查看: 5242|回復: 1
單片機萬年歷部分程序
ID:267055 發表于 2017-12-26 13:27 | 顯示全部樓層 |閱讀模式
alarmflag=1;
//led=0;
lcdinit();//初始化液晶函數
ds1302_init();//DS1302時鐘芯片初始化函數
init();//定時器初始化函數
beep=0;
delay(200);
beep=1;
//led=0;
  year1=(nian)/10*16+(nian)%10;//轉換為bcd碼
  month1=(yue)/10*16+(yue)%10;
  day1=(ri)/10*16+(ri)%10;
  chushihua();//初始化時間函數
     Conversion(0,year1,month1,day1);//
  timealarm();//報時程序
  keyscan();//不斷掃面按鍵函數
  /*if(key2==1)//加鍵不按下時才有用
        ledcontrol();//背光控制
void timer0() interrupt 1//中斷任務:取數據并顯示
TH0=(65536-60000)/256;//重新賦初值
TL0=(65536-60000)%256;
//讀取數據
flag=ReadTemperature();//讀取溫度(考慮是否放在此處)
miao=turnBCD(read_1302(0x81));//讀出秒
fen=turnBCD(read_1302(0x83));//讀出分
shi=turnBCD(read_1302(0x85));//讀出時
ri=turnBCD(read_1302(0x87));//讀出日
yue=turnBCD(read_1302(0x89));//讀出月
nian=turnBCD(read_1302(0x8d));//讀出年
week=turnBCD(read_1302(0x8b));//讀出周
//顯示數據
if(((0<=miao)&&(miao<15))||(((miao/10==2)||(miao/10==4))&&(miao%10<=5))||((54<=miao)&&(miao<60))) /*顯示所有信息的時間段*/
  print(0x80,"20  /  /   W < >");
  writecom(h1+0x0c);
  writedata(0x7e);//→右箭頭
  writeday(8,ri);//顯示日
  writeday(5,yue);//顯示月
  writeday(2,nian);//顯示年
  writeweek(week);//顯示星期
  print(0x40,"  :  :          ");
  writetemp(9,flag);//顯示溫度,第二行顯示
  writetime(6,miao);//顯示出秒
  writetime(3,fen);//顯示出分
  writetime(0,shi);//顯示出時,第二行第一個開始
//if(15<=miao)/*當秒大于15時才顯示*/
  if(((miao/10==1)||(miao/10==3))&&(miao%10>=5))
  switch(flag/100)//取出溫度的十位數
   case 0:print(0x80,"Pretty cold now!");
       break;
   case 1:print(0x80,"little cold now!");
       break;
   case 2:print(0x80,"It is warm now. ");
       break;
   case 3:print(0x80,"It's hot !!!    ");
       break;
   case 4:print(0x80,"Very very hot!!!");
       break;
   case 5:print(0x80,"Very very hot!!!");
       break;
   case 6:print(0x80,"Very very hot!!!");
       break;
  //print(0x80,"It is warm now. ");
  if(((miao/10==2)||(miao/10==4))&&(miao%10>=5))/*25-30 45-50*/
   if((5<=shi)&&(shi<=11)) flagT=1;//5-11時為早上
   if((11<shi)&&(shi<=14)) flagT=2;//11-14為中午
   if((14<shi)&&(shi<=18)) flagT=3;//14-18為下午
   if((18<shi)||(shi<5))   flagT=4;//18-24或者0-5為晚上
   switch(flagT)//分段時間
    case 1:print(0x80," Good Morning!  ");
        break;
    case 2:print(0x80,"   Good Noon!   ");
        break;
    case 3:print(0x80,"Good afternoon! ");
        break;
    case 4:print(0x80,"  Good night!   ");
        break;
  if(((30<=miao)&&(miao<35))||((50<=miao)&&(miao<54)))//30-35 50-54
  {//else改為范圍
  festival();//選擇顯示節日
void timer1() interrupt 3//任務:計時用作報時
TH1=(65536-50000)/256;//中斷后重新賦初值
TL1=(65536-50000)%256;
//count++;//計算時間
if(alarmflag==1)//設置鍵按下才有效
  if(fen==0 && miao<4)
  count++;
  ledcount=count/10;//分開時間段
   switch(ledcount)
    case 0:Gled=0;Yled=1;break;//從零開始
    case 1:Gled=1;Yled=0;break;
    case 2:Gled=0;Yled=1;break;
    case 3:Gled=1;Yled=0;break;
    case 4:Gled=0;Yled=0;break;
    case 5:Gled=1;Yled=1;break;
    case 6:Gled=0;Yled=0;break;
    case 7:Gled=0;Yled=0;count=0;break;//在這里面清零
  else if(fen==30 && miao<2)
   Gled=0;
   Yled=0;
  else {
  Gled=1;
  Yled=1;
ID:347352 發表于 2018-10-24 08:30 | 顯示全部樓層
感謝大神
