IAP15W4K61S4+MPU6050+福斯迷你PPM接收機
非得還算穩,但是抗干擾性不太行
2017-12-28 14:45 上傳
2017-12-28 22:33 上傳
- #include "sys.h"
- #include "lib.h"
- #include "myiic.h"
- #include "mpu6050.h"
- #include "ano.h"
- #include "config.h"
- #include "inertial_sensor.h"
- #include "ahrs_dcm.h"
- #include "ahrs_quat.h"
- #include "attitude_control.h"
- #include "rcin.h"
- #include "motor.h"
- //PPM
- data uint16_t ppm_start[8];
- data uint16_t ppm_value_temp[8];
- data uint16_t ppm_value[8] = {2750,2750,1500,2750,1500,1500};
- data uint8_t ppm_counter = 0;
- bit ppm_ok = 0;
- inertial_sensor_t ins;
- ahrs_quat_t ahrs_quat;
- attitude_control_t atti_ctrl;
- rcin_t rcin_roll,rcin_pitch,rcin_thr,rcin_yaw,rcin_5,rcin_6;
- motor_t apmotor;
- uint8_t t1,t2;
- void fast_loop(void);
- void arm_check_loop(void);
- void rc_loop(void);
- //手動模式
- void test_run()
- atti_ctrl.rate_bf_target.x = rcin_roll.control_in;
- atti_ctrl.rate_bf_target.y = rcin_pitch.control_in;
- atti_ctrl.rate_bf_target.z = rcin_yaw.control_in*3;
- apmotor.throttle_out = rcin_thr.control_in;
- void setup()
- inertial_sensor_init();
- ahrs_quat_init();
- attitude_control_init();
- rcin_init();
- motor_init();
- void main()
- gpio_init();
- uart_init(115200);
- timer1_init(); //10ms無中斷
- IIC_Init();
- mpu6050_init();
- pwm_init();
- pca_init();
- timer0_init(); //2ms中斷
- setup();
- while(1)
- while(!TF1);TF1=0; //100Hz
- fast_loop();
- if(ppm_ok) //50Hz
- rc_loop(); //217us
- if(++t1 == 10) //10Hz
- t1 = 0;
- arm_check_loop(); //解鎖檢測
- // ANO_DT_Send_Sensor(ahrs_quat.omega.z*100,apmotor.yaw_out,ahrs_quat.omega.x*100,apmotor.roll_pwm,0,0,0,0,0);
- // ANO_DT_Send_Status(rcin_roll.control_in,rcin_pitch.control_in,rcin_yaw.control_in,rcin_thr.control_in,0,0);
- // ANO_DT_Send_Status(ahrs_quat.roll_sensor,ahrs_quat.pitch_sensor,ahrs_quat.yaw_sensor,0,0,0);
- // ANO_DT_Send_Sensor(acceladc[0],acceladc[1],acceladc[2],gyroadc[0],gyroadc[1],gyroadc[2],0,0,0);
- // ANO_DT_Send_Sensor(rcin_thr.radio_in,rcin_thr.control_in,apmotor.throttle_pwm,0,0,0,0,0,0);
- ANO_DT_Send_Sensor(ins.gyro.x*100,ins.gyro.y*100,ins.gyro.z*100,0,0,0,0,0,0);
- // ANO_DT_Send_MotoPWM(apmotor.motor_out[0],apmotor.motor_out[1],apmotor.motor_out[2],apmotor.motor_out[3],0,0,0,0);
- void fast_loop()
- ahrs_quat_update(); //更新姿態
- rate_control_run(); //內環控制0.823ms->motor.roll_out,pitch_out,yaw_out
- motor_output(); //動力輸出
- stabilize_run(); //外環控制
- void rc_loop()
- if(ppm_ok)
- rcin_set_control(&rcin_roll,ppm_value[0]); // -> radio_in -> control_in
- rcin_set_control(&rcin_pitch,ppm_value[1]);
- rcin_set_control(&rcin_thr,ppm_value[2]);
- rcin_set_control(&rcin_yaw,ppm_value[3]);
- ppm_ok = 0;
- void arm_check_loop()
- static int16_t arming_counter = 0;
- int16_t tmp;
- if (rcin_thr.control_in > 0) //油門非0,直接退出
- arming_counter = 0;
- return;
- tmp = rcin_yaw.control_in; //方向通道值
- if (tmp > 4000) //contol_in對radio_in做了映射,最大是4500
- if (arming_counter < ARM_DELAY)
- arming_counter++;
- if (arming_counter == ARM_DELAY && !apmotor.armed) //檢測到解鎖動作2s
- init_arm_motors();
- arming_counter = 0; //解鎖成功
- else if (tmp < -4000)//上鎖
- if (arming_counter < DISARM_DELAY)
- arming_counter++;
- if (arming_counter == DISARM_DELAY && apmotor.armed)
- init_disarm_motors();//上鎖
- else//非解鎖或上鎖
- #define CNT_PER_US 2.5
- #define CNT_600US 600*CNT_PER_US //1500
- #define CNT_1100US 1100*CNT_PER_US //2750
- #define CNT_1500US 1600*CNT_PER_US //4000
- #define CNT_2500US 2500*CNT_PER_US //2000+500
- void PCA_isr() interrupt ISR_PCA using 1
- if (CCF1)
- CCF1 = 0;
- if(PPM_Pin) //上升沿
- CH = CL = 0;
- else //下降沿
- uint16_t value;
- value = (CCAP1H<<8) + CCAP1L;
- if(value > CNT_2500US)
- ppm_value[0] = ppm_value_temp[0];
- ppm_value[1] = ppm_value_temp[1];
- ppm_value[2] = ppm_value_temp[2];
- ppm_value[3] = ppm_value_temp[3];
quad51.zip
(1.16 MB, 下載次數: 74)
2017-12-28 14:44 上傳
下載積分: 黑幣 -5
