查看: 2753|回復: 0
KeyMatrix-Library (STM32F4)源碼
KeyMatrix Library (STM32F4)
Here is a library with which you can connect a keypad that is built as an X / Y matrix to the STM32F4.
It does not matter what the arrangement of the key matrix is (3 × 3, 4 × 3, 2 × 5, etc.).
No external diodes or pull-ups are needed.
In the H-file the size of the keyboard matrix is set (in the example 3 × 4)
and in the C-File the GPIO pins are assigned to the X and Y direction.
There is a function to read out the pressed key, which returns "0" if no key is pressed. If one or more keys are pressed, the key number of the first key found is returned. (In Example 1 to 12)
To debounce the buttons no timer but only a loop counter is used.
(this event needs to be adapted for you)
Note: if the return value is> 0 even if no keyboard is connected, external pull-ups (4k7) must be attached to the Y-lines.
Images :
// File     : main.c
// Datum    : 02.05.2014
// Version  : 1.0
// Autor    : UB
// EMail    : mc-4u(@)t-online.de
// CPU      : STM32F4
// IDE      : CooCox CoIDE 1.7.4
// GCC      : 4.7 2012q4
// Module   : CMSIS_BOOT, M4_CMSIS_CORE
// Funktion : Demo der Key-Matrix-Library
// Hinweis  : Diese zwei Files muessen auf 8MHz stehen
//              "cmsis_boot/stm32f4xx.h"
//              "cmsis_boot/system_stm32f4xx.c"
#include "main.h"
#include "stm32_ub_keymatrix.h"
#include "stm32_ub_led.h"
int main(void)
  uint8_t key_value;
  SystemInit(); // Quarz Einstellungen aktivieren
  // init der LEDs
  UB_Led_Init();
  // init der Tastatur-Matrix
  UB_KeyMatrix_Init();
    // Tastatur-Matrix abfragen
    key_value=UB_KeyMatrix_Scan();
    // LEDs je nach Tasten-Nr schalten
    if(key_value==1) UB_Led_On(LED_GREEN); else UB_Led_Off(LED_GREEN);
    if(key_value==2) UB_Led_On(LED_RED); else UB_Led_Off(LED_RED);
    if(key_value==3) UB_Led_On(LED_BLUE); else UB_Led_Off(LED_BLUE);
    if(key_value==4) UB_Led_On(LED_ORANGE); else UB_Led_Off(LED_ORANGE);
全部資料51hei下載地址:
Demo_83_KEY_Matrix.zip (173.43 KB, 下載次數: 12)
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
