查看: 2120|回復: 6
單片機程序幫找錯,沒通過編譯,提示在:Delay()哪里
ID:60021 發表于 2017-12-7 15:46 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit IR = P2^1;
sbit key1 = P1^1;
sbit key2 = P1^2;
void Delay();
void SendInstructionCode();
void SendCodeZero();
void SendCodeOne();
void UsrCode();
void Key1();
void Key2();
void KeyScan();
void SendKeyCode();
/*******發送引導碼函數**********/
        TH0 = 0xDC;             //9000us
        TL0 = 0xD8;
        TR0 = 1;
        IR = 0;                //拉低IR
        while(!(TF0 == 1));    //等待定時器溢出,即使IR持續低電平9000us
        IR = 1;
        TF0 = 0;
        TR0 = 0;
    TH0 = 0xEE;            //4500us
        TL0 = 0x6c;
        TR0 = 1;
        while(!(TF0 == 1));     //等待定時器溢出,即使IR持續高電平4500us
        IR = 0;
        TF0 = 0;
        TR0 = 0;
/*********發送0函數*********/
void SendCodeZero()
        TH0 = 0xFD;      //560us
        TL0 = 0xD0;
        TR0 = 1;
        IR = 0;
        while(!(TF0 == 1));
        IR = 1;
        TF0 = 0;
        TR0 = 0;
        TH0 = 0xFD;      //560us
        TL0 = 0xD0;
        TR0 = 1;
        while(!(TF0 == 1));
        IR = 0;
        TF0 = 0;
        TR0 = 0;
/*********發送1函數*********/
void SendCodeOne()
        TH0 = 0xFD;      //560us
        TL0 = 0xD0;
        TR0 = 1;
        IR = 0;
        while(!(TF0 == 1));
        IR = 1;
        TF0 = 0;
        TR0 = 0;
        TH0 = 0xF9;      //1680us
        TL0 = 0x70;
        TR0 = 1;
        while(!(TF0 == 1));
        IR = 0;
        TF0 = 0;
        TR0 = 0;
/*********用戶碼函數*********/
void UsrCode()   //發送用戶碼 11111111  00000000
        uchar i;
          for(i=0;i<8;i++)
                SendCodeOne();
        for(i=0;i<8;i++)
                SendCodeZero();
/*********鍵值1函數********/
void Key1()   //0x3d  0011 1101   ~0x3d  1100 0010
        SendCodeZero();
        SendCodeZero();
        SendCodeOne();
        SendCodeOne();
        SendCodeOne();
        SendCodeOne();
        SendCodeZero();
        SendCodeOne();
        SendCodeOne();
        SendCodeOne();
        SendCodeZero();
        SendCodeZero();
        SendCodeZero();
        SendCodeZero();
        SendCodeOne();
        SendCodeZero();
/*********鍵值2函數********/
void Key2()     //0xe3  1110 0011 ; ~0xe3  0001 1100
        SendCodeOne();
        SendCodeOne();
        SendCodeOne();
        SendCodeZero();
        SendCodeZero();
        SendCodeZero();
        SendCodeOne();
        SendCodeOne();
        SendCodeZero();
        SendCodeZero();
        SendCodeZero();
        SendCodeOne();
        SendCodeOne();
        SendCodeOne();
        SendCodeZero();
        SendCodeZero();
/*********按鍵掃描函數********/
void KeyScan()  //返回值是按下按鍵的按鍵值,沒按下返回100,即不發送
        uchar key = 100;
        uchar keybuf [2]={ 1,1};
        static uchar backup[2]= { 1,1};
        keybuf [0]= key1;
        if(keybuf[0] != backup[0])
                Delay(100);
                if(keybuf[0] == key1)
                        if(backup[0] == 0)
                    key = 1;
        if(keybuf[1] != backup[1])
                Delay(100);
                if(keybuf[1] == key2)
                        if(backup[1] == 0)
                    key = 2;
        return key;
/*********發送函數********/
void SendKeyCode(uchar key)
        if(key == 1)
                UsrCode();
                Key1();
        if(key == 2)
                UsrCode();
                Key2();
void Delay(uint z)
        uint t1,y;
        for(t1=z; t1>0; t1--)
                for(y=110; y>0; y--);
        uchar key;
        TMOD = 0x01;
                key = KeyScan();
                SendKeyCode(key);
ID:60021 發表于 2017-12-7 15:59 | 只看該作者
Build target 'Target 1'
compiling IR_YK01.c...
IR_YK01.C(145): error C267: 'Delay': requires ANSI-style prototype
Target not created
ID:155507 發表于 2017-12-7 16:46 | 只看該作者
試試看
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. sbit IR = P2^1;
  5. sbit key1 = P1^1;
  6. sbit key2 = P1^2;
  7. void Delay(uint z);
  8. void SendInstructionCode();
  9. void SendCodeZero();
  10. void SendCodeOne();
  11. void UsrCode();
  12. void Key1();
  13. void Key2();
  14. uchar KeyScan();
  15. void SendKeyCode(uchar key);
  16. /*******發送引導碼函數**********/
  17. void SendInstructionCode()
  18. {
  19.         TH0 = 0xDC;             //9000us
  20.         TL0 = 0xD8;
  21.         TR0 = 1;
  22.         IR = 0;                //拉低IR
  23.         while(!(TF0 == 1));    //等待定時器溢出,即使IR持續低電平9000us
  24.         IR = 1;
  25.         TF0 = 0;
  26.         TR0 = 0;
  27.         TH0 = 0xEE;            //4500us
  28.         TL0 = 0x6c;
  29.         TR0 = 1;
  30.         while(!(TF0 == 1));     //等待定時器溢出,即使IR持續高電平4500us
  31.         IR = 0;
  32.         TF0 = 0;
  33.         TR0 = 0;
  34. }
  35. /*********發送0函數*********/
  36. void SendCodeZero()
  37. {
  38.         TH0 = 0xFD;      //560us
  39.         TL0 = 0xD0;
  40.         TR0 = 1;
  41.         IR = 0;
  42.         while(!(TF0 == 1));
  43.         IR = 1;
  44.         TF0 = 0;
  45.         TR0 = 0;
  46.         TH0 = 0xFD;      //560us
  47.         TL0 = 0xD0;
  48.         TR0 = 1;
  49.         while(!(TF0 == 1));
  50.         IR = 0;
  51.         TF0 = 0;
  52.         TR0 = 0;
  53. }
  54. /*********發送1函數*********/
  55. void SendCodeOne()
  56. {
  57.         TH0 = 0xFD;      //560us
  58.         TL0 = 0xD0;
  59.         TR0 = 1;
  60.         IR = 0;
  61.         while(!(TF0 == 1));
  62.         IR = 1;
  63.         TF0 = 0;
  64.         TR0 = 0;
  65.         TH0 = 0xF9;      //1680us
  66.         TL0 = 0x70;
  67.         TR0 = 1;
  68.         while(!(TF0 == 1));
  69.         IR = 0;
  70.         TF0 = 0;
  71.         TR0 = 0;
  72. }
  73. /*********用戶碼函數*********/
  74. void UsrCode()   //發送用戶碼 11111111  00000000
  75. {
  76.         uchar i;
  77.         for(i=0;i<8;i++)
  78.         {
  79.                 SendCodeOne();
  80.         }
  81.         for(i=0;i<8;i++)
  82.         {
  83.                 SendCodeZero();
  84.         }
  85. }
  86. /*********鍵值1函數********/
  87. void Key1()   //0x3d  0011 1101   ~0x3d  1100 0010
  88. {
  89.         SendCodeZero();
  90.         SendCodeZero();
  91.         SendCodeOne();
  92.         SendCodeOne();
  93.         SendCodeOne();
  94.         SendCodeOne();
  95.         SendCodeZero();
  96.         SendCodeOne();
  97.         SendCodeOne();
  98.         SendCodeOne();
  99.         SendCodeZero();
  100.         SendCodeZero();
  101.         SendCodeZero();
  102.         SendCodeZero();
  103.         SendCodeOne();
  104.         SendCodeZero();
  105. }
  106. /*********鍵值2函數********/
  107. void Key2()     //0xe3  1110 0011 ; ~0xe3  0001 1100
  108. {
  109.         SendCodeOne();
  110.         SendCodeOne();
  111.         SendCodeOne();
  112.         SendCodeZero();
  113.         SendCodeZero();
  114.         SendCodeZero();
  115.         SendCodeOne();
  116.         SendCodeOne();
  117.         SendCodeZero();
  118.         SendCodeZero();
  119.         SendCodeZero();
  120.         SendCodeOne();
  121.         SendCodeOne();
  122.         SendCodeOne();
  123.         SendCodeZero();
  124.         SendCodeZero();
  125. }
  126. /*********按鍵掃描函數********/
  127. uchar KeyScan()  //返回值是按下按鍵的按鍵值,沒按下返回100,即不發送
  128. {
  129.         uchar key = 100;
  130.         uchar keybuf [2]={ 1,1};
  131.         static uchar backup[2]= { 1,1};
  132.         keybuf [0]= key1;
  133.         if(keybuf[0] != backup[0])
  134.         {
  135.                 Delay(100);
  136.                 if(keybuf[0] == key1)
  137.                 {
  138.                         if(backup[0] == 0)
  139.                         key = 1;
  140.                 }
  141.         }
  142.         if(keybuf[1] != backup[1])
  143.         {
  144.                 Delay(100);
  145.                 if(keybuf[1] == key2)
  146.                 {
  147.                         if(backup[1] == 0)
  148.                         key = 2;
  149.                 }
  150.         }
  151.         return key;
  152. }
  153. /*********發送函數********/
  154. void SendKeyCode(uchar key)
  155. {
  156.         if(key == 1)
  157.         {
  158.                 SendInstructionCode();
  159.                 UsrCode();
  160.                 Key1();
  161.         }
  162.         if(key == 2)
  163.         {
  164.                 SendInstructionCode();
  165.                 UsrCode();
  166.                 Key2();
  167.         }
  168. }
  169. void Delay(uint z)
  170. {
  171.         uint t1,y;
  172.         for(t1=z; t1>0; t1--)
  173.         for(y=110; y>0; y--);
  174. }
  175. void main()
  176. {
  177.         uchar key;
  178.         TMOD = 0x01;
  179.         while(1)
  180.         {
  181.                 key = KeyScan();
  182.                 SendKeyCode(key);
  183.         }
  184. }
ID:258478 發表于 2017-12-7 17:27 | 只看該作者
申明的問題,前面的聲明是不帶參的,但是你實際的是帶參的,不是同一個。
ID:258770 發表于 2017-12-7 19:11 | 只看該作者
改下申明
ID:235264 發表于 2017-12-7 21:25 | 只看該作者
這個程序有幾個問題 一個是你前面申明delay函數時沒有傳形參 二是你按鍵掃描函數 你定義的是void型 然而你還return key
ID:60021 發表于 2017-12-12 15:55 | 只看該作者
謝謝
