查看: 4970|回復(fù): 1
單片機(jī)蜂鳴器發(fā)聲蘭花草音樂
ID:259336 發(fā)表于 2017-12-9 11:16 | 只看該作者 |只看大圖 回帖獎勵 |正序瀏覽 |閱讀模式
  1. #include <reg51.h>
  3. sbit beepIO=P2^0;
  4. uchar m,n;
  5. uchar code T[49][2]={{0,0},
  6. {0xF8,0x8B},{0xF8,0xF2},{0xF9,0x5B},{0xF9,0xB7},{0xFA,0x14},
  7. {0xFA,0x66},{0xFA,0xB9},{0xFB,0x03},{0xFB,0x4A},{0xFB,0x8F},
  8. {0xFB,0xCF},{0xFC,0x0B},{0xFC,0x43},{0xFC,0x78},{0xFC,0xAB},
  9. {0xFC,0xDB},{0xFD,0x08},{0xFD,0x33},{0xFD,0x5B},{0xFD,0x81},
  10. {0xFD,0xA5},{0xFD,0xC7},{0xFD,0xE7},{0xFE,0x05},{0xFE,0x21},
  11. {0xFE,0x3C},{0xFE,0x55},{0xFE,0x6D},{0xFE,0x84},{0xFE,0x99},
  12. {0xFE,0xAD},{0xFE,0xC0},{0xFE,0x02},{0xFE,0xE3},{0xFE,0xF3},
  13. {0xFF,0x02},{0xFF,0x10},{0xFF,0x1D},{0xFF,0x2A},{0xFF,0x36},
  14. {0xFF,0x42},{0xFF,0x4C},{0xFF,0x56},{0xFF,0x60},{0xFF,0x69},
  15. {0xFF,0x71},{0xFF,0x79},{0xFF,0x81}};
  16. uchar code music[][2]={{0,4},{11,4},{18,4},{18,4},{18,4},{18,8},{16,4},
  17. {14,6},{16,2},{16,4},{13,4},{11,12},
  18. {22,4},{22,4},{22,4},{22,4},{22,6},{21,12},
  19. {18,4},{21,4},{10,4},{19,4},{18,12},
  20. {18,4},{23,4},{23,4},{21,4},{18,6},{16,12},
  21. {14,4},{16,2},{16,4},{13,4},{11,8},{6,8},
  22. {6,4},{14,4},{14,4},{13,4},{11,6},{18,12},
  23. {16,6},{14,2},{13,4},{9,4},{11,8},{12,12},{10,4},{0xFF,0xFF}};
  24. void delay(uchar p)
  25. {
  26.     uchar i,j;
  27.     for(;p>0;p--)
  28.     for(i=181;i>0;i--)
  29.     for(j=181;j>0;j--);
  30. }
  31. void pause()
  32. {
  33.     uchar i,j;
  34.     for(i=150;i>0;i--)
  35.     for(j=150;j>0;j--);
  36. }
  37. void T0_int() interrupt 1
  38. {
  39. beepIO=!beepIO;
  40. TH0=T[m][0]; TL0=T[m][1];
  41. }
  42. void main()
  43. {
  44. uchar i=0;
  45. TMOD=0x01;  EA=1; ET0=1;
  46. while(1)
  47.       {
  48.         m=music[i][0];n=music[i][1];
  49.            if(m==0x00)
  50.              {TR0=0;delay(n);i++;}
  51.            else if(m==0xFF)
  52.              {TR0=0;delay(30);i=0;}
  53.            else if(m==music[i+1][0])
  54.              {TR0=1;delay(n);TR0=0;pause();i++;}
  55.            else
  56.              {TR0=1;delay(n);i++;}
  57.       }
  58. }
蜂鳴器發(fā)聲,蘭花草音樂
蜂鳴器發(fā)聲,蘭花草音樂
ID:408024 發(fā)表于 2018-10-18 22:38 | 只看該作者
此帖僅作者可見
