查看: 3129|回復(fù): 2
矩陣鍵盤和數(shù)碼管
ID:260598 發(fā)表于 2017-12-13 10:46 | 顯示全部樓層 |閱讀模式
如何實(shí)現(xiàn)在用矩陣鍵盤控制數(shù)碼管顯示時(shí),如何控制前一數(shù)碼管顯示數(shù)字不消失的情況下通過矩陣鍵盤實(shí)現(xiàn)下一數(shù)據(jù)輸出。
ID:213173 發(fā)表于 2017-12-13 15:11 | 顯示全部樓層
這是在矩陣鍵盤1位數(shù)碼管顯示鍵值0~F的程序上改的,6位數(shù)碼管顯示,只能保存6次鍵值,超出6次前面的溢出。
#include <AT89X52.H>
#define uint unsigned int                 //宏定義無符號整型數(shù)據(jù)
#define uchar unsigned char         //宏定義無符號字符型數(shù)據(jù)
sbit dula=P2^6;                        //數(shù)碼管段鎖存
sbit wela=P2^7;                        //數(shù)碼管位鎖存
uchar code table[]={                //共陰數(shù)碼管(0~F.-)
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x6f,0x77,0x7c,
        0x39,0x5e,0x79,0x71,0x80,0x40};
uchar key=17,key1=17,key2=17,key3=17,key4=17,key5=17,key6=17;
void keyscan()                                        //按鍵掃描程序
        static bit sign=0;                        //按鍵有效標(biāo)志
        static uint count=0;                //消抖計(jì)數(shù)變量
        uchar num=0;                                //臨時(shí)變量
        P3=0xf0;                                                //賦值P3 1111 0000
        if(P3!=0xf0)                                //檢測按鍵按下并有效
                count++;                                        //消抖計(jì)數(shù)
                if((count>=500)&&(sign==0))        //100~1000,根據(jù)主循環(huán)周期調(diào)整約10~20ms
                {                                                        //按鍵有效標(biāo)志0
                        sign=1;                                //按鍵有效標(biāo)志置1
                        num=P3;                                //保存P3值xxxx 0000,x為0或1
                        num|=0x0f;                        //保存num按位或0x0f值xxxx 1111
                        P3=num;                                //賦值P3 xxxx 1111
                        num=P3;                                //保存P3值xxxx xxxx
                        switch(num)
                                case 0xee: key= 0; break;
                                case 0xde: key= 1; break;
                                case 0xbe: key= 2; break;
                                case 0x7e: key= 3; break;
                                case 0xed: key= 4; break;
                                case 0xdd: key= 5; break;
                                case 0xbd: key= 6; break;
                                case 0x7d: key= 7; break;
                                case 0xeb: key= 8; break;
                                case 0xdb: key= 9; break;
                                case 0xbb: key=10; break;
                                case 0x7b: key=11; break;
                                case 0xe7: key=12; break;
                                case 0xd7: key=13; break;
                                case 0xb7: key=14; break;
                                case 0x77: key=15; break;
                        key6=key5;key5=key4;key4=key3;//轉(zhuǎn)移保存鍵值
                        key3=key2;key2=key1;key1=key;
        else                                                //鍵抬起
                sign=0;                                //按鍵有效標(biāo)志清0
                count=0;                                //消抖計(jì)數(shù)清0
void Timer0Init()                //2毫秒@11.0592MHz
        TMOD= 0x01;                //設(shè)置定時(shí)器模式
        TL0 = 0xCD;                //設(shè)置定時(shí)初值
        TH0 = 0xF8;                //設(shè)置定時(shí)初值
        TF0 = 0;                        //清除TF0標(biāo)志
        TR0 = 1;                        //定時(shí)器0開始計(jì)時(shí)
        EA=1;                                //開總中斷
        ET0=1;                        //開定時(shí)器0中斷
void display()
        static uchar count=0;        //計(jì)數(shù)變量
        switch(count)
                case 0:
                   P0=table[key6];
                   dula=1;
                   dula=0;
                   P0=0x7e;
                   wela=1;
                   wela=0;
                   count++;
                break;
                case 1:
                   P0=table[key5];
                   dula=1;
                   dula=0;
                   P0=0x7d;
                   wela=1;
                   wela=0;
                   count++;
                break;
                case 2:
                   P0=table[key4];
                   dula=1;
                   dula=0;
                   P0=0x7b;
                   wela=1;
                   wela=0;
                   count++;
                break;
                case 3:
                   P0=table[key3];
                   dula=1;
                   dula=0;
                   P0=0x77;
                   wela=1;
                   wela=0;
                   count++;
                break;
                case 4:
                   P0=table[key2];
                   dula=1;
                   dula=0;
                   P0=0xef;
                   wela=1;
                   wela=0;
                   count++;
                break;
                case 5:
                   P0=table[key1];
                   dula=1;
                   dula=0;
                   P0=0xdf;
                   wela=1;
                   wela=0;
                   count=0;
                break;
void main()                                                //主函數(shù)
        Timer0Init();
                keyscan();                                //按鍵掃描程序
//                display();                                //1位數(shù)碼管顯示程序
void timer0() interrupt        1
        display();                //6位數(shù)碼管顯示程序
ID:259274 發(fā)表于 2017-12-13 15:55 | 顯示全部樓層
將這個(gè)數(shù)碼管位選關(guān)閉,下一次按鍵應(yīng)答另選一個(gè)數(shù)碼管。當(dāng)然前一個(gè)要保持高電平
參與人數(shù) 1黑幣 +50 收起 理由
admin + 50 回帖助人的獎(jiǎng)勵(lì)!
無效樓層,該帖已經(jīng)被刪除
