col2=P1^6; sbit col3=P2^0; sbit col4=P2^1; sbit speak=P3^2; sbit datacs=P2^6; sbit chipcs=P2^7; unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d, 0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};//共陰數(shù)碼管顯示段碼0~9 /*數(shù)碼管顯示函數(shù)*/ uchar th0_f; //在中斷中裝載的 T0 的值高 8 位 uchar tl0_f; //在中斷中裝載的 T0 的值低 8 位 //T0 的值,及輸出頻率對照表 uchar code freq[36*2]={ 0xA9,0xEF,//00220HZ ,1 //0 0x93,0xF0,//00233HZ ,1# 0x73,0xF1,//00247HZ ,2 0x49,0xF2,//00262HZ ,2# 0x07,0xF3,//00277HZ ,3 0xC8,0xF3,//00294HZ ,4 0x73,0xF4,//00311HZ ,4# 0x1E,0xF5,//00330HZ ,5 0xB6,0xF5,//00349HZ ,5# 0x4C,0xF6,//00370HZ ,6 0xD7,0xF6,//00392HZ ,6# 0x5A,0xF7,//00415HZ ,7 0xD8,0xF7,//00440HZ 1 //12 0x4D,0xF8,//00466HZ 1# //13 0xBD,0xF8,//00494HZ 2 //14 0x24,0xF9,//00523HZ 2# //15 0x87,0xF9,//00554HZ 3 //16 0xE4,0xF9,//00587HZ 4 //17 0x3D,0xFA,//00622HZ 4# //18 0x90,0xFA,//00659HZ 5 //19 0xDE,0xFA,//00698HZ 5# //20 0x29,0xFB,//00740HZ 6 //21 0x6F,0xFB,//00784HZ 6# //22 0xB1,0xFB,//00831HZ 7 //23 0xEF,0xFB,//00880HZ `1 0x2A,0xFC,//00932HZ `1# 0x62,0xFC,//00988HZ `2 0x95,0xFC,//01046HZ `2# 0xC7,0xFC,//01109HZ `3 0xF6,0xFC,//01175HZ `4 0x22,0xFD,//01244HZ `4# 0x4B,0xFD,//01318HZ `5 0x73,0xFD,//01397HZ `5# 0x98,0xFD,//01480HZ `6 0xBB,0xFD,//01568HZ `6# 0xDC,0xFD,//01661HZ `7 //35 }; unsigned char v,b,n,m; void delay100ms() //延時函數(shù) {
