查看: 1394|回復: 0
簡易安防聲光報警器
ID:268427 發表于 2017-12-28 16:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  • #include<reg52.h>
  • #define uchar unsigned char
  • #define uint unsigned int
  • sbit red=P1^0;
  • sbit green=P1^1;
  • sbit spe=P1^2;
  • sbit bjjc=P1^3;
  • sbit mjbj=P3^2;
  • sbit hwbj=P3^3;
  • void delay(uint ms)
  • uchar i;
  • while(ms--)
  •    {for(i=0;i<120;i++);}
  • void baojin()
  • while(1)
  • green=1;
  • red=0;
  • spe=~spe;
  • delay(100);
  • red=1;
  • delay(100);
  • if(!bjjc)
  • break;
  • if(!mjbj&&!hwbj)
  • P0=0x4f;
  • void external_int0() interrupt 0
  • delay(10);
  • while(!mjbj&&hwbj)
  • P0=0x06;
  • baojin();
  • while(!mjbj&&!hwbj)
  • P0=0xb0;
  • baojin();
  • void external_int1() interrupt 2
  • delay(10);
  • while(mjbj&&!hwbj)
  • P0=0x5b;
  • baojin();
  • P0=0x4f;
  • baojin();
  • void main()
  • P0=0x00;
  • delay(100);
  • while(1)
  • P0=0x3f;
  • red=1;
  • green=0;
  • spe=1;
  • IE=0x8f;
  • IP=0x05;
