查看: 2830|回復: 0
求助!一個51利用RFID模塊識別卡號的程序,實現卡號對了燈就滅額,不對燈就亮
ID:256652 發表于 2017-12-18 23:30 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#include<string.h>
unsigned char num1[]={0x02,0x32,0x31,0x30,0x30,0x43,0x37,0x43,0x30,0x46,0x44,0x44,0x42,0x03};
unsigned char num2[]={0x02,0x32,0x31,0x30,0x30,0x43,0x36,0x42,0x34,0x42,0x44,0x45,0x45,0x03};
unsigned char num3[]={0x02,0x32,0x31,0x30,0x30,0x43,0x38,0x34,0x34,0x31,0x46,0x42,0x32,0x03};
unsigned char num4[]={0x02,0x32,0x31,0x30,0x30,0x43,0x38,0x42,0x33,0x35,0x41,0x30,0x30,0x03};
unsigned char num5[]={0x02,0x32,0x31,0x30,0x30,0x43,0x39,0x31,0x31,0x35,0x39,0x41,0x30,0x03};
unsigned char num6[]={0x02,0x32,0x31,0x30,0x30,0x35,0x42,0x45,0x43,0x34,0x38,0x44,0x45,0x03};
unsigned char num[14];//存放選定的卡號
unsigned int i,n=0;
unsigned char now[14];//存放讀取的卡號
sbit LED=P1^2;
unsigned char m=100;
unsigned int j,k,temp,key=0;
void delaychar(unsigned int m)
  for(j=m;j>0;j--)
    for(k=125;k>0;k--);
void jvzhen()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delaychar(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=0;
               break;
          case 0xde:
               key=1;
               break;
          case 0xbe:
               key=2;
               break;
          case 0x7e:
               key=3;
               break;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delaychar(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=4;
               break;
          case 0xdd:
               key=5;
               break;
          case 0xbd:
               key=6;
               break;
          case 0x7d:
               key=7;
               break;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delaychar(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=8;
               break;
          case 0xdb:
               key=9;
               break;
          case 0xbb:
               key=10;
               break;
          case 0x7b:
               key=11;
               break;
    P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delaychar(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xe7:
               key=12;
               break;
          case 0xd7:
               key=13;
               break;
          case 0xb7:
               key=14;
               break;
          case 0x77:
               key=15;
               break;
        switch(key)
          case 1:strcpy(num,num1);break;
          case 2:strcpy(num,num2);break;
          case 3:strcpy(num,num3);break;
          case 4:strcpy(num,num4);break;
          case 5:strcpy(num,num5);break;
          case 6:strcpy(num,num6);break;
          default:break;
        if(!strcmp(now,num))
             LED=1;
             LED=0;
void transfor() interrupt 4//串口通信中斷
     if(RI)
        RI=0;
        now[n]=SBUF;
        n++;
        if(n==14)
                        n=0;
void main(void)
    TMOD=0x20;
        TH1=0xfd;
        TL1=0xfd;
        SCON=0x50;
        TR1=1;
        ES=1;
        EA=1;
        jvzhen();
