查看: 11509|回復: 2
自己寫的51單片機的計算器程序
ID:263173 發表于 2017-12-23 12:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define ucharunsigned char
#define uintunsigned int
#define weixuan P1
#define duan  P0
int qian,bai,shi,ge;
intnum1,num2,num,keyvalue,keyvalue1;
uchar codetable[11]={0x14,0xd7,0x4c,0x45,0x87,0x25,0x24,0x57,0x04,0x05,0xff};//定義數碼管的數值0-9,0xff為滅。
uchar  wei[4]={0,0,0,0};定義位。
//uchardisbuffer[4]={0,11,11,11};
   void delayms(uintxms)//延時函數
   uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
temp=0x01;         顯示函數
void display()
    qian=num/1000;
  bai=num%1000/100;
  shi=num%100/10;
  ge=num%10;
  weixuan = ~wei[1] ;
duan=table[ge];
delayms(1);
duan=0xff;
weixuan = ~wei[2] ;
duan=table[shi];
delayms(1);
duan=0xff;
  weixuan = ~wei[3];
duan=table[bai];
delayms(1);
duan=0xff;
weixuan = ~wei[4] ;
duan=table[qian];
delayms(1);
duan=0xff;
delayms(1);
void init()        //                      初始化函數
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TR0=1;
ET0=1;
EA=1;
unsigned char keyscan()          //按鍵掃描函數
unsigned char keytemp,keyvalue;
keyvalue1 = 0;
P3=0x0f;
keytemp=P3;
if(keytemp!=0x0f)
delayms(5);
return 0xff;
P3=0x0f;
keytemp=P3;
if(keytemp!=0x0f)
switch(keytemp)
case 0x0e:keyvalue=0;
break;
case 0x0d:keyvalue=1;
break;
     case 0x0b:keyvalue=2;
break;
case 0x07:keyvalue=3;
break;
P3=0xf0;
keytemp=P3;
switch(keytemp)
case0xe0:keyvalue1=keyvalue+0;
break;
case0xd0:keyvalue1=keyvalue+4;
break;
     case0xb0:keyvalue1=keyvalue+8;
break;
case0x70:keyvalue1=keyvalue+12;
break;
if(keyvalue1<10)                 //按鍵位移  并且給按鍵賦值
wei[4]=wei[3]<<1;
wei[3]=wei[2]<<1;
wei[2]=wei[1]<<1;
wei[1]=wei[0];
     num=num*10+keyvalue1;
while(P3 != 0xf0);
return keyvalue1;
void yunsuan()            //運算并且分辨按鍵的值
static uchar fh;//
if(fh==0)
num1=num;
num2=num;
if(keyvalue1==11)
switch(fh)
case 1:num=num1+num2;
break;
case 2:num=num1-num2;
break;
case 3:num=num1*num2;
break;
case 4:num=num1/num2;
break;
wei[4]=8,wei[1]=1,wei[2]=2,wei[3]=4;
if(keyvalue1>11)
    switch(keyvalue1)
case 12:fh=1;break;
case 13:fh=2;break;
case 14:fh=3;break;
case 15:fh=4;break;
num=0;
wei[4]=0,wei[1]=0,wei[2]=0,wei[3]=0;
if (keyvalue1==10)
num=0,num1=0,num2=0,wei[4]=0,wei[1]=0,wei[2]=0,wei[3]=0;fh=0;
keyvalue1 = 0;
main()                     //主函數
    init();
keyscan();
yunsuan();
display();
ID:771010 發表于 2020-7-10 11:25 | 只看該作者
能不能批注下每個代碼的意思呢,我有些不太懂
ID:138997 發表于 2020-7-25 08:06 | 只看該作者
最好配上仿真原理圖和注釋就好了,作為新手的我是一頭霧水。
