#include <reg52.h>
# define uchar unsigned char
# define uint unsigned int
sbit wela =P2^7; //數(shù)碼管位選信號(hào)
sbit dula =P2^6; //數(shù)碼管段選信號(hào)
int time;
int W1,W2,W3,W4,W5,W6;
/*延時(shí)子函數(shù)*/
void delayms(uint time)
uint i;
for(;time>0;time--)
for(i=0;i<124;i++)
/*數(shù)碼管顯示子函數(shù)--不帶小數(shù)點(diǎn)*/
void display (int num1,int num2) // num1為顯示的位置,num2為要顯示的數(shù)字0-9
uchar code wei[]={0xdf,0xef,0xf7,0xfb,0xfd,0xfe}; //數(shù)碼管各位的碼表,為低時(shí)選中某一位
uchar code duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,}; //段選0-9的碼表,為低時(shí)某一段亮
P0=wei[num1-1];
wela=1;
wela=0;
switch(num2)
case 0: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 1: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 2: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 3: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 4: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 5: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 6: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 7: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 8: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
case 9: P0=duan[num2]; dula=1; dula=0; delayms(2); break;
/*數(shù)碼管顯示子函數(shù)--帶小數(shù)點(diǎn)*/
void display2 (int a,int b) // a為顯示的位置,b為要顯示的數(shù)字0.-9.
uchar code duan[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,}; //段選0.-9.的碼表,為低時(shí)某一段亮
P0=wei[a-1];
wela=1;
wela=0;
switch(b)
case 0: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 1: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 2: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 3: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 4: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 5: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 6: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 7: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 8: P0=duan[b]; dula=1; dula=0; delayms(2); break;
case 9: P0=duan[b]; dula=1; dula=0; delayms(2); break;
/*定時(shí)器T0初始化子函數(shù)*/
void initTimer0 (void)
TMOD = 0x01; //模式1,16位T0,定時(shí)10ms
TH0 = 0xD8; //初值
TL0 = 0xF0;
EA = 1; //開(kāi)總中斷
ET0 = 1; //允許T0中斷
TR0 = 1; //啟動(dòng)T0
/*定時(shí)器T0中斷子程序*/
void Timer0 (void) interrupt 1
int a;
time++;
a=time;
W1=a%10;a/=10;
W2=a%10;a/=10;
W3=a%6;a/=6;
W4=a%10;a/=10;
W5=a%6;a/=6;
W6=a%10;a/=10;
/*主函數(shù)*/
initTimer0(); //初始化
display (1,W1) ; //數(shù)碼管顯示
display2 (2,W2) ;
display (3,W3) ;
display2 (4,W4) ;
display (5,W5) ;
display2 (6,W6) ;
