#include<reg51.h> //頭文件
typedef unsigned int uint;
typedef unsigned char uchar;
sbit D1=P1^0;
sbit D2=P1^1;
sbit D3=P1^2;
sbit D4=P1^3;
sbit D5=P1^4;
sbit D6=P1^5;
sbit D7=P1^6;
sbit D8=P1^7;
sbit D9=P3^0;
sbit D10=P3^1;
sbit D11=P3^2;
sbit D12=P3^3;
sbit D13=P3^4;
sbit D14=P3^5;
sbit D15=P3^6;
sbit D16=P3^7;
sbit D17=P0^0;
sbit D18=P0^1;
sbit D19=P0^2;
sbit D20=P0^3;
sbit D21=P0^4;
sbit D22=P0^5;
sbit D23=P0^6;
sbit D24=P0^7;
sbit D25=P2^0;
sbit D26=P2^1;
sbit D27=P2^2;
sbit D28=P2^3;
sbit D29=P2^4;
sbit D30=P2^5;
sbit D31=P2^6;
sbit D32=P2^7;
void delayms(unsigned int t)
unsigned int a,b;
for(a=110;a>0;a--)
for(b=t;b>0;b--);
int f=0;
void main() //主函數(shù)
if(f==0)
st:
while(D32==0);
P1=0X00;
P0=0X00;
P2=0XFF;
P3=0XFF;
f=1;
delayms(1000);
if(f==1)
D8=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D11=0;
delayms(250);
if(D32==0)goto st;/@
D7=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D12=0;
delayms(250);
if(D32==0)goto st; /@
D17=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D10=0;
delayms(250);
D4=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D16=0;
delayms(250);
D5=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D15=0;
delayms(250);
D3=1;
delayms(200);
D31=0;
delayms(200);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(200);
D27=1;
D25=0;
delayms(200);
D25=1;
D13=0;
delayms(200);
D6=1;
delayms(200);
D31=0;
delayms(200);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(200);
D27=1;
D14=0;
delayms(200);
D14=1;
D9=0;
delayms(200);
D1=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D25=0;
delayms(250);
D2=1;
delayms(250);
D31=0;
delayms(250);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(250);
D27=1;
D14=0;
delayms(250);
D20=1;
delayms(333);
D31=0;
delayms(333);
if(D32==0)goto st;
D31=1;
D27=0;
delayms(333);
D18=1;
delayms(333);
D31=0;
delayms(333);
if(D32==0)goto st;
D31=1;
D28=0;
delayms(333);
D19=1;
delayms(333);
D31=0;
delayms(333);
if(D32==0)goto st;
D31=1;
D26=0;
delayms(333);
D22=1;
delayms(333);
D31=0;
delayms(333);
if(D32==0)goto st;
D31=1;
D30=0;
delayms(333);
D21=1;
delayms(333);
D31=0;
delayms(333);
if(D32==0)goto st;
D31=1;
D29=0;
delayms(333);
D23=1;
D31=0;
delayms(1000);
f=2;
if(f==2)
