#include <stc.h>
#include <intrins.h>
#define RELOAD_COUNT 0xD7 //12.6 MHz,1T9600bps
/*----------------------------LCD1602接口定義----------------------------------*/
sbit LCD_RS= P2^5; //數(shù)據(jù)指令
sbit LCD_RW= P2^7; //讀寫控制端
sbit LCD_EN= P2^4; //使能端
/********************************顯示數(shù)據(jù)表*********************************/
typedef unsigned char uchar;
uchar tmp;
uchar dis1[] = {"4 -.--V 5 -.--V"};
uchar dis2[] = {"I ----mA P -.--V"};
uchar channel;
uchar result[5];
long Data=500; //電壓源電壓值 v*100
void serial_port_initial(void); //定義串口
void delayms(uchar); //延時
void delayus(uchar us); //延時
void UART_Interrupt_Receive(void); //接收字符
void send_char(uchar); //發(fā)送字符
void send_str(uchar stLCD_RS[]); //發(fā)送字符串
uchar get_AD_result(uchar); //AD轉(zhuǎn)換
void lcd_en(void); //輸入使能
void lcd_wcmd (uchar cmd) ;
void lcd_wdat (uchar dat) ;
void lcd_printc (uchar x, uchar y, uchar c) ;
void lcd_prints (uchar x, uchar y, uchar *s) ;
bit lcd_bz();
/**********************LCD延時子程序********************************/
void delayms(uchar ms) //LCD延時子程序
{ uchar a,b;
while(ms--)
for(b=233;b>0;b--)
for(a=12;a>0;a--);
void delayus(uchar us) //1us相當于
uchar a;
while(us--)
a++;
a--;
函數(shù)功能:顯示相關(guān)程序
void lcd_init() //函數(shù)功能:LCD初始化子程序
lcd_wcmd(0x28); //四線顯示
delayms(1);
lcd_wcmd(0x0c); //顯示打開
delayms(1);
lcd_wcmd(0x06);
delayms(1);
lcd_wcmd(0x01); //顯示清屏
delayms(1);
void lcd_en(void) //輸入使能
LCD_EN = 1;
delayus(10); //10us
LCD_EN = 0;
bit lcd_bz()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayus(50);
result = (bit)(P2 & 0x08);
LCD_EN = 0;
return result;
函數(shù)功能:寫指令數(shù)據(jù)到LCD子程序
入口參數(shù):cmd
出口參數(shù):
void lcd_wcmd(uchar cmd)
while(lcd_bz()); //判斷LCD是否忙碌
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
P2 &= 0xf0; //清低四位
P2 |= (cmd&0xf0)>>4; //寫低四位
lcd_en();
P2 &= 0xf0; //清低四位
P2 |= cmd&0x0f; //寫低四位
lcd_en();
函數(shù)功能:寫入顯示數(shù)據(jù)到LCD子程序
入口參數(shù):dat
出口參數(shù):
void lcd_wdat(uchar dat)
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P2 &= 0xf0; //清低四位
P2 |= (dat&0xf0)>>4; //寫低四位
lcd_en();
P2 &= 0xf0; //清低四位
P2 |= dat&0x0f; //寫低四位
lcd_en();
void lcd_printc (uchar x, uchar y, uchar c) //字符定位輸出
if(y) lcd_wcmd(x | 0xc0); //液晶定位
else lcd_wcmd(x | 0x80);
lcd_wdat(c);
void lcd_prints (uchar x, uchar y, uchar *s) //字符串定位輸出
while(*s)
lcd_wdat(*s);
s++;
/************************主程序************************************/
void main(void)
{ // 初始化串口
serial_port_initial();
lcd_init(); // 初始化LCD
P1ASF=0xff ; // 0110,0011,要設(shè)置為 A/D 轉(zhuǎn)換的P1.x 口,先設(shè)為高
channel=4;
while(1){
get_AD_result(channel);
dis1[0]=channel+48 ;
dis1[2]=result[0];
dis1[4]=result[1];
dis1[5]=result[2];
get_AD_result(5);
dis1[11]= result[0];
dis1[13]= result[1];
dis1[14]= result[2];
get_AD_result(6);
if(result[3]>=0x7e){result[3]-=0x7e; dis2[1]='+';} else {result[3]=0x7e-result[3]; dis2[1]='-';} //127==0x7f
Data= result[3]*5;
dis2[2]=Data/1000+48 ; // 返回 A/D 轉(zhuǎn)換結(jié)果
dis2[3]=(Data%1000)/100+48 ;
dis2[4]=((Data%100)/10)+48 ;
dis2[5]=(Data%10)+48 ;
Data=63750/(get_AD_result(7)); //Data=255*250/result
dis2[11]= Data/100+48;
dis2[13]= (Data%100)/10+48;
dis2[14]= Data%10+48;
lcd_prints (0,0,dis1);
lcd_prints (0,1,dis2);
if(result[3]=='k')
send_char(get_AD_result(channel));
delayms(100);
/*********************串口相關(guān)程序********************************/
void serial_port_initial() //定義串口初始值
PCON = 0x00; //波特率不倍速
SCON = 0x50; //8位數(shù)據(jù),可變波特率
AUXR |= 0x40; //定時器1時鐘為Fosc,即1T
AUXR &= 0xfe; //串口1選擇定時器1為波特率發(fā)生器
TMOD = 0x20;
TL1 = RELOAD_COUNT; //設(shè)定定時初值
TH1 = RELOAD_COUNT; //設(shè)定定時器重裝值
ET1 = 0; //禁止定時器1中斷
TR1 = 1; //啟動定時器1
EA = 1;
ES = 1;
void send_char(uchar i) //發(fā)送單字符
SBUF = i;
while(TI ==0); //等待發(fā)送完成
TI = 0; //清零串口發(fā)送完成中斷請求標志
void send_str(uchar stLCD_RS[]) // 發(fā)送字符串
uchar i=0;
ES = 0; //關(guān)串口中斷
while(stLCD_RS != '\0')
SBUF = stLCD_RS;
while(!TI); // 等特數(shù)據(jù)傳送
i++; // 下一個字符
ES = 1; //允許串口中斷
void UARTInterrupt(void) interrupt 4 //串口中斷接收
if(RI) // 是否有數(shù)據(jù)到來
RI=0;
result[3] = SBUF; // 暫存接收到的數(shù)據(jù)
if(result[3]<8)
channel =result[3];
result[3]=get_AD_result(channel);
send_str("第");
send_char(channel+48);
send_str("通道電壓是: ");
send_char(result[0]);
send_char('.');
send_char(result[1]);
send_char(result[2]);
send_char('V');
send_char(' ');
if(result[3]=='p')
result[3]=get_AD_result(7);
Data=63750/(result[3]);
send_str("芯片供電電壓是: ");
send_char(Data/100+48);
send_char('.');
send_char((Data%100)/10+48);
send_char(Data%10+48);
send_char('V');
send_char(' ');
/**********************AD轉(zhuǎn)換程序********************************/
uchar get_AD_result(uchar channell) //
uchar AD_finished = 0; // 存儲 A/D 轉(zhuǎn)換標志
ADC_CONTR=0xE0; //設(shè)置速度 0xx00000 打開電源 x0000000
ADC_RES = 0;
ADC_CONTR |= channell; // 選擇 A/D 當前通道
delayms(1); //使輸入電壓達到穩(wěn)定
ADC_CONTR |= 0x08; //0000,1000 令 ADC_START = 1, 啟動A/D 轉(zhuǎn)換
AD_finished = 0;
while ( AD_finished == 0 ) // 等待A/D 轉(zhuǎn)換結(jié)束
AD_finished = (ADC_CONTR & 0x10); //0001,0000, ADC_FLAG ==1測試A/D轉(zhuǎn)換結(jié)束否
ADC_CONTR &= 0xE0; //1110,0000 令 ADC_START = 0, 關(guān)閉A/D 轉(zhuǎn)換,
result[3]=ADC_RES;
result[0]=result[3]*Data/25500+48 ; // 返回 A/D 轉(zhuǎn)換結(jié)果
result[1]=((result[3]*Data/255)%100)/10+48 ;
result[2]=(result[3]*Data/255)%10+48 ;
return (result[3]);
