STM32F103的一個例子
單片機(jī)源程序如下:
- /* 本實(shí)驗(yàn)使得GPIO的PD2和PD3管腳控制STM32神舟IV號開發(fā)板的LED1和LED2兩個燈進(jìn)行閃爍 */
- #define __IO volatile
- typedef unsigned int uint32_t;
- typedef __IO uint32_t vu32;
- typedef unsigned short int uint16_t;
- #define GPIO_Pin_0 ((uint16_t)0x0001) /*!< Pin 0 selected */
- #define GPIO_Pin_1 ((uint16_t)0x0002) /*!< Pin 1 selected */
- #define GPIO_Pin_2 ((uint16_t)0x0004) /*!< Pin 2 selected */
- #define GPIO_Pin_3 ((uint16_t)0x0008) /*!< Pin 3 selected */
- #define GPIO_Pin_4 ((uint16_t)0x0010) /*!< Pin 4 selected */
- #define GPIO_Pin_5 ((uint16_t)0x0020) /*!< Pin 5 selected */
- #define GPIO_Pin_6 ((uint16_t)0x0040) /*!< Pin 6 selected */
- #define GPIO_Pin_7 ((uint16_t)0x0080) /*!< Pin 7 selected */
- #define GPIO_Pin_8 ((uint16_t)0x0100) /*!< Pin 8 selected */
- #define GPIO_Pin_9 ((uint16_t)0x0200) /*!< Pin 9 selected */
- #define GPIO_Pin_10 ((uint16_t)0x0400) /*!< Pin 10 selected */
- #define GPIO_Pin_11 ((uint16_t)0x0800) /*!< Pin 11 selected */
- #define GPIO_Pin_12 ((uint16_t)0x1000) /*!< Pin 12 selected */
- #define GPIO_Pin_13 ((uint16_t)0x2000) /*!< Pin 13 selected */
- #define GPIO_Pin_14 ((uint16_t)0x4000) /*!< Pin 14 selected */
- #define GPIO_Pin_15 ((uint16_t)0x8000) /*!< Pin 15 selected */
- #define GPIO_Pin_All ((uint16_t)0xFFFF) /*!< All pins selected */
- #define RCC_APB2Periph_AFIO ((uint32_t)0x00000001)
- #define RCC_APB2Periph_GPIOA ((uint32_t)0x00000004)
- #define RCC_APB2Periph_GPIOB ((uint32_t)0x00000008)
- #define RCC_APB2Periph_GPIOC ((uint32_t)0x00000010)
- #define RCC_APB2Periph_GPIOD ((uint32_t)0x00000020)
- /************ GPIOD <*************/
- typedef struct
- __IO uint32_t CRL;
- __IO uint32_t CRH;
- __IO uint32_t IDR;
- __IO uint32_t ODR;
- __IO uint32_t BSRR;
- __IO uint32_t BRR;
- __IO uint32_t LCKR;
- } GPIO_TypeDef;
- typedef struct
- __IO uint32_t CR;
- __IO uint32_t CFGR;
- __IO uint32_t CIR;
- __IO uint32_t APB2RSTR;
- __IO uint32_t APB1RSTR;
- __IO uint32_t AHBENR;
- __IO uint32_t APB2ENR;
- __IO uint32_t APB1ENR;
- __IO uint32_t BDCR;
- __IO uint32_t CSR;
- } RCC_TypeDef;
- /********* GPIOD管腳的內(nèi)存對應(yīng)地址 *******/
- #define PERIPH_BASE ((uint32_t)0x40000000)
- #define APB2PERIPH_BASE (PERIPH_BASE + 0x10000)
- #define GPIOD_BASE (APB2PERIPH_BASE + 0x1400)
- #define GPIOD ((GPIO_TypeDef *) GPIOD_BASE)
- /************ RCC時鐘 <*************/
- #define AHBPERIPH_BASE (PERIPH_BASE + 0x20000)
- #define RCC_BASE (AHBPERIPH_BASE + 0x1000)
- #define RCC ((RCC_TypeDef *) RCC_BASE)
- void Delay(vu32 nCount);
- int main(void) //main是程序入口
- /* 使能APB2總線的時鐘,對GPIO的端口D時鐘使能 */
- RCC->APB2ENR |= RCC_APB2Periph_GPIOD;
- /*-- GPIO Mode Configuration速度,輸入或輸出 -----------------------*/
- /*-- GPIO CRL Configuration 設(shè)置IO端口低8位的模式(輸入還是輸出)---*/
- /*-- GPIO CRH Configuration 設(shè)置IO端口高8位的模式(輸入還是輸出)---*/
- GPIOD->CRL &= 0xFFFF00FF;
- GPIOD->CRL |= 0x00003300; /* 設(shè)置GPIOD的PD2和PD3配置為通用推挽模式輸出50MHZ */
- while (1)
- /* 對BRR設(shè)置為1,則GPIO輸出為0 */
- GPIOD->BRR = GPIO_Pin_2;
- GPIOD->BRR = GPIO_Pin_3;
- Delay(0x2FFFFF);
test2.7z
(207.16 KB, 下載次數(shù): 20)
2021-10-29 17:35 上傳
點(diǎn)擊文件名下載附件
STMF103 下載積分: 黑幣 -5
