查看: 3041|回復: 4
求教arduino的l293d馬達板如何用在51單片機上
ID:264258 發表于 2017-12-28 19:05 | 顯示全部樓層 |閱讀模式
本帖最后由 asuraaxllxc 于 2017-12-28 19:33 編輯
如題,在做arduino的時候買了一塊l293d板子,現在想要用51單片機來控制這個板子,該怎么做?
我原來認為只要將對應的引腳連在io口上,vcc,gnd連起來就可以了,但是實際上卻發現這個板子上還有74HC595N芯片,引腳并不是直接連l293d芯片。而是通過74HC595N芯片,這樣該怎么做?此外板子的vcc,gnd有多少個在哪里怎么連我真的搞不清啊
感激不盡!
ID:264258 發表于 2017-12-28 21:47 | 顯示全部樓層
自頂
不要沉啊Σ(っ °Д °;)っ
不要沉啊Σ(っ °Д °;)っ
不要沉啊Σ(っ °Д °;)っ
大神們幫幫忙啊
ID:242623 發表于 2017-12-29 02:15 | 顯示全部樓層
建議先看看595的例子,這個是串行輸入,八位并行輸出的,
#include<reg51.h>
#include<intrins.h>
#defineNOP()_nop_()
sbitMOSIO=P3^7;
sbitR_CLK=P3^5;
sbitS_CLK=P3^6;
sbiten573=P1^3;
sbitends=P1^2;
voidHC595SendData(unsignedintSendVal);
unsignedintVal;
unsignedcharcodetab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsignedcharcodedigittab[18][8]={
{0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00},//0
{0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00},//1
{0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00},//2
{0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00},//3
{0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00},//4
{0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00},//5
{0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00},//6
{0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00},//7
{0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00},//8
{0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00},//9
{0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00},//P
{0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00},//R
{0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00},//E
{0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00},//C
{0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00},//H
{0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00},//I
{0x00,0x7F,0x10,0x08,0x04,0x7F,0x00,0x00},//N
{0x7C,0x48,0x48,0xFF,0x48,0x48,0x7C,0x00}
unsignedinttimecount;
unsignedcharcnta;
unsignedcharcntb;
voidmain(void)
TMOD=0x01;
TH0=(65536-3000)/256;
TL0=(65536-3000)%256;
TR0=1;
ET0=1;
EA=1;
cntb=0;
ends=0;
en573=0;
voidt0(void)interrupt1using0
if(cntb<18)/
{//P1=0xFF;
//P2=tab[cnta];
P0=~digittab[cntb][cnta];
Val=tab[cnta]&0x00ff;
Val<<=8;
Val=Val+0x00ff;
HC595SendData(Val);
{//P2=0xFF;
//P1=tab[cnta];
P0=~digittab[cntb-18][cnta];
Val=tab[cnta];
Val=Val+0xFF00;
HC595SendData(Val);
if(++cnta>=8)cnta=0;
if(++timecount>=333)
{timecount=0;
if(++cntb>=36)cntb=0;
{unsignedchari;
for(i=0;i<16;i++)
{ if((SendVal<<i)&0x8000)MOSIO=1;//setdatalinehigh0X8000
elseMOSIO=0; //MOSIO=1
S_CLK=0;
NOP();
NOP();
S_CLK=1;
R_CLK=0;//setdatalinelow
NOP();
NOP();
R_CLK=1;
盜版來的程序,你看看參考一下
ID:268706 發表于 2017-12-29 09:16 | 顯示全部樓層
不要沉啊Σ(っ °Д °;)っ
不要沉啊Σ(っ °Д °;)っ
不要沉啊Σ(っ °Д °;)っ
大神們幫幫忙啊
ID:264258 發表于 2017-12-30 09:27 | 顯示全部樓層
xjkszc 發表于 2017-12-29 02:15
#include
#include
感謝!我會去看看的,其實我還想知道兩個板子之間怎么連線
