下面的的程序在STC15W408AS單片機上顯示正常,與24LE1無線模塊連接好后,數(shù)碼管全亮顯示,
邏輯分析儀抓取的波形如下:請高手指點一二,謝謝
程序如下:
#include "Nordic\reg24le1.h"
#include "MAX7219.H"
#include "stdint.h"
#include "API.h"
unsigned char disbuf[8];
void delayms(unsigned int ms)
unsigned char i=100,j;
for(;ms;ms--)
while(--i)
j=10;
while(--j);
* Ãè êö : ÅäÖà IO P0.0oíP0.1Îaêä3ö£¬P1.2oíP1.3Îaêäèë
* èë 2Î : ÎT
* ·μ»ØÖμ : ÎT
void IO_Init(void)
P0DIR =0x03; //Åä 0000 0011
P1DIR = 0x00; //ÅäÖÃ0000 1100
//P1CON=0X00;
void disp( )
unsigned char i;
for(i=0;i<8;i++)
Write_Max7219(i,disbuf[i]);
IO_Init(); // I/O¿ú3õê¼»ˉ
Init_MAX7219();
disp();
disp();
delayms(500);
#ifndef __MAX7219_H__
#define __MAX7219_H__
//#include <reg52.h>
//¶¨òåMax7219¶Ë¿ú
sbit Max7219_pinCLK = P1^6;
sbit Max7219_pinCS = P1^5;
sbit Max7219_pinDIN = P1^4;
extern void delayms(unsigned int ms);
//1|Äü£oÏòMAX7219(U3)D′èë×Ö½ú
//èë¿ú2Îêy£oDATA
//3ö¿ú2Îêy£oÎT
//ËμÃ÷£o
void Write_Max7219_byte(uchar DATA)
uchar i;
Max7219_pinCS=0;
for(i=8;i>=1;i--)
Max7219_pinCLK=0;
Max7219_pinDIN=DATA&0x80;
DATA=DATA<<1;
Max7219_pinCLK=1;
//1|Äü£oÏòMAX7219D′èëêy¾Y
//èë¿ú2Îêy£oaddress¡¢dat
//3ö¿ú2Îêy£oÎT
//ËμÃ÷£o
void Write_Max7219(uchar address,uchar dat)
Max7219_pinCS=0;
Write_Max7219_byte(address); //D′èëμØÖ·£¬¼′êyÂë1ü±àoÅ
Write_Max7219_byte(dat); //D′èëêy¾Y£¬¼′êyÂë1üÏÔê¾êy×Ö
Max7219_pinCS=1;
void Init_MAX7219(void)
Write_Max7219(0x09, 0xff); //òëÂ뷽꽣oBCDÂë
Write_Max7219(0x0a, 0x03); //áá¶è
Write_Max7219(0x0b, 0x07); //é¨Ãè½çÏT£»4¸öêyÂë1üÏÔê¾
Write_Max7219(0x0c, 0x01); //μôμçģ꽣o0£¬ÆÕí¨Ä£ê½£o1
Write_Max7219(0x0f, 0x01); //ÏÔê¾2aêÔ£o1£»2aêÔ½áêø£¬Õy3£ÏÔê¾£o0
#endif
