SP207E–SP213E ic datasheet
Low Power, High ESD +5V RS-232 Transceivers
■ Meets All EIA-232 and ITU V.28 Specifcations
■ Single +5V Supply Operation
■ 3mA Typical Static Supply Current
■ 4 x 0.1μF External Charge Pump Capacitors
■ Typical 230kbps Transmission Rates
■ Standard SOIC and SSOP Footprints
■ 1μA Shutdown Mode (SP211E & SP213E)
■ Two Wake-Up Receivers (SP213E)
■ Tri-State/RxEnable (SP211E & SP213E)
■ Improved ESD Specifcations:
+5kV Human Body Model
+5kV IEC000-4-2 Air Discharge
+8kV IEC000-4-2 Contact Discharge
SP207E–SP213E引腳圖
2017-12-13 01:19 上傳
2017-12-13 01:18 上傳
2017-12-13 01:18 上傳
完整的pdf格式文檔51黑下載地址(共19頁):
sp.pdf
(995.78 KB, 下載次數(shù): 5)
2017-12-12 17:05 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
